    MMM-Hoymiles-Wifi
    58 Posts 6 Posters 22.7k Views 5 Watching
    • KristjanESPERANTOK Offline
      KristjanESPERANTO Module Developer @schris88
      @schris88 Nice :-) Don’t forget to add it to the module list: https://github.com/MagicMirrorOrg/MagicMirror/wiki/3rd-party-modules
      • evroomE Offline
        evroom @schris88
        @schris88
        Hi there,
        I am using hoymiles-wifi myself and am curious on how it looks on the MagicMirror.
        Very nice initiative !!
        Trying to get your module working, but no luck till now.
        I will open some Issues for you to have a look at.
        Best regards,
        E.J.
        MagicMirror version: 2.37.0
          schris88 @evroom
          @evroom We will make this work, great input, there is so many possibilities what and how to display the data.
          Im thinking about feeding a free tier mongodb or some local docker db for long time charts.
          • evroomE Offline
            evroom @schris88
            @schris88
            It is working now.
            I see it displayed on the MagicMirror.
            Due to no sunshine I cannot check actual values, but that is for later.
              SuVo @schris88
              @schris88 dfg
              I am using
              HMS-800W-2T
              I have done your installation steps but there is no output on my MagicMirror.
              The source http://127.0.0.1:5000 is correct?
              What can I try?
              Have you any idea what could be wrong?
              evroomE 2 Replies Last reply Reply Quote 0
              • evroomE Offline
                evroom @SuVo
                @SuVo said in MMM-Hoymiles-Wifi:
                What can I try?
                You have to edit
                ~/MagicMirror/modules/MMM-Hoymiles-Wifi/hoymiles_data.py
                Change this line to the address of your DTU:
                dtu = DTU("192.168.178.114")
                And I had to change
                 width: "288px",
                 height: "360px",
                in the ~/MagicMirror/config/config.js file.
                This is my config:
                  module: "MMM-Hoymiles-Wifi",
                  header: "MMM-Hoymiles-Wifi",
                  disabled: false,
                    width: "288px",
                    height: "360px",
                    updateInterval: 60000, // in milli seconds
                    frames : [
                      { src: 'http://127.0.0.1:5000' },
                evroomE S 2 Replies Last reply Reply Quote 0
                • evroomE Offline
                  evroom @evroom
                  Just FYI.
                  I am currently busy making some changes to the module.
                  As there is no sunshine due to the current weather conditions, it is a bit difficult to have real measurements.
                  Trying to add a test using a JSON dataset.
                  Hope to be able to present it a.s.a.p.
                  E.J.
                    sdetweil @evroom
                    @evroom said in MMM-Hoymiles-Wifi:
                    dtu = DTU(“192.168.178.114”)
                    sounds like a new config parm so you don’t have to edit the file
                    (pass as a parameter on /hoymiles_data.py start)
                    • evroomE Offline
                      evroom @sdetweil
                      @sdetweil said in MMM-Hoymiles-Wifi:
                      Exactly!
                      I did change hoymiles_data.py to be able to refrain from hard-coding it:
                      python hoymiles_data.py --dtu_ip_address 192.168.178.114--debug
                      The next thing would be to pass the parameter(s) from the configuration (to be coded in the MMM-Hoymiles-Wifi.js file).
                      As I never made a module myself, I would need to find out how.
                      Any suggestions are much appreciated!
                      E.J.
                        sdetweil @evroom
                        @evroom put it in the modulename.js defaults section
                        i bet the config is already passed to the node helper which execs the python script.
                        yep
                          this.sendSocketNotification("INIT", this.config)
                        then the user adds the property to the config.js module entry, as they are editing it anyhow
                        • evroomE Offline
                          evroom @SuVo
                          @SuVo
                          Hi, question,
                          do you live somewhere sunny ?
                          Could you try the run this and share the output ?
                          hoymiles-wifi --host 192.168.178.114 get-real-data-new
                          You’ll need to change the IP to the IP of your DTU.
                          E.J.
                          • evroomE Offline
                            evroom @sdetweil
                            Actually the python script is being executed via a shell script (in order to make it running using pm2).
                            I do not see anything in the node_helper.js file.
                            This is mainly due to the fact that the developer of the module used MMM-HTMLSnippet as basis and concentrated more on the data that he wanted to display.
                            The challenge is now to have everything running inside the module, without this ‘external’ stuff.
                            As all modules tend to do.
                            S S 2 Replies Last reply Reply Quote 1
                              sdetweil @evroom
                              @evroom see my pythonPrint module for how to execute a python script
                              https://github.com/sdetweil/MMM-PythonPrint
                              you can also exec a shell script too
                              and launch pm2 to start/stop that shell script
                                schris88 @evroom
                                This is true, it´s a hacked proof of concept, nothing to be proud of at the moment :D
                                Not sure how much time I have for it till end of year, I can grant write access to anyone who´s willing to help.
                                • evroomE Offline
                                  evroom @schris88
                                  @schris88 said in MMM-Hoymiles-Wifi:
                                  Not to worry. You sparked an idea.
                                  I have some modifications ready (I forked it), but fighting with github to get it synced (github wants to delete all my modifications when I try).
                                  Perhaps granting me access (evroom) wil make it easier.
                                  Although it is not really the way to use github, I guess.
                                  E.J.
                                    sdetweil @evroom
                                    @evroom
                                    you fork
                                    clone fork //git clone
                                    make new branch // git checkout -b nane
                                    make code changes
                                    // this part multiple times
                                    add to files to commit // git add filename
                                    git commit
                                    git push // to add to github fork
                                    on github go to original repo source
                                    create pull request // for origin to pull changes from your fork
                                    if subsequent push to same branch, PR will be updated automatically
                                    • evroomE Offline
                                      evroom @sdetweil
                                      git commit
                                      I am stuck here.
                                      Will open a new topic for it …
                                      • evroomE Offline
                                        evroom @evroom
                                        Hi there,
                                        I made some major changes to the code and hopefully did all the GitHub stuff correct in order to allow persons interested to give it a (new) try.
                                        https://github.com/schris88/MMM-Hoymiles-Wifi
                                        There is still a lot to do (see ‘TODO’ in the README file), but I think the basis provided by Christian (@schris88) has been strengthened.
                                        Best regards,
                                        E.J.
                                        • evroomE Offline
                                          evroom @evroom
                                          @schris88
                                          Christian,
                                          This is on the TODO list:
                                          change pv_data to dtu date for combined output of inverter
                                          But I do not really understand what you mean by it.
                                          Do you mean combined output of 2 panels iso just 1 ?
                                          Please elaborate.
                                          E.J.
                                            schris88 @evroom
                                            @evroom Hi there, maybe you can confirm, if the inverter has multiple inputs there seems to be an array of pv_data objects in the json (as seen in the test.json you pushed)
                                            so the meter should combine all pv data power to have the total, right.
                                            But we dont need to do that by hand because the combined value should be in dtu_power already, you can get rid of all the try except.
                                            I just didnt change it in the beginning because for inverters with only one input it makes no difference because its pv_data power and dtu_power is always the same value.
