    Cant use showEnd icloud cal
    30 Posts 3 Posters 6.0k Views 3 Watching
      blvk
      Hey,
      hopefully you can help me. If already tryed to try this fix but it dont work for me.
      https://github.com/MagicMirrorOrg/MagicMirror/issues/2629
      My problem, i got a Calendar form my icloud cal. I already got every informations i want.
      This is my ics
      BEGIN:VEVENT
      CREATED:20240922T101541Z
      DTEND;VALUE=DATE:20250104
      DTSTAMP:20240922T101542Z
      DTSTART;VALUE=DATE:20241216
      LAST-MODIFIED:20240922T101541Z
      SEQUENCE:0
      SUMMARY:Urlaub Jan
      UID:66E9674A-B97F-41DC-B25E-DE2D2C4DFF3B
      URL;VALUE=URI:
      X-APPLE-CREATOR-IDENTITY:com.apple.mobilecal
      X-APPLE-CREATOR-TEAM-IDENTITY:0000000000
      TRANSP:OPAQUE
      END:VEVENT
                              "module": "calendar",
                              "header": "Urlaub",
                              "position": "top_left",
                              "config": {
                                      showEnd: true,
                                      showEndsOnlyWithDuration: true,
                                      maximumEntries: 8,
                                      "calendars": [
                                                      "symbol": "calendar",
                                                      "url": "http://192.168.178.3:8080/modules/calendars/3920BBAD-278C-4EAB-AF16-9442B82D2459.ics"
      The showEnd dont work, i got only the start date of my holidays.
      What do i wrong?
      • evroomE Offline
        evroom @sdetweil
        My Google Calendar remark was more aimed at the basic.ics we get from it.
        I see now it added an unnecessary discussion.
        However it did take me some time to find out that the screen you showed is only seen after clicking the More Options button; my bad.
        Your evaluation of showEnd and showEndsOnlyWithDuration is quite useful.
        Btw, one time in the Dutch parliament there was a big confusion about voting for something.
        If you do not want XXX, then vote yes, if you want XXX then vote no.
        Of course this went wrong.
        Concluding: all my tests passed, meaning it works as designed.
        I will raise an issue for a feature request, but you can either reject it or put it on the bottom of your list of todo’s.
        MagicMirror version: 2.37.0
          sdetweil @blvk
          @blvk also need
          tineFornat:"absolute"
            blvk @sdetweil
            @sdetweil said in Cant use showEnd icloud cal:
            @blvk also need
            Nothing changed
              sdetweil @blvk
              @blvk turn off showOnlyWithDuration
              this is a whole day, multiday event
              duration is tor a short term event
                blvk @sdetweil
                set to false, no changes, do you need some more informations i can share?
                  sdetweil @blvk
                  @blvk sorry, didn’t think it thru
                  because your events are full day (no time)
                  there is no duration
                  we do not show end for full day events
                  we could, but don’t
                  if (this.config.showEnd) {
                  	if (this.config.showEndsOnlyWithDuration && event.startDate === event.endDate) {
                  	    // no duration here, don't display end
                  	} else {
                  //----- we do this
                  		timeWrapper.innerHTML += "-";
                  			timeWrapper.innerHTML += CalendarUtils.capFirst(moment(event.endDate, "x").format(this.config.dateEndFormat));
                  	// For full day events we use the fullDayEventDateFormat
                  	if (event.fullDayEvent) {
                          	//subtract one second so that fullDayEvents end at 23:59:59, and not at 0:00:00 on the next day
                  	       event.endDate -= ONE_SECOND;
                  /// then change the display of both to just the start
                                 timeWrapper.innerHTML = CalendarUtils.capFirst(moment(event.startDate, "x").format(this.config.fullDayEventDateFormat));
                    sdetweil @blvk
                    @blvk I just added this to the next release calendar
                    you can get my test version and try it out
                    see https://forum.magicmirror.builders/topic/19070/call-for-testers-updated-calendar-module
                    if showEnd:true, and start date is different then end date, then
                    add end date on using dateEndFormat
                    — this (dateEndFormat) might collide with dateEndFormat on events WITH time… need feedback
                    • evroomE Offline
                      evroom @sdetweil
                      At first sight I do not like it too much.
