    Default weather module stuck loading after latest MM update
    35 Posts 8 Posters 13.6k Views 8 Watching
      Peter @Peter
      This is my config, maybe somebody can tell me what is wrong?
      module: "weather",
      type: "current",
      locationID: "2759705", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      apiKey: "xxxxxxxxxxxxxxxxxxxxxx"
      module: "weather",
      header: "Weersverwachting",
      colored: true,
      type: "forecast",
      apiKey: "xxxxxxxxxxxxxxxxxx"
        sdetweil @Peter
        @Peter ok, two things…
        you ALSO have to add
        weatherEndpoint: "/onecall",
        to each config, as this is required for the 3.0 api
        this makes it work with my 3.0 apikey
        second,
        in the forum, when you post config, or log info, please use the code block wrapper… else the quotes get changed to workd processing type which JS doesn’t understand
        to do
        paste the text into the editor, blank line above and below
        select the text just pasted
        hit the </> button above the editor
        P J 2 Replies Last reply Reply Quote 2
          pritikin71 @sdetweil
          @sdetweil Thanks, You solve a 2 weeks headache problem wit this line:
          weatherEndpoint: “/onecall”,
            JMac @sdetweil
            @sdetweil so my config was identical to above, so I’ve added you new line “weatherEndpoint…”
            I’m using Putty to access the MM and used pm2 to stop the MM.
            which it did.
            However now, pm2 via Putty is no longer having any effect on the MM.
            MM isn’t launching.
            run pm2 logs mm and get a parsing error over adding the new line
            unexpected token weatherEndpoint your configuration file contains syntax errors.
            all I’ve added is weatherEndpoint: “/onecall”, to a final line under the apiKey line above.
            any thoughts?
            edit to add, pm2 status and logs show that pm2 exists still it’s just not launching. can pm2 be “updated” or should I follow the process for a first install?
            for completeness I don’t want it to launch MM on boot I just want to be able to start and stop the MM using pm2.
              sdetweil @JMac
              @JMac did u have the trailing comma
              we added code to stop MagicMirror coming up with garbage profile on error
              J P 2 Replies Last reply Reply Quote 0
                JMac @sdetweil
                @sdetweil I have it exactly as you have it above.
                can you share a config for this module as an example?
                I can’t even check if this is working with pm2 not launching the MM
                  sdetweil @JMac
                  @JMac
                  npm start
                    Peter @sdetweil
                    @sdetweil Adding ‘weatherEndpoint: “/onecall”,’’ gives some kind of weather, but for the wrong location I presume (26C but it is only 15C here).
                    So, location ID does not work with API 3.0; it worked with 2.5.
                    Somebody have the solution?
                    Lat/ Lon?
                    Peter
                      JMac @sdetweil
                      > magicmirror@2.29.0 start
                      [2024-10-08 19:41:58.640] [LOG]   Starting MagicMirror: v2.29.0
                      [2024-10-08 19:41:58.693] [LOG]   Loading config ...
                      [2024-10-08 19:41:58.698] [LOG]   config template file not exists, no envsubst
                      [2024-10-08 19:41:59.497] [INFO]  Checking config file /home/MagicMirror/MagicMirror/config/config.js ...
                      [2024-10-08 19:41:59.584] [ERROR] Your configuration file contains syntax errors :(
                      Line 94 column 5: Parsing error: Unexpected token weatherEndpoint
                      That parsing error is for the new line added in for weatherEndpoint
                        sdetweil @JMac
                        @JMac yes, the line before needs a trailing comma
                          MaXi-XCeL Project Sponsor @Peter
                          @Peter Found it in the documentation!
                          Note: Latitude and longitude are REQUIRED if weatherEndpoint is set to ‘/onecall’. The locationID and location options are ignored when the OpenWeatherMap One Call API is used.
                          https://docs.magicmirror.builders/modules/weather.html#configuration-options
                          P P 2 Replies Last reply Reply Quote 1
                            Peter @MaXi-XCeL
                            @MaXi-XCeL it works!
                            Thanks,
                            Peter
                              pritikin71 @MaXi-XCeL
                              Hi I have a new problem now, using /onecall and the correct Lat /Long parameters shows my Time Zone Name omn top of Weather modules and a Crazy time… the Clock Module shows correct.
                              What else I need to modify to have Weather working again like before the doomed update? ( “Xx” for privacy)
                              		module: "weather",
                              		CalendarClasses: "current",
                              		header: "Weather Forecast",
                                      disabled: false,
                              			//updateInterval: "20",
                              			type: "current",
                              			tempUnits: "imperial",
                              			degreeLabel: "false",
                              			locationID: "XXxXXX", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                              			apiKey: "XxXXXXxxXXXXxXXxXXxX",
                                          showFeelsLike: "false",
                              			lat: "2XXXX350",
                                          lon: "-8X.3XXxX915"
                              S S 2 Replies Last reply Reply Quote 0
                                sdetweil @pritikin71
                                @pritikin71
                                see
                                https://forum.magicmirror.builders/topic/19043/location-title-in-default-module-weather-openweather
                                  @sdetweil Thank you a lot.
                                  I was able to fix the header problem but not the time problem. I looked to a lot of /js files looking for the TimeZone Parameter but I didnt get it.
                                  Also is really weird the 18:48… the different minutes tells that maybe isn’t a timezone problem.
                                  S karsten13K 2 Replies Last reply Reply Quote 0
                                    @pritikin71 weather with openweather 3 uses lat/lon for location
                                    and time is local system time . make sure you have timezone set correctly
                                    corrected below… sunrise/sunset time is shown (whichever is next)
                                    not current wall clock time
                                    • karsten13K Offline
                                      karsten13 @pritikin71
                                      @pritikin71 said in Default weather module stuck loading after latest MM update:
                                      this is not an actual time, but sunrise or sunset (depending on what comes next)
                                        sdetweil @karsten13
                                        @karsten13 dang I get that wrong EVERY time!
                                          karsten13 @sdetweil
                                          @sdetweil said in Default weather module stuck loading after latest MM update:
                                          one of the reasons I wrote my own njk …
                                            pritikin71 @karsten13
                                            @karsten13 Wow… you kill me… what a Shame jaja Sorry for the misunderstood and great idea your config/
                                            @sdetweil thanks too
