Cannot get MMM-EmbedURL to show any sites
14 Posts 3 Posters 1.1k Views 3 Watching
  • U Offline
    unaccomplished
    Rapsberry Pi 4, MagicMirror v2.29.0
    I have a week-old install working for all modules except MMM-EmbedURL. I am trying to get two, local ip cams to display a feed over http. These feeds work fine in the Chromium desktop browser. Here’s an example of a URL:
    http://10.0.0.51:50081/ui3.htm?t=live&cam=Doorbell&maximize=1
    I have tried other URLs, including the examples, but nothing shows up, not even an error. This is the last module to load for me, and no errors are present for any module. There are not any other broadcasts or messages related to this module afterwards. The header used does appear, confirming the module is loaded.
    [LOG]   Connecting socket for: MMM-EmbedURL
    In case there are any known issues with other modules, here’s a list of what’s installed and working, across 4 different pages with MMM-pages:
    WallberryTheme
    WB-clock
    WB-weather
    MMM-CalendarExt3Journal
    alert
    updatenotification
    clock
    MMM-homeassistant-sensors
    MMM-CalDAV
    Pinfo
    calendar
    MMM-Pir
    MMM-MoonPhase
    MMM-NHL
    MMM-MyStandings
    MMM-EasyPix.
    MMM-BGSS_1 (copy/tweak of MMM-BackgroundSlideshow)
    MMM-GroveGestures
    MMM-NotificationTrigger
    MMM-EmbedURL
    Here’s the top of my config.js, as well as the relevant module configuration:
    let config = {
            electronOptions: {
                    webPreferences: {
                            webSecurity: false,
                            webviewTag: true,
                    fullscreen: true,
                    alwaysOnTop: true,
    and
                           module: "MMM-EmbedURL",
                           position: "upper_third",
                           header: "Embed-URL",
                                   updateInterval: 120,
                                   embedElementType: "webview",
                                   attributes: [
                                           "frameborder=0",
                                   embed: [
                                           "http://10.0.0.51:50081/ui3.htm?t=live&cam=Doorbell&maximize=1",
                                           "https://www.youtube.com/embed/dIHr96KqfDI",
    I’d appreciate any help on this, and let me know if there’s something else I can add or provide to resolve.
    S W 2 Replies Last reply Dec 3, 2024, 10:50 PM Reply Quote 0
    • U Offline
      unaccomplished @unaccomplished
      @wishmaster270
      Just went back in and realized these were commented out in my config.
      ignoreXOriginHeader: true,
      ignoreContentSecurityPolicy: true,
      I added them back in, and success! Now to find a way to config the page to not need a login, but its huge progress. Thanks!
      S 1 Reply Last reply Dec 4, 2024, 11:21 PM Reply Quote 0
      • S Away
        sdetweil @unaccomplished
        @unaccomplished can you look at the messages where you start MagicMirror
        if you are using pm2, then
        pm2 logs --lines=50
        may show them
        typically I recommend NOT using pm2 when adding and changing modules as it makes access to the logs harder…
        I see
        [2024-12-03 16:48:09.041] [ERROR] (node:2137989) electron: Failed to load URL: https://www.cnn.com/?timestamp=1733266088 with error: ERR_BLOCKED_BY_RESPONSE
        (Use `electron --trace-warnings ...` to show where the warning was created)
        [2024-12-03 16:48:09.482] [ERROR] (node:2137989) electron: Failed to load URL: https://magicmirror.builders/?timestamp=1733266088 with error: ERR_BLOCKED_BY_RESPONSE
        S U 2 Replies Last reply Dec 3, 2024, 10:56 PM Reply Quote 0
        • S Away
          @unaccomplished
          I put one of my MM web pages in the embed list and it also doesn’t show… altho the embed content is in the MM elements page view
          and the page works correctly when viewed in a browser (the page is hosted by MM)
          never tried the module before
          • W Offline
            wishmaster270 Module Developer @unaccomplished
            @unaccomplished
            just tried your config in my setup and everything worked as expected.
            The question is…where are the differences in your and mine setup.
            As a first try you can replace embedElementType: "webview," with embedElementType: "iframe,".
            If the embeded pages does not block embedding iframe should work and you do not weaken any security settings of the electron browser.
            Additionally you can replace "frameborder=0", with "frameborder=1",. You should see two boxes at least then. Even if the sites could not be embedded.
