    Default weather module stuck loading after latest MM update
    35 Posts 8 Posters 14.4k Views 8 Watching
      sdetweil @JMac
      @JMac
      npm start
        Peter @sdetweil
        @sdetweil Adding ‘weatherEndpoint: “/onecall”,’’ gives some kind of weather, but for the wrong location I presume (26C but it is only 15C here).
        So, location ID does not work with API 3.0; it worked with 2.5.
        Somebody have the solution?
        Lat/ Lon?
        Peter
          JMac @sdetweil
          > magicmirror@2.29.0 start
          [2024-10-08 19:41:58.640] [LOG]   Starting MagicMirror: v2.29.0
          [2024-10-08 19:41:58.693] [LOG]   Loading config ...
          [2024-10-08 19:41:58.698] [LOG]   config template file not exists, no envsubst
          [2024-10-08 19:41:59.497] [INFO]  Checking config file /home/MagicMirror/MagicMirror/config/config.js ...
          [2024-10-08 19:41:59.584] [ERROR] Your configuration file contains syntax errors :(
          Line 94 column 5: Parsing error: Unexpected token weatherEndpoint
          That parsing error is for the new line added in for weatherEndpoint
            sdetweil @JMac
            @JMac yes, the line before needs a trailing comma
              MaXi-XCeL Project Sponsor @Peter
              @Peter Found it in the documentation!
              Note: Latitude and longitude are REQUIRED if weatherEndpoint is set to ‘/onecall’. The locationID and location options are ignored when the OpenWeatherMap One Call API is used.
              https://docs.magicmirror.builders/modules/weather.html#configuration-options
              P P 2 Replies Last reply Reply Quote 1
                Peter @MaXi-XCeL
                @MaXi-XCeL it works!
                Thanks,
                Peter
                  pritikin71 @MaXi-XCeL
                  Hi I have a new problem now, using /onecall and the correct Lat /Long parameters shows my Time Zone Name omn top of Weather modules and a Crazy time… the Clock Module shows correct.
                  What else I need to modify to have Weather working again like before the doomed update? ( “Xx” for privacy)
                  		module: "weather",
                  		CalendarClasses: "current",
                  		header: "Weather Forecast",
                          disabled: false,
                  			weatherEndpoint: "/onecall",
                  			//updateInterval: "20",
                  			type: "current",
                  			tempUnits: "imperial",
                  			degreeLabel: "false",
                  			locationID: "XXxXXX", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                  			apiKey: "XxXXXXxxXXXXxXXxXXxX",
                              showFeelsLike: "false",
                  			lat: "2XXXX350",
                              lon: "-8X.3XXxX915"
                  S S 2 Replies Last reply Reply Quote 0
                    sdetweil @pritikin71
                    @pritikin71
                    see
                    https://forum.magicmirror.builders/topic/19043/location-title-in-default-module-weather-openweather
                      pritikin71 @sdetweil
                      @sdetweil Thank you a lot.
                      I was able to fix the header problem but not the time problem. I looked to a lot of /js files looking for the TimeZone Parameter but I didnt get it.
                      Also is really weird the 18:48… the different minutes tells that maybe isn’t a timezone problem.
                      S karsten13K 2 Replies Last reply Reply Quote 0
                        @pritikin71 weather with openweather 3 uses lat/lon for location
                        and time is local system time . make sure you have timezone set correctly
                        corrected below… sunrise/sunset time is shown (whichever is next)
                        not current wall clock time
                        • karsten13K
                          karsten13 @pritikin71
                          @pritikin71 said in Default weather module stuck loading after latest MM update:
                          this is not an actual time, but sunrise or sunset (depending on what comes next)
                            sdetweil @karsten13
                            @karsten13 dang I get that wrong EVERY time!
                            • karsten13K
                              karsten13 @sdetweil
                              @sdetweil said in Default weather module stuck loading after latest MM update:
                              one of the reasons I wrote my own njk …
                                pritikin71 @karsten13
                                @karsten13 Wow… you kill me… what a Shame jaja Sorry for the misunderstood and great idea your config/
                                @sdetweil thanks too
                                  Sampleswow @pritikin71
                                  @pritikin71 said in [Default weather module stuck loading after latest MM
                                    	module: "weather",
                                          disabled: false,
                                    		type: "current",
                                    		lat: "2XXXX350",
                                              lon: "-8X.3XXxX915"
                                  My code looks exactly like this i even generated a new api key paid setup payment and i am still only getting loading on my npm start i have Zero Errors im so confused
                                    sdetweil @Sampleswow
                                    @Sampleswow weather is done all in browser, so you have to open the browser developers window condole tab to see any errors
                                    ctrl-shift-i
                                      Sampleswow @sdetweil
                                      Thanks for your reply i have found the error it is,
                                      Failed to load resource: the api.openweathermap
                                      server responded with a
                                      status of 401 (unauthorized)
                                      how do i adjust this?
                                        @Sampleswow said in Default weather module stuck loading after latest MM update:
                                        your api key is incorrect
                                        the 3.0 apikey requires a credit card, right?
                                        see this too
                                        https://github.com/MagicMirrorOrg/MagicMirror/issues/3574#issuecomment-2423544713
