    Calendar shows late day events on next day but at correct time
    35 Posts 4 Posters 12.6k Views 6 Watching
    • N
      natmash
      Barre Class, with dates: ["2024-09-11T01:15:00.000Z","2024-09-18T01:15:00.000Z","2024-09-25T01:15:00.000Z","2024-10-02T01:15:00.000Z","2024-10-09T01:15:00.000Z","2024-10-16T01:15:00.000Z","2024-10-23T01:15:00.000Z","2024-10-30T01:15:00.000Z","2024-11-06T01:15:00.000Z","2024-11-13T01:15:00.000Z","2024-11-20T01:15:00.000Z","2024-11-27T01:15:00.000Z","2024-12-04T01:15:00.000Z","2024-12-11T01:15:00.000Z","2024-12-18T01:15:00.000Z","2024-12-25T01:15:00.000Z","2025-01-01T01:15:00.000Z","2025-01-08T01:15:00.000Z","2025-01-15T01:15:00.000Z","2025-01-22T01:15:00.000Z","2025-01-29T01:15:00.000Z","2025-02-05T01:15:00.000Z","2025-02-12T01:15:00.000Z","2025-02-19T01:15:00.000Z","2025-02-26T01:15:00.000Z","2025-03-05T01:15:00.000Z","2025-03-12T01:15:00.000Z","2025-03-19T01:15:00.000Z","2025-03-26T01:15:00.000Z","2025-04-02T01:15:00.000Z","2025-04-09T01:15:00.000Z","2025-04-16T01:15:00.000Z","2025-04-23T01:15:00.000Z","2025-04-30T01:15:00.000Z","2025-05-07T01:15:00.000Z","2025-05-14T01:15:00.000Z","2025-05-21T01:15:00.000Z","2025-05-28T01:15:00.000Z"]
      [2024-09-28 11:26:06.920] [DEBUG] Rule has byweekday, checking for correction
      [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Sep 10 2024 20:15:00 GMT-0500 (Central Daylight Time)
      [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Sep 17 2024 20:15:00 GMT-0500 (Central Daylight Time)
      [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Sep 24 2024 20:15:00 GMT-0500 (Central Daylight Time)
      [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Oct 01 2024 20:15:00 GMT-0500 (Central Daylight Time)
      [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Oct 08 2024 20:15:00 GMT-0500 (Central Daylight Time)
      [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Oct 15 2024 20:15:00 GMT-0500 (Central Daylight Time)
      [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Oct 22 2024 20:15:00 GMT-0500 (Central Daylight Time)
      [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Oct 29 2024 20:15:00 GMT-0500 (Central Daylight Time)
      [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 6) and hour=19 >= 24-6, Adding 1 day to Tue Nov 05 2024 19:15:00 GMT-0600 (Central Standard Time)
        sdetweil @natmash
        @natmash yes… code I put in to fix another bug, in the repeating rule parser… it used to return the day prior UTC date and right time… so I adjusted it.
        now in this one case it returns the correct UTC date…
        if I fix this it breaks other testcases…
        looking for another option
          sdetweil @natmash
          @natmash so, I think I finally have a fix for this.
          Would you like to try it?
          Which MagicMirror version are you using?
            MarcLandis Module Developer @sdetweil
            @sdetweil I am going to test your fix with my calendar too, as it was the cause for the initial fix.
              sdetweil @MarcLandis
              @MarcLandis you want it on 2.28 or 2.29?
                @sdetweil 2.29 please
                (2.28 is too old :) )
                  @MarcLandis understood, but I don’t want to force upgrade to test
                    @MarcLandis @natmash
                    here is a test version of the fixes for all kinds of calendar date problems.
                    best to make a new folder and git clone there
                    git  clone https://github.com/sdetweil/MagicMirror
                    cd MagicMirror
                    git checkout fixcaldates
                    npm run install-mm
                    copy your config.js and custom.css from the prior folder
                    and the non-default modules you have installed…
                    this ONLY changes the default calendar
                    but DOES ship an updated node-ical library too
                    if you need to fall back, just rename the folders around again so that
                    your original is called MagicMirror
                    all the testcases for node-ical and MagicMirror execute successfully.
                    the ‘BIG’ change here is to get the local NON-TZ dates for the
                    rrule.between()
                    all the checking and conversion code is commented out or not used
                    the node-ical fixes are for excluded dates (exdate) values being adjusted for DST/STD time… waiting to submit that PR
                    one fix in calendar.js for checking if a past date was too far back,
                    but it never checked to see IF the event date was in the past… (before today) so it chopped off too many
                    and one change in calendarfetcher.js to put out a better diagnostic message of the parsed data… (exdate was excluded cause JSON stringify couldn’t convert the complex structure)
                      @sdetweil I testet your branch and so far it looks good with my test calendar and also with my real ones.
                      S 2 Replies Last reply Reply Quote 1
                        @MarcLandis thanks. i still have some reported issues. so use it and let me know. will advise when i make nect updates
                        we wouldn’t release til jan anyhow, so we have time
                          sdetweil @natmash
                          @natmash please see my latest test update this entry is now added to the testcases run
                          (I had NOT fixed it before today)
                            @MarcLandis can you retest at your convenience
                            git pull and npm run install-mm
                            • N
                              natmash @sdetweil
                              @sdetweil I pulled down and started it up. Indeed the entries show up on the correct days, but now the entries that were right time, wrong day, are right day, wrong time (offset).
                                sdetweil @natmash
                                @natmash did you do that pull before today? cause it was broken yesterday
                                not now…
                                and requires the updated node-ical ., so npm install too…
                                • N
                                  natmash @sdetweil
                                  @sdetweil I pulled yesterday and again this morning, and I ran npm install as well.
                                  Latest commit I have is 95db75ab17b1a258bb8969a31197acc4fcb37d73.
                                    sdetweil @natmash
                                    @natmash able ro recreate
                                    • N
                                      natmash @sdetweil
                                      @sdetweil For now I have done
                                      if (hasByWeekdayRule && false)
                                      (in order to change as little as possible) and my use cases work for now.
                                        sdetweil @natmash
                                        @natmash cool…
                                          here is an updated test version of the fixes for all kinds of calendar date problems.
                                          NOTE: the changed branch name
                                          NOTE: this used the node-cal@0.19.0 library UNCHANGED
                                          cd MagicMirror
                                          git checkout fixcaldates2 // <------ note this is a changed branch name
                                          npm run install-mm
                                          rrule.between()
                                          I added the tests you all have documented
                                          please re-pull and checkout the new branch (I deleted the old branch)
                                          and npm run install-mm again
                                          • N
                                            natmash
                                            @sdetweil That looks correct to me now!
