    Changing table cell in calendar module using custom.css
    11 Posts 2 Posters 2.7k Views 2 Watching
    • evroomE Offline
      evroom
      I saw some CSS topics recently and would like to add my issue to the list.
      I read a few tutorials / explanations, but I cannot get that mapped to my issue.
      Trying to add an entry in custom.css to change padding-top: 10px; to padding-top: 0px;
      Using the browsers elements inspector I was able to find what should be changed:
      Now the question is how to translate this to the wanted CSS entry.
      This is an attempt, but of course wrong:
      .calendar .div.module-content .table.xsmall .tr.dateheader.normal .td .element.style {
          padding-top: 0px;
      Any help is much appreciated.
      E.J.
      MagicMirror version: 2.37.0
        sdetweil @evroom
        @evroom did you get this resolved?
        so, what classes/element names get you to that specific element
        if you look at the bottom of the html view, when u have that element selected you will see the style chain (pink box bottom, also around selected element)
        one other cool thing is that in the console tab you can use jquery search to ‘find’ THE element(or elements)
        $(jquery search clause) (which matches the css selector clause, IN SINGLE QUOTES)
        press enter and it will give you a result list… length 0 means not found.
        if elements are found you can examine them,
        you can start small (left most) and then cursor up to get what you had and add more…
        • evroomE Offline
          evroom @sdetweil
          @sdetweil said in Changing table cell in calendar module using custom.css:
          No, I did not and even with your additional tutorial I am hitting a black spot.
          I see this at the bottom:
          This corresponds with:
          <div class="module-content"
          ><table class="xsmall">
              <tr class="dateheader normal dayAfterTomorrow">
                  <td colspan="3" style="padding-top: 10px;">Nov 15th 00:00 </td>
              </tr>
              <tr class="event-wrapper normal event dayAfterTomorrow">
                  <td>&nbsp;&nbsp;&nbsp;</td>
                  <td class="title bright align-left" colspan="2">TestCal: All day event</td>
              </tr>
          </table>
          </div>
          So I should have all info available to build the CSS entry, you would think.
          Right ?
          And the console does not like my input:
          ${'calendar .event'}
          VM2076:1 Uncaught SyntaxError: Unexpected token '{'
          ${'.calendar .event'}
          VM2080:1 Uncaught SyntaxError: Unexpected token '{'
          ${'.calendar .event .time'}
          VM2146:1 Uncaught SyntaxError: Unexpected token '{'
          I cannot even make a CSS entry to change this:
          <table class="xsmall">, that is how lost I am :-)
          Need to study the existing tutorials some more.
          E.J.
            sdetweil @evroom
            @evroom the console jquery search is
            $('search string')
            parens, not braces
              sdetweil @evroom
              @evroom also, your screen shot says it
              when there is no space between the elements in a selector clause,
              that mean they ALL MUST be present on AN element
              with space they must be in the same element TREE (notice the space after …Tomorrow and before td)
              so that means
              a tr (table row) element (no . in front) AND a dateheader (class .) AND a normal(class .) AND a dayAfterTomorrow (class .) followed by a td (table/column/data) element
              • evroomE Offline
                evroom @sdetweil
                parens, not braces
                Yes, those who can read have a clear advantage. :-)
                $('.calendar tr .dateheader.normal.dayAfterTomorrow td')
                null
                $('.calendar tr.dateheader.normal.dayAfterTomorrow td')
                $('.calendar .dateheader.normal.dayAfterTomorrow td')
                custom.css:
                .calendar .dateheader.normal.dayAfterTomorrow td {
                    padding-top: 0px;
                .calendar tr.dateheader.normal.dayAfterTomorrow td {
                  padding-top: 0px;
                Both do no work.
                Either the selection is wrong, or perhaps it has to do with style="padding-top: 10px;".
                Or both.
                Will continue tomorrow.
                E.J.
                  sdetweil @evroom
                  @evroom can u see the custom.css styles selected in the right window on the dev window elements tab?
                  that will prove that the selector clause worked (or not)
                  • evroomE Offline
                    evroom @sdetweil
                    Yes, I can:
                    But is stricken through.
                    So somebody high-jacked it probably.
                    Look like I am going somewhere, but now the finishing touch.
                      sdetweil @evroom
                      @evroom
                      ok, the selector is good
                      that typing at the top has replaced it
                      but CSS selects the style that is MOST specific…
                      yours might not be vs the style ON the element
                      you can override by adding !important
                         padding-top: 0px !important;
                      • evroomE Offline
                        evroom @sdetweil
                        That did the trick !
                        I must say that the Elements tab is confusing, as it looks like the value did not change.
                        Probably this is the state before custom.css is applied.
                        The padding has gone (this was my goal):
                        An additional question.
                        How to change the class, as in this example ?
                        $('.calendar table')
                        <table class="xsmall"><tr class="dateheader normal dayAfterTomorrow"><td colspan="3" style="padding-top: 10px;">Nov 15th 00:00 </td></tr><tr class="event-wrapper normal event dayAfterTomorrow"><td>&nbsp;&nbsp;&nbsp;</td><td class="title bright align-left" colspan="2">TestCal: All day event</td></tr></table>
                        .calendar .table {
                          class: "small" !important;
                        It says Unkown property name, which makes sense.
                        E.J.
                          sdetweil @evroom
                          @evroom you cannot add or change a classname string
                          class=“foo”
                          to add “bar” class too
                          class =“foo bar”
                          but you CAN change the behavior of the other classes to match what adding another class could do
                          OR , you could add the styles to the ELEMENTS you WOULD have added the bar class to…
                          just_have_to_select_them {
                          styles
                          as an example of a complex selector in my MMM-Config, I want to hide an element on a library generated element
                          .possibly-hidden-tab div:nth-child(2)  > div > div >div >ul >li:only-child >a[rel*="Item%201"] {
                            display: none;
                          this is
                          elements with the possibly-hidden-tab class
                          its second child div
                          its immed child div
                          its immed child div
                          its immed child div
                          its immed child ul
                          its immed only child li
                          with an a element containing a rel attribute value of “Item 1”
                          (spaces have to be encoded, but for clarity I left it out here)
