    MMM-MovieListings
    28 Posts 4 Posters 14.2k Views 4 Watching
    • mumblebajM
      mumblebaj Module Developer @BerkSmash1984
      @BerkSmash1984 I would give node 20.9.0 a go.
      BerkSmash1984B 1 Reply Last reply
      • BerkSmash1984B
        BerkSmash1984 @mumblebaj
        @mumblebaj
        Just hesitant that the update will break other modules my MM is using. Sounds like Node updates could be more hassle than they are worth if your MM is functioning, minus a model or 2 ;)
        What is the safest way to update Node to 20.9.0? Node Version Manager?
        mumblebajM S 2 Replies Last reply
        • mumblebajM
          @BerkSmash1984 Yeah, that would work.
            sdetweil @BerkSmash1984
            @BerkSmash1984 if you used my script it should upgrade mode too. it uses n, the nodejs version of nvm
            • mumblebajM
              @sdetweil From the above it does seem like he used your script but it failed to update node to the required version which should be one of the following, right?
              >=20.9.0 <21 || 22
                sdetweil @mumblebaj
                @mumblebaj yes , id like to see the installers/upgrade.log
                maybe the test subversion failed
                  sdetweil @mumblebaj
                  @mumblebaj really >=20.9.0, not 21, or >= 22
                  mumblebajM 1 Reply Last reply
                  • mumblebajM
                    @sdetweil From package.json
                    • BerkSmash1984B
                      @mumblebaj @sdetweil
                      I did the update using @sdetweil upgrade script
                      • mumblebajM
                        mumblebaj Module Developer @mumblebaj
                        UPDATES
                        V1.1.0
                        • Fixed issue with cast list appending cast members from different movies to the same list. Now only cast members of the displayed movie is displayed.
                        • Update and simplify the API calls to reduce the number of calls.
                        Reply Quote 2
