    Modules are loading with new docker image
    15 Posts 3 Posters 5.2k Views 3 Watching
    • H Offline
      HeikoGr @codac
      @codac you need to add
      weatherEndpoint: '/onecall',
      for the weather module as it is using API 3.0 from openweathermap.
      For the other modules i may look later if i have more time and access to my homelab
        codac @HeikoGr
        @HeikoGr What is the difference between the free user endpoints ‘/weather’ , ‘/onecall’ , ‘/forecast’?
        • H Offline
          HeikoGr @codac
          @codac API 2.5 had different endpoints, but this version is deprecated. It could go offline at any time (since june 2024).
          API 3.0 only supports the endpoint „onecall“
          For more details you need to read the API docs yourself
          S 2 Replies Last reply Reply Quote 1
            sdetweil @HeikoGr
            @HeikoGr email from ow says 2.5 final shutdown starting on Oct 14. so just a week away
              sdetweil @HeikoGr
              @HeikoGr we should have made /onecall the default
              • H Offline
                HeikoGr @sdetweil
                @sdetweil at least when openweathermap is used.
                  sdetweil @HeikoGr
                  @HeikoGr yes, in the provider file
                  • H Offline
                    HeikoGr
                    @codac MMM-WeatherChart did also update to API 3.0
                    did you update your subscription for openweathermap?
                    Unfortunately you need to add a credit card. 1000 calls per day are free.
                    On my system the weather modules are working (with my api key)
                    the MMM-SoccerLiveScore has another API problem. not related to the magic mirror release. See: https://github.com/0m4r/MMM-SoccerLiveScore/issues/13
                      sdetweil @HeikoGr
                      @HeikoGr i changed one word for soccer, according , to related
                      btw, thank you for such clear messages and helping others
                        codac @sdetweil
                        @sdetweil @HeikoGr
                        That was it, changing the parameter for the weather Plugin + updating the api Key to a payment method.
                        Now weather and MMM-WeatherChart are running again.
                        MMM-SoccerLiveScore not, as they seem to search for a new API.
