    Calendar shows late day events on next day but at correct time
    35 Posts 4 Posters 11.4k Views 6 Watching
      MarcLandis Module Developer @sdetweil
      @sdetweil I testet your branch and so far it looks good with my test calendar and also with my real ones.
      S 2 Replies Last reply Reply Quote 1
        sdetweil @MarcLandis
        @MarcLandis thanks. i still have some reported issues. so use it and let me know. will advise when i make nect updates
        we wouldn’t release til jan anyhow, so we have time
          sdetweil @natmash
          @natmash please see my latest test update this entry is now added to the testcases run
          (I had NOT fixed it before today)
            @MarcLandis can you retest at your convenience
            git pull and npm run install-mm
            • N Offline
              natmash @sdetweil
              @sdetweil I pulled down and started it up. Indeed the entries show up on the correct days, but now the entries that were right time, wrong day, are right day, wrong time (offset).
                sdetweil @natmash
                @natmash did you do that pull before today? cause it was broken yesterday
                not now…
                and requires the updated node-ical ., so npm install too…
                • N Offline
                  natmash @sdetweil
                  @sdetweil I pulled yesterday and again this morning, and I ran npm install as well.
                  Latest commit I have is 95db75ab17b1a258bb8969a31197acc4fcb37d73.
                    sdetweil @natmash
                    @natmash able ro recreate
                    • N Offline
                      natmash @sdetweil
                      @sdetweil For now I have done
                      if (hasByWeekdayRule && false)
                      (in order to change as little as possible) and my use cases work for now.
                        sdetweil @natmash
                        @natmash cool…
                          @MarcLandis @natmash
                          here is an updated test version of the fixes for all kinds of calendar date problems.
                          NOTE: the changed branch name
                          NOTE: this used the node-cal@0.19.0 library UNCHANGED
                          best to make a new folder and git clone there
                          git clone https://github.com/sdetweil/MagicMirror
                          cd MagicMirror
                          git checkout fixcaldates2 // <------ note this is a changed branch name
                          npm run install-mm
                          copy your config.js and custom.css from the prior folder
                          and the non-default modules you have installed…
                          this ONLY changes the default calendar
                          but DOES ship an updated node-ical library too
                          if you need to fall back, just rename the folders around again so that
                          your original is called MagicMirror
                          all the testcases for node-ical and MagicMirror execute successfully.
                          the ‘BIG’ change here is to get the local NON-TZ dates for the
                          rrule.between()
                          all the checking and conversion code is commented out or not used
                          the node-ical fixes are for excluded dates (exdate) values being adjusted for DST/STD time… waiting to submit that PR
                          one fix in calendar.js for checking if a past date was too far back,
                          but it never checked to see IF the event date was in the past… (before today) so it chopped off too many
                          and one change in calendarfetcher.js to put out a better diagnostic message of the parsed data… (exdate was excluded cause JSON stringify couldn’t convert the complex structure)
                          I added the tests you all have documented
                          please re-pull and checkout the new branch (I deleted the old branch)
                          and npm run install-mm again
                          • N Offline
                            natmash
                            @sdetweil That looks correct to me now!
                              sdetweil @natmash
                              @natmash awesome, thanks for the feedback…
                              have one moved recurring event problem yet…
                                @natmash posted another update, moved event at end of day
                                really need to add another, moved to diff time, and duration(done)
                                also added testcases for moved( before and after original) AND deleted recurrences
                                • N Offline
                                  natmash @sdetweil
                                  @sdetweil Still looks good to me!
                                    sdetweil @natmash
                                    @natmash awesome. thanks for the testing and feedback
