    Cant use showEnd icloud cal
    30 Posts 3 Posters 6.5k Views 3 Watching
      sdetweil @blvk
      @blvk sorry, didn’t think it thru
      because your events are full day (no time)
      DTSTART;VALUE=DATE:20241216
      there is no duration
      we do not show end for full day events
      we could, but don’t
      if (this.config.showEnd) {
      	if (this.config.showEndsOnlyWithDuration && event.startDate === event.endDate) {
      	    // no duration here, don't display end
      	} else {
      //----- we do this
      		timeWrapper.innerHTML += "-";
      			timeWrapper.innerHTML += CalendarUtils.capFirst(moment(event.endDate, "x").format(this.config.dateEndFormat));
      	// For full day events we use the fullDayEventDateFormat
      	if (event.fullDayEvent) {
              	//subtract one second so that fullDayEvents end at 23:59:59, and not at 0:00:00 on the next day
      	       event.endDate -= ONE_SECOND;
      /// then change the display of both to just the start
                     timeWrapper.innerHTML = CalendarUtils.capFirst(moment(event.startDate, "x").format(this.config.fullDayEventDateFormat));
        sdetweil @blvk
        @blvk I just added this to the next release calendar
        you can get my test version and try it out
        see https://forum.magicmirror.builders/topic/19070/call-for-testers-updated-calendar-module
        if showEnd:true, and start date is different then end date, then
        add end date on using dateEndFormat
        — this (dateEndFormat) might collide with dateEndFormat on events WITH time… need feedback
        evroomE 1 Reply Last reply
        • evroomE
          evroom @sdetweil
          At first sight I do not like it too much.
          Daily repeating events have an end time now that does not make really sense (23:59) and the Holliday end time only makes sense when the dateEndFormat is extended to see the date.
          And that makes it pretty crowded in the date/time column.
          IMHO :-)
          timeFormat: "absolute",
          showEnd: true,
          showEndsOnlyWithDuration: true,
          //dateEndFormat: "HH:mm",
          dateEndFormat: "dddd MMM D - HH:mm",
          I currently have
          but
          showEndsOnlyWithDuration: false,
          does not seem to do anything.
          showEnd: false,
          //dateEndFormat: "dddd MMM D - HH:mm",
          Regards,
          E.J.
          MagicMirror version: 2.37.0
            sdetweil @evroom
            @evroom thanks… that was what I was afraid of
            can you change line calendar.js 439 to be like this, use the FullDayEventFormat, so not different that begin
            							timeWrapper.innerHTML += CalendarUtils.capFirst(moment(event.endDate, "x").format(this.config.fullDayEventDateFormat));
            • evroomE
              evroom @sdetweil
              @sdetweil said in Cant use showEnd icloud cal:
              calendar.js
              ~/MagicMirror/modules/default/calendar/calendar.js
              showEnd: true,
              showEnd: false,
                sdetweil @evroom
                @evroom that looks better , is it better?
                only w duration only applies to date-time events
                but same day shouldnt have add end show (but i compared full internal date value, which includes a utc time value which would be different)
                its ‘more’ consistent with end showing, but illogical to me to have start and end on the same day
                  @evroom
                  so try this , new line 437. only show end if the end date is different than the start date
                  if (this.config.showEnd && moment(event.startDate,"x").format("YYYYMMDD") !== moment(event.endDate,"x").format("YYYYMMDD")) {
                  • evroomE
                    evroom @sdetweil
                    In short, I think it is looking better now.
                    To make full profit from ‘showEnd: true’ one should use a ‘dateEndFormat’ that makes sense, not like mine.
                    The only thing that I notice, is that ‘showEndsOnlyWithDuration’ is not doing anything.
                    In my examples I only see a change when I toggle ‘showEnd’.
                    urgency: 0,
                    dateFormat: "dddd MMM D - HH:mm",
                    fullDayEventDateFormat: "dddd MMM D",
                    showEnd: true,
                    getRelative: 0,
                    showEnd: true,
                    showEnd: false,
                    showEnd: false,
                      sdetweil @evroom
                      @evroom
                      you don’t have a full day event across multiple days NOT repeating
                      example
                            vacation mon-friday allday 1 NON-repeating event
                      repeating are handled differently
                      show start, but not repeating end
                      with sliceMultiDayEvents:true, // for REPEATING only (1 day event 5 times)
                         see each day of repeating
                             1/5
                             2/5
                             3/5
                             5/5
                      then next day
                             2/5
                             etc
                      @evroom said in Cant use showEnd icloud cal:
                      sorry, don’t understand this, I thought prior note said TIME display on fullday events was wrong… endFormat is for events with time (IMHO)
                      ok, the code here is
                      					// Add end time if showEnd
                      						} else {
                      BUT,
                      immediately AFTER this is the test for fullday events, which changes the timeWrapper
                      So, this would ONLY apply
                      not-fullday
                      not repeating
                      event start on Monday:20:00:end on Tuesday:6:00 sleep over at Bobs
                      I see the bug… testing 2 things to together
                        @evroom
                        change lines 415 —
                        				if (this.config.timeFormat === "absolute") {
                        					// Use dateFormat
                        					timeWrapper.innerHTML = CalendarUtils.capFirst(moment(event.startDate, "x").format(this.config.dateFormat));
                        						if (event.startDate !== event.endDate) {
                        							//  duration here, display end if requested
                        						  if(this.config.showEndsOnlyWithDuration){
                        • evroomE
                          evroom @sdetweil
                          Sorry, do not want to cause confusion.
