    Cant use showEnd icloud cal
    30 Posts 3 Posters 6.5k Views 3 Watching
    • evroomE
      evroom @sdetweil
      Sorry, do not want to cause confusion.
      One should probably not do a quick test right after a full working day:-)
      The number of test cases seems endless.
      Do I remove the earlier changes ((lines 437 and 439) before changing line 415 ?
      MagicMirror version: 2.37.0
        sdetweil @evroom
        @evroom said in Cant use showEnd icloud cal:
        indeed… calendar is a tricky beast
        no… the end of this change is just before the prior , match up that last line
        working on getting this into the update now, creating testcases!
          I have posted an updated fixcaldates2
          this also resolves the showEndsOnlyWithDuration
          and adds support for showEnd:true with full day events (non-repeating)
          like vacation mon-fri, all day
          just
          git pull
          to update…
          this is my fork, not the official pull request at this time
          if you are just getting this for the 1st time. do
          git clone https://github.com/sdetweil/MagicMirror.git newmm
          cd newmm
          git checkout fixcaldates2
          npm run install-mm
          evroomE 1 Reply Last reply
          • evroomE
            evroom @sdetweil
            Sam,
            The option showEndsOnlyWithDuration is not described yet on https://docs.magicmirror.builders/modules/calendar.html.
            The interaction / dependancy with showEnd also needs to be documented.
            I do not know if documentation issues also can / should be done on https://github.com/MagicMirrorOrg/MagicMirror.
            evroomE S 2 Replies Last reply
            • evroomE
              evroom @evroom
              Sam,
              Whilst testing your last changes, I sort of see a need for a new date format parameter.
              For an event with duration, spanning multiple days.
              E.g. spanningDayEventDateFormat.
              [TestCal: TIMESPAN_HOLIDAY]
              BEGIN:VEVENT
              DTSTART:20241125T110000Z
              DTEND:20241127T160000Z
              DTSTAMP:20241026T091719Z
              UID:1lk06o70p9bp21ln3pdfda4ng0@google.com
              CREATED:20241026T090035Z
              LAST-MODIFIED:20241026T090035Z
              SEQUENCE:0
              STATUS:CONFIRMED
              SUMMARY:TestCal: TIMESPAN_HOLIDAY
              TRANSP:OPAQUE
              END:VEVENT
              For events with duration. spanning one night, like an overnight flight, it is not really necessary, but not really bad either.
              [TestCal: OVERNIGHT_FLIGH]
              BEGIN:VEVENT
              DTSTART:20241202T190000Z
              DTEND:20241203T030000Z
              UID:0s4flhmaf7p6q5atemshns4upp@google.com
              CREATED:20241026T090148Z
              LAST-MODIFIED:20241026T090215Z
              SEQUENCE:0
              STATUS:CONFIRMED
              SUMMARY:TestCal: OVERNIGHT_FLIGHT
              TRANSP:OPAQUE
              END:VEVENT
              The reasoning behind it is following:
              For a ‘normal’, single, event I am not really interested in the full end date format (dateEndFormat).
              That is why I normally use dateEndFormat: "HH:mm".
              But for an event with duration, spanning multiple days, the setting dateEndFormat: "ddd MMM D - HH:mm" makes more sense.
              dateFormat: “ddd MMM D - HH:mm”
              dateEndFormat: “HH:mm”
              fullDayEventDateFormat: “ddd MMM D”
              [good for normal events, ‘bad’ for spanning events]:
              dateEndFormat: “ddd MMM D - HH:mm”
              [‘bad’ for normal events, good for spanning events]:
              I hope I could explain it well enough.
