Modules are loading with new docker image
15 Posts 3 Posters 1.3k Views 3 Watching
    codac
    Hi guys,
    I’m using @karsten13 Docker image of MagicMirror. since the last two updates of the docker image, many of the modules show “Loading”.
    I have updated all modules and did run npm install in their folders.
    The only error I receive in the log of the magicmirror docker is:
    2024/10/07 15:45:41	stderr	(Use `node --trace-deprecation ...` to show where the warning was created)
    2024/10/07 15:45:41	stderr	[2024-10-07 15:45:41.323] [ERROR] (node:71) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
    Affected modules are:
    MMM-SoccerLiveScore
    weather
    MMM-WeatherChart
    Any ideas about how to fix this?
      codac @sdetweil
      @sdetweil @HeikoGr
      That was it, changing the parameter for the weather Plugin + updating the api Key to a payment method.
      Now weather and MMM-WeatherChart are running again.
      MMM-SoccerLiveScore not, as they seem to search for a new API.
      • H Offline
        HeikoGr
        Which version of the docker container do you use?
        C 1 Reply Last reply Oct 8, 2024, 7:37 PM Reply Quote 0
          codac @HeikoGr
          @HeikoGr
          2.29.0
          • H Offline
            HeikoGr
            Can you post your (anonymized) config file?
            C 1 Reply Last reply Oct 9, 2024, 6:58 AM Reply Quote 0
              codac @HeikoGr
              @HeikoGr
              I’ll add the bits for the modules. But I’m pretty sure its not the config, as it is running for years now.
              The Loading came up, after IÄve updated the docker image.
              			module: "weather",
              				type: "current",
              				locationID: "1234567", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
              				apiKey: "<apiKey>"
                          "module": "MMM-WeatherChart",
                          "position": "top_right",
                          "config": {
                              "apiKey": "<apiKey>",
                              "dataNum": 24,
                              "dataType": "daily",
              				"dailyLabel": "days_of_week",
                              "height": "400px",
                              "width": "400px",
                              "lat": 50.1234567,
                              "lon": 8.1234567,
                              "units": "metric",
              				"hourFormat": "24h",
              				"showIcon": true,
              				"datalabelsDisplay": true,
                              "showRain": true,
              				"showZeroRain": false,
              				"showZeroSnow": false,
                              "includeSnow": true,
                              "showSnow": true,
              		    module: 'MMM-SoccerLiveScore',
              		    position: 'top_left',
              			        leagues: [35],
              			        showNames: true,
              			        showLogos: true,
              					displayTime: 60 * 1000,
              					showStandings: false,
              					showTables: true,
              					showScorers: false,
              					scrollVertical: false,
              					language: 'de', // supported values are en, de, it
              H 1 Reply Last reply Oct 9, 2024, 7:29 AM Reply Quote 0
              • H Offline
                HeikoGr @codac
                @codac you need to add
                weatherEndpoint: '/onecall',
                for the weather module as it is using API 3.0 from openweathermap.
                For the other modules i may look later if i have more time and access to my homelab
                C 1 Reply Last reply Oct 9, 2024, 8:03 AM Reply Quote 0
                  codac @HeikoGr
                  @HeikoGr What is the difference between the free user endpoints ‘/weather’ , ‘/onecall’ , ‘/forecast’?
                  H 1 Reply Last reply Oct 9, 2024, 8:10 AM Reply Quote 0
                  • H Offline
                    HeikoGr @codac
                    @codac API 2.5 had different endpoints, but this version is deprecated. It could go offline at any time (since june 2024).
                    API 3.0 only supports the endpoint „onecall“
                    For more details you need to read the API docs yourself
                    S 2 Replies Last reply Oct 9, 2024, 1:51 PM Reply Quote 1
                    • S Away
                      sdetweil @HeikoGr
                      @HeikoGr email from ow says 2.5 final shutdown starting on Oct 14. so just a week away
                      • S Away
                        sdetweil @HeikoGr
                        @HeikoGr we should have made /onecall the default
                        H 1 Reply Last reply Oct 9, 2024, 3:53 PM Reply Quote 0