            @sdetweil Are you sure you set the security settings of electron? Without them electron will not support webview and will not display anything.
            S U 2 Replies Last reply Dec 4, 2024, 5:51 PM Reply Quote 1
            • S Away
              sdetweil @wishmaster270
              @wishmaster270 said in Cannot get MMM-EmbedURL to show any sites:
              no… I viewed that as optional if doing webview…(electron javascript content) but I am viewing an html page. (altho hosted by MM)
              If do use the build in electron browser to view the mirror you can use Webview instead
              my config
                  attributes: [
                      "frameborder=0",
                  embed: [
                      "http://localhost:8090/modules/MMM-Config/review/",
                      "https://cnn.com"
              S 1 Reply Last reply Dec 4, 2024, 11:16 PM Reply Quote 0
              • U Offline
                unaccomplished @sdetweil
                @sdetweil said in Cannot get MMM-EmbedURL to show any sites:
                pm2 logs --lines=50
                It seems this is the most relevant error in the log:
                /home/MagicMirrorPi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                Here are my error logs:
                /home/MagicMirrorPi/.pm2/logs/MagicMirror-error.log last 50 lines:
                0|MagicMir | [2100:1204/174503.791282:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2100:1204/174503.791659:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2100:1204/174503.791914:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2100:1204/174503.792304:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2100:1204/174503.792571:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2100:1204/174503.794953:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2100:1204/174503.795270:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2100:1204/174503.797663:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2100:1204/174503.799569:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2100:1204/174503.801781:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2100:1204/174503.805922:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2100:1204/174503.809880:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2100:1204/174503.810094:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2100:1204/174503.810464:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2100:1204/174503.810645:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2100:1204/174503.810893:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2100:1204/174503.811059:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2100:1204/174503.811276:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2100:1204/174503.811427:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | /home/MagicMirrorPi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                0|MagicMir | [2024-12-04 17:52:52.959] [WARN]  No /home/MagicMirrorPi/MagicMirror/js/../modules/WallberryTheme/WB-clock/WallberryTheme/WB-clock.js found for module: WB-clock.
                0|MagicMir | [2024-12-04 17:52:52.966] [WARN]  No /home/MagicMirrorPi/MagicMirror/js/../modules/WallberryTheme/WB-weather/WallberryTheme/WB-weather.js found for module: WB-weather.
                0|MagicMir | [2061:1204/175303.171404:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.171830:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.172059:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.173512:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.173776:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.173859:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.174003:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.174110:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.174246:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.174329:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.174452:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.174522:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.174643:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.174716:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.175789:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.177938:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.178289:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.178399:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.178547:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.178626:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.182442:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.183828:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.184097:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.184177:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.184326:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.184401:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.184533:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                0|MagicMir | [2061:1204/175303.184607:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                The two wrapper errors and the two Wallberry warnings have been perpetual, but don’t seem to affect anything. If you have any insight on these, I’d appreciate it.
                I also noted this from the out-put log:
                0|MagicMir | ### OTHER:    timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
                0|MagicMir | [2024-12-04 17:53:26.965] [LOG]   Electron's cache successfully cleared.
                and later in the same log:
                0|MagicMir | [2024-12-04 17:53:34.199] [INFO]  Checking git for module: MMM-EmbedURL
                0|MagicMir | [2024-12-04 17:53:34.289] [LOG]   resizing done!
                I don’t think these are errors, at least not in the context provided.
                S 1 Reply Last reply Dec 4, 2024, 11:07 PM Reply Quote 0
                • U Offline
                  unaccomplished @wishmaster270
                  @unaccomplished
                  I updated the config as requested, once without, and then with “iframe”.
                                                 embedElementType: "iframe",
                                                 attributes: [
                                                         "frameborder=1",
                                                 embed: [
                  Without switching to iframe, the frameborder made no difference. Now with iframe, I have two blank boxes appearing.
                  S U 2 Replies Last reply Dec 4, 2024, 11:08 PM Reply Quote 0
                  • S Away
                    @unaccomplished I agree, not the errors I was seeing…
                    so @wishmaster270 will have to help more
                    • S Away
                      @unaccomplished your code markers MUST start in column 1.
                      U 1 Reply Last reply Dec 4, 2024, 11:14 PM Reply Quote 0
                      • U Offline
                        Sorry, is it a formatting error in my comments, or in my config file?
