    Cant use showEnd icloud cal
    30 Posts 3 Posters 6.0k Views 3 Watching
    • evroomE Offline
      evroom @evroom
      Sam,
      Whilst testing your last changes, I sort of see a need for a new date format parameter.
      For an event with duration, spanning multiple days.
      E.g. spanningDayEventDateFormat.
      [TestCal: TIMESPAN_HOLIDAY]
      BEGIN:VEVENT
      DTSTART:20241125T110000Z
      DTEND:20241127T160000Z
      DTSTAMP:20241026T091719Z
      UID:1lk06o70p9bp21ln3pdfda4ng0@google.com
      CREATED:20241026T090035Z
      LAST-MODIFIED:20241026T090035Z
      SEQUENCE:0
      STATUS:CONFIRMED
      SUMMARY:TestCal: TIMESPAN_HOLIDAY
      TRANSP:OPAQUE
      END:VEVENT
      For events with duration. spanning one night, like an overnight flight, it is not really necessary, but not really bad either.
      [TestCal: OVERNIGHT_FLIGH]
      BEGIN:VEVENT
      DTSTART:20241202T190000Z
      DTEND:20241203T030000Z
      UID:0s4flhmaf7p6q5atemshns4upp@google.com
      CREATED:20241026T090148Z
      LAST-MODIFIED:20241026T090215Z
      SEQUENCE:0
      STATUS:CONFIRMED
      SUMMARY:TestCal: OVERNIGHT_FLIGHT
      TRANSP:OPAQUE
      END:VEVENT
      The reasoning behind it is following:
      For a ‘normal’, single, event I am not really interested in the full end date format (dateEndFormat).
      That is why I normally use dateEndFormat: "HH:mm".
      But for an event with duration, spanning multiple days, the setting dateEndFormat: "ddd MMM D - HH:mm" makes more sense.
      dateFormat: “ddd MMM D - HH:mm”
      dateEndFormat: “HH:mm”
      fullDayEventDateFormat: “ddd MMM D”
      [good for normal events, ‘bad’ for spanning events]:
      dateEndFormat: “ddd MMM D - HH:mm”
      [‘bad’ for normal events, good for spanning events]:
      I hope I could explain it well enough.
      And that it makes sense. :-)
      Best regards,
      E.J.
      MagicMirror version: 2.37.0
        sdetweil @evroom
        @evroom there is a documentation repo
        • evroomE Offline
          evroom @sdetweil
          @sdetweil said in Cant use showEnd icloud cal:
          Found it:
          https://github.com/MagicMirrorOrg/MagicMirror-Documentation/issues
          • evroomE Offline
            evroom @evroom
            @evroom said in Cant use showEnd icloud cal:
            Found it:
            Opened:
            https://github.com/MagicMirrorOrg/MagicMirror-Documentation/issues/266
            S 2 Replies Last reply Reply Quote 1
              sdetweil @evroom
              @evroom and thinking about it, i think i just messed up the implementation (Which was broken already)
              showEnd:true
              should show the end for all events fullday or not
              showEndsOnlyWithDuration:true should NOT show the end for full day events but DO show end for others ( because of showEnd:true)
                sdetweil @evroom
                @evroom i replied there
                  @evroom I just posted an update to fix showEndsOnlyWithDuration
                  doc added
                  • evroomE Offline
                    evroom @sdetweil
                    Okay, so to recap (me talking to myself :-)):
                    It basically applies to a fullday event that spans multiple days.
                    Because a single fullday event has an equal start and end date.
                    And a fullday reoccurring event is just X times a single fullday event.
                    Google Calendar makes it a bit more difficult to understand the begin and end dates (hence the need to calculate and adjust) :
                    TestCal: SINGLE_FULLDAY_EVENT
                    Thursday, October 31
                    BEGIN:VEVENT
                    DTSTART;VALUE=DATE:20241031
                    DTEND;VALUE=DATE:20241101
                    TestCal: FULLDAY_EVENT_SPANS_3_DAYS
                    November 1 – 3, 2024
                    DTSTART;VALUE=DATE:20241101
                    DTEND;VALUE=DATE:20241104
                    Here a fullday event that spans multiple days:
                    BEGIN:VEVENT
                    DTSTAMP:20241026T152207Z
                    UID:2srults5ctu7t3n4piick00gv8@google.com
                    CREATED:20241026T152154Z
                    LAST-MODIFIED:20241026T152154Z
                    SEQUENCE:0
                    STATUS:CONFIRMED
                    SUMMARY:TestCal: FULLDAY_EVENT_SPANS_3_DAYS
                    TRANSP:TRANSPARENT
                    END:VEVENT
                    ‘prevent’ means: when set to false (default), you will see the end date.
                    When set to true, you will not see the end date.
                    Test with latest updates (git pull on Sat 26 Oct 16:51:00 CEST 2024):
                    showEnd: true.
                    showEndsOnlyWithDuration: false,
                    20241026_TestCal_true_false_new_2.png !
                    showEnd: true.
                    showEndsOnlyWithDuration: true,
                    20241026_TestCal_true_true_new_2.png !
                      sdetweil @evroom
                      @evroom google calendar makes it easy (IMHO), dropdown for recurring/does not repeat. by default events don’t repeat, regardless of their start/end difference
                      correct, applies to multi-day events… cause it if was single day, then it says Saturday or Oct 26. no point displaying SAME end as START
                      prevent
                      in timeFormat:“absolute”,
                      showEnd:true (default false) says DISPLAY END dates/times ALWAYS
                      • for duration events (tuesday from 6pm-8pm) ,
                        • use the dateFormat format string for the START date/time,
                        • use the dateEndFormat format string for the END date/time
                      • for fullDayEvents
                        • use the fullDayEventDateFormat format string, for both start and end-(with my bug fix)
                      showEndsOnlyWithDuration:true (default false), means DISPLAY END dates/TIMES, but ONLY for events with durations… full day events NEVER have duration (even over multiple days)
                      • evroomE Offline
                        evroom @sdetweil
                        My Google Calendar remark was more aimed at the basic.ics we get from it.
                        I see now it added an unnecessary discussion.
                        However it did take me some time to find out that the screen you showed is only seen after clicking the More Options button; my bad.
                        Your evaluation of showEnd and showEndsOnlyWithDuration is quite useful.
                        Btw, one time in the Dutch parliament there was a big confusion about voting for something.
                        If you do not want XXX, then vote yes, if you want XXX then vote no.
                        Of course this went wrong.
                        Concluding: all my tests passed, meaning it works as designed.
                        I will raise an issue for a feature request, but you can either reject it or put it on the bottom of your list of todo’s.
                          sdetweil @evroom
                          @evroom I didn’t pick the property name… just got stuck with fixing its behavior!.. lol
                          your enhancement… thats why we expose the work… have the discussions.
