    Cant use showEnd icloud cal
    30 Posts 3 Posters 5.6k Views 3 Watching
      sdetweil @blvk
      @blvk turn off showOnlyWithDuration
      this is a whole day, multiday event
      duration is tor a short term event
        blvk @sdetweil
        @sdetweil said in Cant use showEnd icloud cal:
        set to false, no changes, do you need some more informations i can share?
          sdetweil @blvk
          @blvk sorry, didn’t think it thru
          because your events are full day (no time)
          DTSTART;VALUE=DATE:20241216
          there is no duration
          we do not show end for full day events
          we could, but don’t
          if (this.config.showEnd) {
          	if (this.config.showEndsOnlyWithDuration && event.startDate === event.endDate) {
          	    // no duration here, don't display end
          	} else {
          //----- we do this
          		timeWrapper.innerHTML += "-";
          			timeWrapper.innerHTML += CalendarUtils.capFirst(moment(event.endDate, "x").format(this.config.dateEndFormat));
          	// For full day events we use the fullDayEventDateFormat
          	if (event.fullDayEvent) {
                  	//subtract one second so that fullDayEvents end at 23:59:59, and not at 0:00:00 on the next day
          	       event.endDate -= ONE_SECOND;
          /// then change the display of both to just the start
                         timeWrapper.innerHTML = CalendarUtils.capFirst(moment(event.startDate, "x").format(this.config.fullDayEventDateFormat));
            sdetweil @blvk
            @blvk I just added this to the next release calendar
            you can get my test version and try it out
            see https://forum.magicmirror.builders/topic/19070/call-for-testers-updated-calendar-module
            if showEnd:true, and start date is different then end date, then
            add end date on using dateEndFormat
            — this (dateEndFormat) might collide with dateEndFormat on events WITH time… need feedback
            • evroomE Offline
              evroom @sdetweil
              At first sight I do not like it too much.
              Daily repeating events have an end time now that does not make really sense (23:59) and the Holliday end time only makes sense when the dateEndFormat is extended to see the date.
              And that makes it pretty crowded in the date/time column.
              IMHO :-)
              timeFormat: "absolute",
              showEnd: true,
              showEndsOnlyWithDuration: true,
              //dateEndFormat: "HH:mm",
              dateEndFormat: "dddd MMM D - HH:mm",
              I currently have
              but
              showEndsOnlyWithDuration: false,
              does not seem to do anything.
              showEnd: false,
              //dateEndFormat: "dddd MMM D - HH:mm",
              Regards,
              E.J.
              MagicMirror version: 2.37.0
                sdetweil @evroom
                @evroom thanks… that was what I was afraid of
                can you change line calendar.js 439 to be like this, use the FullDayEventFormat, so not different that begin
                							timeWrapper.innerHTML += CalendarUtils.capFirst(moment(event.endDate, "x").format(this.config.fullDayEventDateFormat));
                • evroomE Offline
                  evroom @sdetweil
                  calendar.js
                  ~/MagicMirror/modules/default/calendar/calendar.js
                  showEnd: true,
                  showEnd: false,
                    sdetweil @evroom
                    @evroom that looks better , is it better?
                    only w duration only applies to date-time events
                    but same day shouldnt have add end show (but i compared full internal date value, which includes a utc time value which would be different)
                    its ‘more’ consistent with end showing, but illogical to me to have start and end on the same day
                      @evroom
                      so try this , new line 437. only show end if the end date is different than the start date
                      if (this.config.showEnd && moment(event.startDate,"x").format("YYYYMMDD") !== moment(event.endDate,"x").format("YYYYMMDD")) {
                      • evroomE Offline
                        evroom @sdetweil
                        In short, I think it is looking better now.
                        To make full profit from ‘showEnd: true’ one should use a ‘dateEndFormat’ that makes sense, not like mine.
                        The only thing that I notice, is that ‘showEndsOnlyWithDuration’ is not doing anything.
                        In my examples I only see a change when I toggle ‘showEnd’.
                        urgency: 0,
                        dateFormat: "dddd MMM D - HH:mm",
                        fullDayEventDateFormat: "dddd MMM D",
                        showEnd: true,
                        getRelative: 0,
                        showEnd: true,
                        showEnd: false,
                        showEnd: false,
                          sdetweil @evroom
                          @evroom
                          you don’t have a full day event across multiple days NOT repeating
                          example
                                vacation mon-friday allday 1 NON-repeating event
                          repeating are handled differently
                          show start, but not repeating end
                          with sliceMultiDayEvents:true, // for REPEATING only (1 day event 5 times)
                             see each day of repeating
                                 1/5
                                 2/5
                                 3/5
                                 5/5
                          then next day
                                 2/5
                                 etc
                          @evroom said in Cant use showEnd icloud cal:
                          sorry, don’t understand this, I thought prior note said TIME display on fullday events was wrong… endFormat is for events with time (IMHO)
                          ok, the code here is
                          					// Add end time if showEnd
                          						} else {
                          BUT,
                          immediately AFTER this is the test for fullday events, which changes the timeWrapper
                          So, this would ONLY apply
                          not-fullday
                          not repeating
                          event start on Monday:20:00:end on Tuesday:6:00 sleep over at Bobs
                          I see the bug… testing 2 things to together
                            @evroom
                            change lines 415 —
                            				if (this.config.timeFormat === "absolute") {
                            					// Use dateFormat
                            					timeWrapper.innerHTML = CalendarUtils.capFirst(moment(event.startDate, "x").format(this.config.dateFormat));
                            						if (event.startDate !== event.endDate) {
                            							//  duration here, display end if requested
                            						  if(this.config.showEndsOnlyWithDuration){
                            • evroomE Offline
                              evroom @sdetweil
                              Sorry, do not want to cause confusion.
