    [ERROR] Calendar Error. Could not fetch calendar:
    13 Posts 2 Posters 3.1k Views 2 Watching
      sdetweil @Kazzer
      @Kazzer can you show the startup messages from npm start
      after the starting application
      there is a dump of system info , like this
      2024-10-29 17:55:20.819] [INFO]  System information:
      ### SYSTEM:   manufacturer: ; model: ; virtual: false
      ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51+rpt-rpi-v8
      ### VERSIONS: electron: 31.7.3; used node: 20.18.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
      ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
      K 2 Replies Last reply
      • K
        Kazzer @sdetweil
        Hi Sam,
        Thank you for the quick reply, I will send the information when I get home.
        • K
          Kazzer @sdetweil
          • K
            Kazzer
            Hi Sam,
            here you go hope it helps.
            [2024-10-30 19:35:41.396] [INFO] System information:
            SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false
            OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 5.10.103-v7l+
            VERSIONS: electron: 31.6.0; used node: 20.17.0; installed node: 20.18.0; npm: 10.8.2; pm2: 5.4.2
            OTHER: timeZone: Europe/London; ELECTRON_ENABLE_GPU: undefined
            also i get this on the mirror:
            If you need anymore information let me know.
            Thanks again
            Kazzer
              sdetweil @Kazzer
              @Kazzer ok, that looks correct. there were timeout reported problems in an earlier electron version.
              can you try manually downloading the cal?
              from commandline do
              curl -sL cal_url >somefile.txt
              then examine somefile.txt
              • K
                Kazzer
                @sdetweil Hi, i tried this command (curl -sL cal_url >somefile.txt) from within Magicmirror folder and also from the Pi commandline but the somefile.txt is always empty. I even tried it while magic mirror was running.
                Am i doing something wrong?
                  sdetweil @Kazzer
                  @Kazzer you put the real url from the calendar config in place of the cal_url in that command, right?
                  • K
                    Kazzer
                    @sdetweil Hi, done it right now, the somefile seems ok it’s got all my meeting in it. Do you want to see it?
                      sdetweil @Kazzer
                      @Kazzer no, it was just a test of access.
                      • K
                        Kazzer
                        @sdetweil Ok any ideas why it’s not working?
                        Anything else I can try?
                        • K
                          Kazzer
                          Hi Sam,
                          I think i have fixed it by disabling IPv6 in the Raspberry Pi. (see the link below)
                          https://forum.magicmirror.builders/post/114735
                          Thanks for your help.
                            sdetweil @Kazzer
                            @Kazzer awesome