                          One should probably not do a quick test right after a full working day:-)
                          The number of test cases seems endless.
                          Do I remove the earlier changes ((lines 437 and 439) before changing line 415 ?
                            sdetweil @evroom
                            indeed… calendar is a tricky beast
                            no… the end of this change is just before the prior , match up that last line
                            working on getting this into the update now, creating testcases!
                              I have posted an updated fixcaldates2
                              this also resolves the showEndsOnlyWithDuration
                              and adds support for showEnd:true with full day events (non-repeating)
                              like vacation mon-fri, all day
                              just
                              git pull
                              to update…
                              this is my fork, not the official pull request at this time
                              if you are just getting this for the 1st time. do
                              git clone https://github.com/sdetweil/MagicMirror.git newmm
                              cd newmm
                              git checkout fixcaldates2
                              npm run install-mm
                              • evroomE
                                evroom @sdetweil
                                Sam,
                                The option showEndsOnlyWithDuration is not described yet on https://docs.magicmirror.builders/modules/calendar.html.
                                The interaction / dependancy with showEnd also needs to be documented.
                                I do not know if documentation issues also can / should be done on https://github.com/MagicMirrorOrg/MagicMirror.
                                evroomE S 2 Replies Last reply
                                • evroomE
                                  evroom @evroom
                                  Sam,
                                  Whilst testing your last changes, I sort of see a need for a new date format parameter.
                                  For an event with duration, spanning multiple days.
                                  E.g. spanningDayEventDateFormat.
                                  [TestCal: TIMESPAN_HOLIDAY]
                                  BEGIN:VEVENT
                                  DTSTART:20241125T110000Z
                                  DTEND:20241127T160000Z
                                  DTSTAMP:20241026T091719Z
                                  UID:1lk06o70p9bp21ln3pdfda4ng0@google.com
                                  CREATED:20241026T090035Z
                                  LAST-MODIFIED:20241026T090035Z
                                  SEQUENCE:0
                                  STATUS:CONFIRMED
                                  SUMMARY:TestCal: TIMESPAN_HOLIDAY
                                  TRANSP:OPAQUE
                                  END:VEVENT
                                  For events with duration. spanning one night, like an overnight flight, it is not really necessary, but not really bad either.
                                  [TestCal: OVERNIGHT_FLIGH]
                                  BEGIN:VEVENT
                                  DTSTART:20241202T190000Z
                                  DTEND:20241203T030000Z
                                  UID:0s4flhmaf7p6q5atemshns4upp@google.com
                                  CREATED:20241026T090148Z
                                  LAST-MODIFIED:20241026T090215Z
                                  SEQUENCE:0
                                  STATUS:CONFIRMED
                                  SUMMARY:TestCal: OVERNIGHT_FLIGHT
                                  TRANSP:OPAQUE
                                  END:VEVENT
                                  The reasoning behind it is following:
                                  For a ‘normal’, single, event I am not really interested in the full end date format (dateEndFormat).
                                  That is why I normally use dateEndFormat: "HH:mm".
                                  But for an event with duration, spanning multiple days, the setting dateEndFormat: "ddd MMM D - HH:mm" makes more sense.
                                  dateFormat: “ddd MMM D - HH:mm”
                                  dateEndFormat: “HH:mm”
                                  fullDayEventDateFormat: “ddd MMM D”
                                  [good for normal events, ‘bad’ for spanning events]:
                                  dateEndFormat: “ddd MMM D - HH:mm”
                                  [‘bad’ for normal events, good for spanning events]:
                                  I hope I could explain it well enough.
                                  And that it makes sense. :-)
                                  Best regards,
                                  E.J.
                                    sdetweil @evroom
                                    @evroom there is a documentation repo
                                    • evroomE
                                      evroom @sdetweil
                                      Found it:
                                      https://github.com/MagicMirrorOrg/MagicMirror-Documentation/issues
                                      • evroomE
                                        evroom @evroom
                                        Found it:
                                        Opened:
                                        https://github.com/MagicMirrorOrg/MagicMirror-Documentation/issues/266
                                          sdetweil @evroom
                                          @evroom and thinking about it, i think i just messed up the implementation (Which was broken already)
                                          showEnd:true
                                          should show the end for all events fullday or not
                                          showEndsOnlyWithDuration:true should NOT show the end for full day events but DO show end for others ( because of showEnd:true)
                                            sdetweil @evroom
                                            @evroom i replied there