                      Daily repeating events have an end time now that does not make really sense (23:59) and the Holliday end time only makes sense when the dateEndFormat is extended to see the date.
                      And that makes it pretty crowded in the date/time column.
                      IMHO :-)
                      timeFormat: "absolute",
                      showEnd: true,
                      //dateEndFormat: "HH:mm",
                      dateEndFormat: "dddd MMM D - HH:mm",
                      I currently have
                      but
                      showEndsOnlyWithDuration: false,
                      does not seem to do anything.
                      showEnd: false,
                      //dateEndFormat: "dddd MMM D - HH:mm",
                      Regards,
                      E.J.
                        sdetweil @evroom
                        @evroom thanks… that was what I was afraid of
                        can you change line calendar.js 439 to be like this, use the FullDayEventFormat, so not different that begin
                        							timeWrapper.innerHTML += CalendarUtils.capFirst(moment(event.endDate, "x").format(this.config.fullDayEventDateFormat));
                        • evroomE Offline
                          evroom @sdetweil
                          calendar.js
                          ~/MagicMirror/modules/default/calendar/calendar.js
                          showEnd: true,
                          showEnd: false,
                            sdetweil @evroom
                            @evroom that looks better , is it better?
                            only w duration only applies to date-time events
                            but same day shouldnt have add end show (but i compared full internal date value, which includes a utc time value which would be different)
                            its ‘more’ consistent with end showing, but illogical to me to have start and end on the same day
                              @evroom
                              so try this , new line 437. only show end if the end date is different than the start date
                              if (this.config.showEnd && moment(event.startDate,"x").format("YYYYMMDD") !== moment(event.endDate,"x").format("YYYYMMDD")) {
                              • evroomE Offline
                                evroom @sdetweil
                                In short, I think it is looking better now.
                                To make full profit from ‘showEnd: true’ one should use a ‘dateEndFormat’ that makes sense, not like mine.
                                The only thing that I notice, is that ‘showEndsOnlyWithDuration’ is not doing anything.
                                In my examples I only see a change when I toggle ‘showEnd’.
                                urgency: 0,
                                dateFormat: "dddd MMM D - HH:mm",
                                fullDayEventDateFormat: "dddd MMM D",
                                showEnd: true,
                                getRelative: 0,
                                showEnd: true,
                                showEnd: false,
                                showEnd: false,
                                  sdetweil @evroom
                                  @evroom
                                  you don’t have a full day event across multiple days NOT repeating
                                  example
                                        vacation mon-friday allday 1 NON-repeating event
                                  repeating are handled differently
                                  show start, but not repeating end
                                  with sliceMultiDayEvents:true, // for REPEATING only (1 day event 5 times)
                                     see each day of repeating
                                         1/5
                                         2/5
                                         3/5
                                         5/5
                                  then next day
                                         2/5
                                         etc
                                  @evroom said in Cant use showEnd icloud cal:
                                  sorry, don’t understand this, I thought prior note said TIME display on fullday events was wrong… endFormat is for events with time (IMHO)
                                  ok, the code here is
                                  					// Add end time if showEnd
                                  						} else {
                                  BUT,
                                  immediately AFTER this is the test for fullday events, which changes the timeWrapper
                                  So, this would ONLY apply
                                  not-fullday
                                  not repeating
                                  event start on Monday:20:00:end on Tuesday:6:00 sleep over at Bobs
                                  I see the bug… testing 2 things to together
                                    @evroom
                                    change lines 415 —
                                    				if (this.config.timeFormat === "absolute") {
                                    					// Use dateFormat
                                    					timeWrapper.innerHTML = CalendarUtils.capFirst(moment(event.startDate, "x").format(this.config.dateFormat));
                                    						if (event.startDate !== event.endDate) {
                                    							//  duration here, display end if requested
                                    						  if(this.config.showEndsOnlyWithDuration){
                                    • evroomE Offline
                                      evroom @sdetweil
                                      Sorry, do not want to cause confusion.