              And that it makes sense. :-)
              Best regards,
              E.J.
                sdetweil @evroom
                @evroom there is a documentation repo
                • evroomE
                  evroom @sdetweil
                  @sdetweil said in Cant use showEnd icloud cal:
                  Found it:
                  https://github.com/MagicMirrorOrg/MagicMirror-Documentation/issues
                  • evroomE
                    evroom @evroom
                    Found it:
                    Opened:
                    https://github.com/MagicMirrorOrg/MagicMirror-Documentation/issues/266
                      sdetweil @evroom
                      @evroom and thinking about it, i think i just messed up the implementation (Which was broken already)
                      showEnd:true
                      should show the end for all events fullday or not
                      showEndsOnlyWithDuration:true should NOT show the end for full day events but DO show end for others ( because of showEnd:true)
                        sdetweil @evroom
                        @evroom i replied there
                          @evroom I just posted an update to fix showEndsOnlyWithDuration
                          doc added
                          • evroomE
                            evroom @sdetweil
                            Okay, so to recap (me talking to myself :-)):
                            It basically applies to a fullday event that spans multiple days.
                            Because a single fullday event has an equal start and end date.
                            And a fullday reoccurring event is just X times a single fullday event.
                            Google Calendar makes it a bit more difficult to understand the begin and end dates (hence the need to calculate and adjust) :
                            TestCal: SINGLE_FULLDAY_EVENT
                            Thursday, October 31
                            BEGIN:VEVENT
                            DTSTART;VALUE=DATE:20241031
                            DTEND;VALUE=DATE:20241101
                            TestCal: FULLDAY_EVENT_SPANS_3_DAYS
                            November 1 – 3, 2024
                            DTSTART;VALUE=DATE:20241101
                            DTEND;VALUE=DATE:20241104
                            Here a fullday event that spans multiple days:
                            BEGIN:VEVENT
                            DTSTAMP:20241026T152207Z
                            UID:2srults5ctu7t3n4piick00gv8@google.com
                            CREATED:20241026T152154Z
                            LAST-MODIFIED:20241026T152154Z
                            SEQUENCE:0
                            STATUS:CONFIRMED
                            SUMMARY:TestCal: FULLDAY_EVENT_SPANS_3_DAYS
                            TRANSP:TRANSPARENT
                            END:VEVENT
                            ‘prevent’ means: when set to false (default), you will see the end date.
                            When set to true, you will not see the end date.
                            Test with latest updates (git pull on Sat 26 Oct 16:51:00 CEST 2024):
                            showEnd: true.
                            showEndsOnlyWithDuration: false,
                            20241026_TestCal_true_false_new_2.png !
                            showEnd: true.
                            showEndsOnlyWithDuration: true,
                            20241026_TestCal_true_true_new_2.png !
                              sdetweil @evroom
                              @evroom google calendar makes it easy (IMHO), dropdown for recurring/does not repeat. by default events don’t repeat, regardless of their start/end difference
                              correct, applies to multi-day events… cause it if was single day, then it says Saturday or Oct 26. no point displaying SAME end as START
                              prevent
                              in timeFormat:“absolute”,
                              showEnd:true (default false) says DISPLAY END dates/times ALWAYS
                              • for duration events (tuesday from 6pm-8pm) ,
                                • use the dateFormat format string for the START date/time,
                                • use the dateEndFormat format string for the END date/time
                              • for fullDayEvents
                                • use the fullDayEventDateFormat format string, for both start and end-(with my bug fix)
                              showEndsOnlyWithDuration:true (default false), means DISPLAY END dates/TIMES, but ONLY for events with durations… full day events NEVER have duration (even over multiple days)
                              • evroomE
                                evroom @sdetweil
                                My Google Calendar remark was more aimed at the basic.ics we get from it.
                                I see now it added an unnecessary discussion.
                                However it did take me some time to find out that the screen you showed is only seen after clicking the More Options button; my bad.
                                Your evaluation of showEnd and showEndsOnlyWithDuration is quite useful.
                                Btw, one time in the Dutch parliament there was a big confusion about voting for something.
                                If you do not want XXX, then vote yes, if you want XXX then vote no.
                                Of course this went wrong.
                                Concluding: all my tests passed, meaning it works as designed.
                                I will raise an issue for a feature request, but you can either reject it or put it on the bottom of your list of todo’s.
                                  sdetweil @evroom
                                  @evroom I didn’t pick the property name… just got stuck with fixing its behavior!.. lol
                                  your enhancement… thats why we expose the work… have the discussions.
