    new compositor on wayland
    18 Posts 4 Posters 4.8k Views 6 Watching
      starting w oct 27, 2024 ( dated Oct 22) a new compositor (called labwc) was released in an updated bookworm release
      i know my install script is impacted
      see
      https://www.raspberrypi.com/news/a-new-release-of-raspberry-pi-os/
      @bugsounet i know this will impact your stuff too
      bugsounetB 1 Reply Last reply Reply Quote 3
        sdetweil @lxne
        @lxne you can switch back to x11 using raspi-config
        • bugsounetB Offline
          bugsounet Banned @sdetweil
          @sdetweil yes, again more work ;/
          (and more bugs)
            sdetweil @bugsounet
            @bugsounet yes. never ending change
              AND the new releases are using node 23!!!
              false alarm… user didn’t share all the info… manually installed node and got node 23…
              bugsounetB 1 Reply Last reply Reply Quote 0
                @sdetweil Really… So maybe current version of MM² have to be patched :/
                  sdetweil @bugsounet
                  @bugsounet yes, have to fix my installer, today
                  posted new topic here w instructions .
                  false alarm on node 23
                  S L 2 Replies Last reply Reply Quote 0
                    installer fixed
                    except for screen saver settings, as wayfire.ini is no longer used
                      @sdetweil I will install last OS in my pi 4 for inspect (when i have some keep time :/)
                      info on labwc
                      Labwc, a Wayland window-stacking compositor, doesn’t have screen saver settings. However, you can configure Labwc to do other things, such as:
                      Set a shortcut to a launcher: Create a configuration file at ~/.config/labwc/rc.xml and add a entry.
                      Start a background-image client and a panel: Add the command to ~/.config/labwc/autostart.
                      Labwc is a lightweight compositor that stacks windows and renders some window decorations. It’s inspired by openbox and takes a simple approach, avoiding features like animations.
                      on pi those files are in
                      /etc/xdg/labwc/autostart
                      /etc/xdg/labwc/rc.xml
                      /etc/xdg/labwc/environment
                      none of that appears changed when setting screen dimming on in raspi-config
                      none of the script older settings are triggered
                      • F Offline
                        fatrgr
                        Just wanted to say thanks for the hard work!
                        P.S. Sorry for cluttering the post. :)
                          sdetweil @bugsounet
                          @bugsounet yes, I saw the same, none of the older settings trigger, but haven’t found a new one…