                                      One should probably not do a quick test right after a full working day:-)
                                      The number of test cases seems endless.
                                      Do I remove the earlier changes ((lines 437 and 439) before changing line 415 ?
                                        sdetweil @evroom
                                        indeed… calendar is a tricky beast
                                        no… the end of this change is just before the prior , match up that last line
                                        working on getting this into the update now, creating testcases!
                                          I have posted an updated fixcaldates2
                                          this also resolves the showEndsOnlyWithDuration
                                          and adds support for showEnd:true with full day events (non-repeating)
                                          like vacation mon-fri, all day
                                          just
                                          git pull
                                          to update…
                                          this is my fork, not the official pull request at this time
                                          if you are just getting this for the 1st time. do
                                          git clone https://github.com/sdetweil/MagicMirror.git newmm
                                          cd newmm
                                          git checkout fixcaldates2
                                          npm run install-mm
                                          • evroomE Offline
                                            evroom @sdetweil
                                            Sam,
                                            The option showEndsOnlyWithDuration is not described yet on https://docs.magicmirror.builders/modules/calendar.html.
                                            The interaction / dependancy with showEnd also needs to be documented.
                                            I do not know if documentation issues also can / should be done on https://github.com/MagicMirrorOrg/MagicMirror.
                                            evroomE S 2 Replies Last reply Reply Quote 0
                                            • evroomE Offline
                                              evroom @evroom
                                              Sam,
                                              Whilst testing your last changes, I sort of see a need for a new date format parameter.
                                              For an event with duration, spanning multiple days.
                                              E.g. spanningDayEventDateFormat.
                                              [TestCal: TIMESPAN_HOLIDAY]
                                              BEGIN:VEVENT
                                              DTSTART:20241125T110000Z
                                              DTEND:20241127T160000Z
                                              DTSTAMP:20241026T091719Z
                                              UID:1lk06o70p9bp21ln3pdfda4ng0@google.com
                                              CREATED:20241026T090035Z
                                              LAST-MODIFIED:20241026T090035Z
                                              SEQUENCE:0
                                              STATUS:CONFIRMED
                                              SUMMARY:TestCal: TIMESPAN_HOLIDAY
                                              TRANSP:OPAQUE
                                              END:VEVENT
                                              For events with duration. spanning one night, like an overnight flight, it is not really necessary, but not really bad either.
                                              [TestCal: OVERNIGHT_FLIGH]
                                              BEGIN:VEVENT
                                              DTSTART:20241202T190000Z
                                              DTEND:20241203T030000Z
                                              UID:0s4flhmaf7p6q5atemshns4upp@google.com
                                              CREATED:20241026T090148Z
                                              LAST-MODIFIED:20241026T090215Z
                                              SEQUENCE:0
                                              STATUS:CONFIRMED
                                              SUMMARY:TestCal: OVERNIGHT_FLIGHT
                                              TRANSP:OPAQUE
                                              END:VEVENT
                                              The reasoning behind it is following:
                                              For a ‘normal’, single, event I am not really interested in the full end date format (dateEndFormat).
                                              That is why I normally use dateEndFormat: "HH:mm".
                                              But for an event with duration, spanning multiple days, the setting dateEndFormat: "ddd MMM D - HH:mm" makes more sense.
                                              dateFormat: “ddd MMM D - HH:mm”
                                              dateEndFormat: “HH:mm”
                                              fullDayEventDateFormat: “ddd MMM D”
                                              [good for normal events, ‘bad’ for spanning events]:
                                              dateEndFormat: “ddd MMM D - HH:mm”
                                              [‘bad’ for normal events, good for spanning events]:
                                              I hope I could explain it well enough.
                                              And that it makes sense. :-)
                                              Best regards,
                                              E.J.