                              One should probably not do a quick test right after a full working day:-)
                              The number of test cases seems endless.
                              Do I remove the earlier changes ((lines 437 and 439) before changing line 415 ?
                                sdetweil @evroom
                                indeed… calendar is a tricky beast
                                no… the end of this change is just before the prior , match up that last line
                                working on getting this into the update now, creating testcases!
                                  I have posted an updated fixcaldates2
                                  this also resolves the showEndsOnlyWithDuration
                                  and adds support for showEnd:true with full day events (non-repeating)
                                  like vacation mon-fri, all day
                                  just
                                  git pull
                                  to update…
                                  this is my fork, not the official pull request at this time
                                  if you are just getting this for the 1st time. do
                                  git clone https://github.com/sdetweil/MagicMirror.git newmm
                                  cd newmm
                                  git checkout fixcaldates2
                                  npm run install-mm
                                  • evroomE Offline
                                    evroom @sdetweil
                                    Sam,
                                    The option showEndsOnlyWithDuration is not described yet on https://docs.magicmirror.builders/modules/calendar.html.
                                    The interaction / dependancy with showEnd also needs to be documented.
                                    I do not know if documentation issues also can / should be done on https://github.com/MagicMirrorOrg/MagicMirror.
                                    evroomE S 2 Replies Last reply Reply Quote 0
                                    • evroomE Offline
                                      evroom @evroom
                                      Sam,
                                      Whilst testing your last changes, I sort of see a need for a new date format parameter.
                                      For an event with duration, spanning multiple days.
                                      E.g. spanningDayEventDateFormat.
                                      [TestCal: TIMESPAN_HOLIDAY]
                                      BEGIN:VEVENT
                                      DTSTART:20241125T110000Z
                                      DTEND:20241127T160000Z
                                      DTSTAMP:20241026T091719Z
                                      UID:1lk06o70p9bp21ln3pdfda4ng0@google.com
                                      CREATED:20241026T090035Z
                                      LAST-MODIFIED:20241026T090035Z
                                      SEQUENCE:0
                                      STATUS:CONFIRMED
                                      SUMMARY:TestCal: TIMESPAN_HOLIDAY
                                      TRANSP:OPAQUE
                                      END:VEVENT
                                      For events with duration. spanning one night, like an overnight flight, it is not really necessary, but not really bad either.
                                      [TestCal: OVERNIGHT_FLIGH]
                                      BEGIN:VEVENT
                                      DTSTART:20241202T190000Z
                                      DTEND:20241203T030000Z
                                      UID:0s4flhmaf7p6q5atemshns4upp@google.com
                                      CREATED:20241026T090148Z
                                      LAST-MODIFIED:20241026T090215Z
                                      SEQUENCE:0
                                      STATUS:CONFIRMED
                                      SUMMARY:TestCal: OVERNIGHT_FLIGHT
                                      TRANSP:OPAQUE
                                      END:VEVENT
                                      The reasoning behind it is following:
                                      For a ‘normal’, single, event I am not really interested in the full end date format (dateEndFormat).
                                      That is why I normally use dateEndFormat: "HH:mm".
                                      But for an event with duration, spanning multiple days, the setting dateEndFormat: "ddd MMM D - HH:mm" makes more sense.
                                      dateFormat: “ddd MMM D - HH:mm”
                                      dateEndFormat: “HH:mm”
                                      fullDayEventDateFormat: “ddd MMM D”
                                      [good for normal events, ‘bad’ for spanning events]:
                                      dateEndFormat: “ddd MMM D - HH:mm”
                                      [‘bad’ for normal events, good for spanning events]:
                                      I hope I could explain it well enough.
                                      And that it makes sense. :-)
                                      Best regards,
                                      E.J.
                                        sdetweil @evroom
                                        @evroom there is a documentation repo
                                        • evroomE Offline
                                          evroom @sdetweil
                                          Found it:
                                          https://github.com/MagicMirrorOrg/MagicMirror-Documentation/issues
                                          • evroomE Offline
                                            evroom @evroom
                                            Found it:
                                            Opened:
                                            https://github.com/MagicMirrorOrg/MagicMirror-Documentation/issues/266
                                            S 2 Replies Last reply Reply Quote 1
