    Default weather module stuck loading after latest MM update
    35 Posts 8 Posters 14.0k Views 8 Watching
      MaXi-XCeL Project Sponsor @Peter
      @Peter Found it in the documentation!
      Note: Latitude and longitude are REQUIRED if weatherEndpoint is set to ‘/onecall’. The locationID and location options are ignored when the OpenWeatherMap One Call API is used.
      https://docs.magicmirror.builders/modules/weather.html#configuration-options
      P P 2 Replies Last reply Reply Quote 1
        Peter @MaXi-XCeL
        @MaXi-XCeL it works!
        Thanks,
        Peter
          pritikin71 @MaXi-XCeL
          Hi I have a new problem now, using /onecall and the correct Lat /Long parameters shows my Time Zone Name omn top of Weather modules and a Crazy time… the Clock Module shows correct.
          What else I need to modify to have Weather working again like before the doomed update? ( “Xx” for privacy)
          		module: "weather",
          		CalendarClasses: "current",
          		header: "Weather Forecast",
                  disabled: false,
          			weatherEndpoint: "/onecall",
          			//updateInterval: "20",
          			type: "current",
          			tempUnits: "imperial",
          			degreeLabel: "false",
          			locationID: "XXxXXX", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          			apiKey: "XxXXXXxxXXXXxXXxXXxX",
                      showFeelsLike: "false",
          			lat: "2XXXX350",
                      lon: "-8X.3XXxX915"
          S S 2 Replies Last reply Reply Quote 0
            sdetweil @pritikin71
            @pritikin71
            see
            https://forum.magicmirror.builders/topic/19043/location-title-in-default-module-weather-openweather
              pritikin71 @sdetweil
              @sdetweil Thank you a lot.
              I was able to fix the header problem but not the time problem. I looked to a lot of /js files looking for the TimeZone Parameter but I didnt get it.
              Also is really weird the 18:48… the different minutes tells that maybe isn’t a timezone problem.
              S karsten13K 2 Replies Last reply Reply Quote 0
                @pritikin71 weather with openweather 3 uses lat/lon for location
                and time is local system time . make sure you have timezone set correctly
                corrected below… sunrise/sunset time is shown (whichever is next)
                not current wall clock time
                • karsten13K Offline
                  karsten13 @pritikin71
                  @pritikin71 said in Default weather module stuck loading after latest MM update:
                  this is not an actual time, but sunrise or sunset (depending on what comes next)
                    sdetweil @karsten13
                    @karsten13 dang I get that wrong EVERY time!
                      karsten13 @sdetweil
                      @sdetweil said in Default weather module stuck loading after latest MM update:
                      one of the reasons I wrote my own njk …
                        pritikin71 @karsten13
                        @karsten13 Wow… you kill me… what a Shame jaja Sorry for the misunderstood and great idea your config/
                        @sdetweil thanks too
                          Sampleswow @pritikin71
                          @pritikin71 said in [Default weather module stuck loading after latest MM
                            	module: "weather",
                                  disabled: false,
                            		type: "current",
                            		lat: "2XXXX350",
                                      lon: "-8X.3XXxX915"
                          My code looks exactly like this i even generated a new api key paid setup payment and i am still only getting loading on my npm start i have Zero Errors im so confused
                            sdetweil @Sampleswow
                            @Sampleswow weather is done all in browser, so you have to open the browser developers window condole tab to see any errors
                            ctrl-shift-i
                              Sampleswow @sdetweil
                              Thanks for your reply i have found the error it is,
                              Failed to load resource: the api.openweathermap
                              server responded with a
                              status of 401 (unauthorized)
                              how do i adjust this?
                                @Sampleswow said in Default weather module stuck loading after latest MM update:
                                your api key is incorrect
                                the 3.0 apikey requires a credit card, right?
                                see this too
                                https://github.com/MagicMirrorOrg/MagicMirror/issues/3574#issuecomment-2423544713
