    Changing table cell in calendar module using custom.css
    11 Posts 2 Posters 2.0k Views 2 Watching
      sdetweil @evroom
      @evroom the console jquery search is
      $('search string')
      parens, not braces
        sdetweil @evroom
        @evroom also, your screen shot says it
        when there is no space between the elements in a selector clause,
        that mean they ALL MUST be present on AN element
        with space they must be in the same element TREE (notice the space after …Tomorrow and before td)
        so that means
        a tr (table row) element (no . in front) AND a dateheader (class .) AND a normal(class .) AND a dayAfterTomorrow (class .) followed by a td (table/column/data) element
        • evroomE Offline
          evroom @sdetweil
          parens, not braces
          Yes, those who can read have a clear advantage. :-)
          $('.calendar tr .dateheader.normal.dayAfterTomorrow td')
          null
          $('.calendar tr.dateheader.normal.dayAfterTomorrow td')
          <td colspan="3" style="padding-top: 10px;">Nov 15th 00:00 </td>
          $('.calendar .dateheader.normal.dayAfterTomorrow td')
          custom.css:
          .calendar .dateheader.normal.dayAfterTomorrow td {
              padding-top: 0px;
          .calendar tr.dateheader.normal.dayAfterTomorrow td {
            padding-top: 0px;
          Both do no work.
          Either the selection is wrong, or perhaps it has to do with style="padding-top: 10px;".
          Or both.
          Will continue tomorrow.
          E.J.
          MagicMirror version: 2.33.0
          Test environment:
          MagicMirror version: v2.33.0
            sdetweil @evroom
            @evroom can u see the custom.css styles selected in the right window on the dev window elements tab?
            that will prove that the selector clause worked (or not)
            • evroomE Offline
              evroom @sdetweil
              Yes, I can:
              But is stricken through.
              So somebody high-jacked it probably.
              Look like I am going somewhere, but now the finishing touch.
              Test environment:
                sdetweil @evroom
                @evroom
                ok, the selector is good
                that typing at the top has replaced it
                but CSS selects the style that is MOST specific…
                yours might not be vs the style ON the element
                you can override by adding !important
                   padding-top: 0px !important;
                • evroomE Offline
                  evroom @sdetweil
                  That did the trick !
                  I must say that the Elements tab is confusing, as it looks like the value did not change.
                  Probably this is the state before custom.css is applied.
                  The padding has gone (this was my goal):
                  An additional question.
                  How to change the class, as in this example ?
                  $('.calendar table')
                  <table class="xsmall"><tr class="dateheader normal dayAfterTomorrow"><td colspan="3" style="padding-top: 10px;">Nov 15th 00:00 </td></tr><tr class="event-wrapper normal event dayAfterTomorrow"><td>&nbsp;&nbsp;&nbsp;</td><td class="title bright align-left" colspan="2">TestCal: All day event</td></tr></table>
                  .calendar .table {
                    class: "small" !important;
                  It says Unkown property name, which makes sense.
                  E.J.
                  Test environment:
                    sdetweil @evroom
                    @evroom you cannot add or change a classname string
                    class=“foo”
                    to add “bar” class too
                    class =“foo bar”
                    but you CAN change the behavior of the other classes to match what adding another class could do
                    OR , you could add the styles to the ELEMENTS you WOULD have added the bar class to…
                    just_have_to_select_them {
                    styles
                    as an example of a complex selector in my MMM-Config, I want to hide an element on a library generated element
                    .possibly-hidden-tab div:nth-child(2)  > div > div >div >ul >li:only-child >a[rel*="Item%201"] {
                      display: none;
                    this is
                    elements with the possibly-hidden-tab class
                    its second child div
                    its immed child div
                    its immed child div
                    its immed child div
                    its immed child ul
                    its immed only child li
                    with an a element containing a rel attribute value of “Item 1”
                    (spaces have to be encoded, but for clarity I left it out here)
