    Cant use showEnd icloud cal
    30 Posts 3 Posters 4.0k Views 3 Watching
      sdetweil @blvk
      @blvk turn off showOnlyWithDuration
      this is a whole day, multiday event
      duration is tor a short term event
        blvk @sdetweil
        @sdetweil said in Cant use showEnd icloud cal:
        set to false, no changes, do you need some more informations i can share?
          sdetweil @blvk
          @blvk sorry, didn’t think it thru
          because your events are full day (no time)
          DTSTART;VALUE=DATE:20241216
          there is no duration
          we do not show end for full day events
          we could, but don’t
          if (this.config.showEnd) {
          	if (this.config.showEndsOnlyWithDuration && event.startDate === event.endDate) {
          	    // no duration here, don't display end
          	} else {
          //----- we do this
          		timeWrapper.innerHTML += "-";
          			timeWrapper.innerHTML += CalendarUtils.capFirst(moment(event.endDate, "x").format(this.config.dateEndFormat));
          	// For full day events we use the fullDayEventDateFormat
          	if (event.fullDayEvent) {
                  	//subtract one second so that fullDayEvents end at 23:59:59, and not at 0:00:00 on the next day
          	       event.endDate -= ONE_SECOND;
          /// then change the display of both to just the start
                         timeWrapper.innerHTML = CalendarUtils.capFirst(moment(event.startDate, "x").format(this.config.fullDayEventDateFormat));
            sdetweil @blvk
            @blvk I just added this to the next release calendar
            you can get my test version and try it out
            see https://forum.magicmirror.builders/topic/19070/call-for-testers-updated-calendar-module
            if showEnd:true, and start date is different then end date, then
            add end date on using dateEndFormat
            — this (dateEndFormat) might collide with dateEndFormat on events WITH time… need feedback
            • evroomE Offline
              evroom @sdetweil
              At first sight I do not like it too much.
              Daily repeating events have an end time now that does not make really sense (23:59) and the Holliday end time only makes sense when the dateEndFormat is extended to see the date.
              And that makes it pretty crowded in the date/time column.
              IMHO :-)
              timeFormat: "absolute",
              showEnd: true,
              showEndsOnlyWithDuration: true,
              //dateEndFormat: "HH:mm",
              dateEndFormat: "dddd MMM D - HH:mm",
              I currently have
              but
              showEndsOnlyWithDuration: false,
              does not seem to do anything.
              showEnd: false,
              //dateEndFormat: "dddd MMM D - HH:mm",
              Regards,
              E.J.
              MagicMirror version: 2.33.0
              Test environment:
              MagicMirror version: v2.33.0
                sdetweil @evroom
                @evroom thanks… that was what I was afraid of
                can you change line calendar.js 439 to be like this, use the FullDayEventFormat, so not different that begin
                							timeWrapper.innerHTML += CalendarUtils.capFirst(moment(event.endDate, "x").format(this.config.fullDayEventDateFormat));
                • evroomE Offline
                  evroom @sdetweil
                  calendar.js
                  ~/MagicMirror/modules/default/calendar/calendar.js
                  showEnd: true,
                  showEnd: false,
                  Test environment:
                    sdetweil @evroom
                    @evroom that looks better , is it better?
                    only w duration only applies to date-time events
                    but same day shouldnt have add end show (but i compared full internal date value, which includes a utc time value which would be different)
                    its ‘more’ consistent with end showing, but illogical to me to have start and end on the same day
                      @evroom
                      so try this , new line 437. only show end if the end date is different than the start date
                      if (this.config.showEnd && moment(event.startDate,"x").format("YYYYMMDD") !== moment(event.endDate,"x").format("YYYYMMDD")) {
                      • evroomE Offline
                        evroom @sdetweil
                        In short, I think it is looking better now.
                        To make full profit from ‘showEnd: true’ one should use a ‘dateEndFormat’ that makes sense, not like mine.
                        The only thing that I notice, is that ‘showEndsOnlyWithDuration’ is not doing anything.
                        In my examples I only see a change when I toggle ‘showEnd’.
                        urgency: 0,
                        dateFormat: "dddd MMM D - HH:mm",
                        fullDayEventDateFormat: "dddd MMM D",
                        showEnd: true,
                        getRelative: 0,
                        showEnd: true,
                        showEnd: false,
                        showEnd: false,
                        Test environment:
