    Default weather module stuck loading after latest MM update
    35 Posts 8 Posters 14.4k Views 8 Watching
      sdetweil @JMac
      @JMac did u have the trailing comma
      we added code to stop MagicMirror coming up with garbage profile on error
      J P 2 Replies Last reply
        JMac @sdetweil
        @sdetweil I have it exactly as you have it above.
        can you share a config for this module as an example?
        I can’t even check if this is working with pm2 not launching the MM
          sdetweil @JMac
          @JMac
          npm start
          J 1 Reply Last reply
            Peter @sdetweil
            @sdetweil Adding ‘weatherEndpoint: “/onecall”,’’ gives some kind of weather, but for the wrong location I presume (26C but it is only 15C here).
            So, location ID does not work with API 3.0; it worked with 2.5.
            Somebody have the solution?
            Lat/ Lon?
            Peter
            M 1 Reply Last reply
              JMac @sdetweil
              > magicmirror@2.29.0 start
              [2024-10-08 19:41:58.640] [LOG]   Starting MagicMirror: v2.29.0
              [2024-10-08 19:41:58.693] [LOG]   Loading config ...
              [2024-10-08 19:41:58.698] [LOG]   config template file not exists, no envsubst
              [2024-10-08 19:41:59.497] [INFO]  Checking config file /home/MagicMirror/MagicMirror/config/config.js ...
              [2024-10-08 19:41:59.584] [ERROR] Your configuration file contains syntax errors :(
              Line 94 column 5: Parsing error: Unexpected token weatherEndpoint
              That parsing error is for the new line added in for weatherEndpoint
                sdetweil @JMac
                @JMac yes, the line before needs a trailing comma
                  MaXi-XCeL Project Sponsor @Peter
                  @Peter Found it in the documentation!
                  Note: Latitude and longitude are REQUIRED if weatherEndpoint is set to ‘/onecall’. The locationID and location options are ignored when the OpenWeatherMap One Call API is used.
                  https://docs.magicmirror.builders/modules/weather.html#configuration-options
                  P P 2 Replies Last reply
                    Peter @MaXi-XCeL
                    @MaXi-XCeL it works!
                    Thanks,
                    Peter
                      pritikin71 @MaXi-XCeL
                      Hi I have a new problem now, using /onecall and the correct Lat /Long parameters shows my Time Zone Name omn top of Weather modules and a Crazy time… the Clock Module shows correct.
                      What else I need to modify to have Weather working again like before the doomed update? ( “Xx” for privacy)
                      		module: "weather",
                      		CalendarClasses: "current",
                      		header: "Weather Forecast",
                              disabled: false,
                      			weatherEndpoint: "/onecall",
                      			//updateInterval: "20",
                      			type: "current",
                      			tempUnits: "imperial",
                      			degreeLabel: "false",
                      			locationID: "XXxXXX", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                      			apiKey: "XxXXXXxxXXXXxXXxXXxX",
                                  showFeelsLike: "false",
                      			lat: "2XXXX350",
                                  lon: "-8X.3XXxX915"
                      S S 2 Replies Last reply
                        sdetweil @pritikin71
                        @pritikin71
                        see
                        https://forum.magicmirror.builders/topic/19043/location-title-in-default-module-weather-openweather
                        P 1 Reply Last reply
                          pritikin71 @sdetweil
                          @sdetweil Thank you a lot.
                          I was able to fix the header problem but not the time problem. I looked to a lot of /js files looking for the TimeZone Parameter but I didnt get it.
                          Also is really weird the 18:48… the different minutes tells that maybe isn’t a timezone problem.
                          S karsten13K 2 Replies Last reply
                            @pritikin71 weather with openweather 3 uses lat/lon for location
                            and time is local system time . make sure you have timezone set correctly
                            corrected below… sunrise/sunset time is shown (whichever is next)
                            not current wall clock time
                            • karsten13K
                              karsten13 @pritikin71
                              @pritikin71 said in Default weather module stuck loading after latest MM update:
                              this is not an actual time, but sunrise or sunset (depending on what comes next)
                                sdetweil @karsten13
                                @karsten13 dang I get that wrong EVERY time!
                                karsten13K 1 Reply Last reply
                                • karsten13K
                                  karsten13 @sdetweil
                                  @sdetweil said in Default weather module stuck loading after latest MM update:
                                  one of the reasons I wrote my own njk …
                                    pritikin71 @karsten13
                                    @karsten13 Wow… you kill me… what a Shame jaja Sorry for the misunderstood and great idea your config/
                                    @sdetweil thanks too
                                      Sampleswow @pritikin71
                                      @pritikin71 said in [Default weather module stuck loading after latest MM
                                        	module: "weather",
                                              disabled: false,
                                        		type: "current",
                                        		lat: "2XXXX350",
                                                  lon: "-8X.3XXxX915"
                                      My code looks exactly like this i even generated a new api key paid setup payment and i am still only getting loading on my npm start i have Zero Errors im so confused
                                        sdetweil @Sampleswow
                                        @Sampleswow weather is done all in browser, so you have to open the browser developers window condole tab to see any errors
                                        ctrl-shift-i
                                          Sampleswow @sdetweil
                                          Thanks for your reply i have found the error it is,
                                          Failed to load resource: the api.openweathermap
                                          server responded with a
                                          status of 401 (unauthorized)
                                          how do i adjust this?
                                            @Sampleswow said in Default weather module stuck loading after latest MM update:
                                            your api key is incorrect
                                            the 3.0 apikey requires a credit card, right?
                                            see this too
                                            https://github.com/MagicMirrorOrg/MagicMirror/issues/3574#issuecomment-2423544713
