    Feature suggestion: Dual or triple screen
    Scheduled Pinned Locked Moved Solved Feature Requests
    5 Posts 3 Posters 941 Views 3 Watching
      MarkV
      I’d would be a great addon to mm if there was a native option for dual or triple monitors.
      This to make a large mirror or a mirror with screens on different places.
      Or by running it on a Docker platform and then run a instance per screen…
      S BKeyportB 4 Replies Last reply Reply Quote 0
      • BKeyportB Offline
        BKeyport Module Developer @MarkV
        @MarkV It’s documented how to do it. I (re)wrote that documentation personally. Feel free to read https://docs.magicmirror.builders/configuration/introduction.html#advanced-configuration-and-frequently-asked-how-to-configure-examples and ask here if you have any questions, I’ll be more than happy to help.
          sdetweil @MarkV
          @MarkV dont understand
          you can run multiple instances from the same folder w different config.js and move them to different displays
          see the documentation, it has examples
          https://docs.magicmirror.builders/configuration/introduction.html#using-electronoptions
            sdetweil @MarkV
            @MarkV with docker is a little harder, as the system ui is not visible in the container, you run server only
            but you can start any of the browsers from a shell script on the docker host, or some other host, pointing to different server urls and move them to different displays
            • BKeyportB Offline
                sdetweil @MarkV
                @MarkV did you get this working
