    [ERROR] Calendar Error. Could not fetch calendar:
    13 Posts 2 Posters 2.4k Views 2 Watching
    • K Offline
      Kazzer @sdetweil
      Hi Sam,
      Thank you for the quick reply, I will send the information when I get home.
      • K Offline
        Kazzer @sdetweil
        • K Offline
          Kazzer
          Hi Sam,
          here you go hope it helps.
          [2024-10-30 19:35:41.396] [INFO] System information:
          SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false
          OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 5.10.103-v7l+
          VERSIONS: electron: 31.6.0; used node: 20.17.0; installed node: 20.18.0; npm: 10.8.2; pm2: 5.4.2
          OTHER: timeZone: Europe/London; ELECTRON_ENABLE_GPU: undefined
          also i get this on the mirror:
          If you need anymore information let me know.
          Thanks again
          Kazzer
            sdetweil @Kazzer
            @Kazzer ok, that looks correct. there were timeout reported problems in an earlier electron version.
            can you try manually downloading the cal?
            from commandline do
            curl -sL cal_url >somefile.txt
            then examine somefile.txt
            • K Offline
              Kazzer
              @sdetweil Hi, i tried this command (curl -sL cal_url >somefile.txt) from within Magicmirror folder and also from the Pi commandline but the somefile.txt is always empty. I even tried it while magic mirror was running.
              Am i doing something wrong?
                sdetweil @Kazzer
                @Kazzer you put the real url from the calendar config in place of the cal_url in that command, right?
                • K Offline
                  Kazzer
                  @sdetweil Hi, done it right now, the somefile seems ok it’s got all my meeting in it. Do you want to see it?
                    sdetweil @Kazzer
                    @Kazzer no, it was just a test of access.
                    • K Offline
                      Kazzer
                      @sdetweil Ok any ideas why it’s not working?
                      Anything else I can try?
                      • K Offline
                        Kazzer
                        Hi Sam,
                        I think i have fixed it by disabling IPv6 in the Raspberry Pi. (see the link below)
                        https://forum.magicmirror.builders/post/114735
                        Thanks for your help.
                          sdetweil @Kazzer
                          @Kazzer awesome
