    Modules are loading with new docker image
    15 Posts 3 Posters 5.3k Views 3 Watching
      codac
      Hi guys,
      I’m using @karsten13 Docker image of MagicMirror. since the last two updates of the docker image, many of the modules show “Loading”.
      I have updated all modules and did run npm install in their folders.
      The only error I receive in the log of the magicmirror docker is:
      2024/10/07 15:45:41	stderr	(Use `node --trace-deprecation ...` to show where the warning was created)
      2024/10/07 15:45:41	stderr	[2024-10-07 15:45:41.323] [ERROR] (node:71) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
      Affected modules are:
      MMM-SoccerLiveScore
      weather
      MMM-WeatherChart
      Any ideas about how to fix this?
        codac @sdetweil
        @sdetweil @HeikoGr
        That was it, changing the parameter for the weather Plugin + updating the api Key to a payment method.
        Now weather and MMM-WeatherChart are running again.
        MMM-SoccerLiveScore not, as they seem to search for a new API.
        • H
          HeikoGr
          Which version of the docker container do you use?
            codac @HeikoGr
            @HeikoGr
            2.29.0
            • H
              HeikoGr
              Can you post your (anonymized) config file?
                codac @HeikoGr
                @HeikoGr
                I’ll add the bits for the modules. But I’m pretty sure its not the config, as it is running for years now.
                The Loading came up, after IÄve updated the docker image.
                			module: "weather",
                				type: "current",
                				locationID: "1234567", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                				apiKey: "<apiKey>"
                            "module": "MMM-WeatherChart",
                            "position": "top_right",
                            "config": {
                                "apiKey": "<apiKey>",
                                "dataNum": 24,
                                "dataType": "daily",
                				"dailyLabel": "days_of_week",
                                "height": "400px",
                                "width": "400px",
                                "lat": 50.1234567,
                                "lon": 8.1234567,
                                "units": "metric",
                				"hourFormat": "24h",
                				"showIcon": true,
                				"datalabelsDisplay": true,
                                "showRain": true,
                				"showZeroRain": false,
                				"showZeroSnow": false,
                                "includeSnow": true,
                                "showSnow": true,
                		    module: 'MMM-SoccerLiveScore',
                		    position: 'top_left',
                			        leagues: [35],
                			        showNames: true,
                			        showLogos: true,
                					displayTime: 60 * 1000,
                					showStandings: false,
                					showTables: true,
                					showScorers: false,
                					scrollVertical: false,
                					language: 'de', // supported values are en, de, it
                • H
                  HeikoGr @codac
                  @codac you need to add
                  weatherEndpoint: '/onecall',
                  for the weather module as it is using API 3.0 from openweathermap.
                  For the other modules i may look later if i have more time and access to my homelab
                    codac @HeikoGr
                    @HeikoGr What is the difference between the free user endpoints ‘/weather’ , ‘/onecall’ , ‘/forecast’?
                    • H
                      HeikoGr @codac
                      @codac API 2.5 had different endpoints, but this version is deprecated. It could go offline at any time (since june 2024).
                      API 3.0 only supports the endpoint „onecall“
                      For more details you need to read the API docs yourself
                      S 2 Replies Last reply Reply Quote 1
                        sdetweil @HeikoGr
                        @HeikoGr email from ow says 2.5 final shutdown starting on Oct 14. so just a week away
                          sdetweil @HeikoGr
                          @HeikoGr we should have made /onecall the default
                          • H
                            HeikoGr @sdetweil
                            @sdetweil at least when openweathermap is used.
                              sdetweil @HeikoGr
                              @HeikoGr yes, in the provider file
                              • H
                                HeikoGr
                                @codac MMM-WeatherChart did also update to API 3.0
                                did you update your subscription for openweathermap?
                                Unfortunately you need to add a credit card. 1000 calls per day are free.
                                On my system the weather modules are working (with my api key)
                                the MMM-SoccerLiveScore has another API problem. not related to the magic mirror release. See: https://github.com/0m4r/MMM-SoccerLiveScore/issues/13
                                  sdetweil @HeikoGr
                                  @HeikoGr i changed one word for soccer, according , to related
                                  btw, thank you for such clear messages and helping others
                                    codac @sdetweil
                                    @sdetweil @HeikoGr
