    MMM-Pir or MMM-PIR-Sensor
    27 Posts 6 Posters 13.1k Views 5 Watching
    • A
      Andrei.Leahu @sdetweil
      @sdetweil Hello here is the Info Log: magicmirror@2.26.0 start
      [2024-10-06 14:00:06.410] [LOG] Starting MagicMirror: v2.26.0
      [2024-10-06 14:00:06.456] [LOG] Loading config …
      [2024-10-06 14:00:06.469] [LOG] config template file not exists, no envsubst
      [2024-10-06 14:00:07.561] [INFO] Checking config file /home/xenon/MagicMirror/config/config.js …
      [2024-10-06 14:00:07.688] [INFO] Your configuration file doesn’t contain syntax errors :)
      [2024-10-06 14:00:07.689] [INFO] Checking modules structure configuration …
      [2024-10-06 14:00:07.770] [INFO] Your modules structure configuration doesn’t contain errors :)
      [2024-10-06 14:00:08.526] [LOG] Loading module helpers …
      [2024-10-06 14:00:08.537] [LOG] No helper found for module: alert.
      [2024-10-06 14:00:08.625] [LOG] Initializing new module helper …
      [2024-10-06 14:00:08.626] [LOG] Module helper loaded: updatenotification
      [2024-10-06 14:00:08.641] [LOG] No helper found for module: clock.
      [2024-10-06 14:00:08.644] [LOG] No helper found for module: compliments.
      [2024-10-06 14:00:08.646] [LOG] No helper found for module: weather.
      [2024-10-06 14:00:08.726] [LOG] Initializing new module helper …
      [2024-10-06 14:00:08.728] [LOG] Module helper loaded: MMM-GoogleKeep
      [2024-10-06 14:00:08.732] [LOG] No helper found for module: MMM-CalendarExt3.
      [2024-10-06 14:00:09.350] [LOG] Initializing new module helper …
      [2024-10-06 14:00:09.351] [LOG] Module helper loaded: calendar
      [2024-10-06 14:00:10.016] [LOG] Initializing new module helper …
      [2024-10-06 14:00:10.017] [LOG] Module helper loaded: MMM-BackgroundSlideshow
      [2024-10-06 14:00:10.053] [LOG] Initializing new module helper …
      [2024-10-06 14:00:10.055] [LOG] Module helper loaded: MMM-Pir
      [2024-10-06 14:00:10.058] [LOG] All module helpers loaded.
      [2024-10-06 14:00:10.104] [LOG] Starting server on port 8080 …
      [2024-10-06 14:00:10.979] [LOG] Server started …
      [2024-10-06 14:00:10.981] [LOG] Connecting socket for: updatenotification
      [2024-10-06 14:00:10.983] [LOG] Starting module helper: updatenotification
      [2024-10-06 14:00:10.985] [LOG] Connecting socket for: MMM-GoogleKeep
      [2024-10-06 14:00:10.987] [LOG] [MMM-GoogleKeep_helper]:: Starting node_helper for module [MMM-GoogleKeep]
      [2024-10-06 14:00:10.988] [LOG] Connecting socket for: calendar
      [2024-10-06 14:00:11.013] [LOG] Starting node helper for: calendar
      [2024-10-06 14:00:11.019] [LOG] Connecting socket for: MMM-BackgroundSlideshow
      [2024-10-06 14:00:11.027] [LOG] Connecting socket for: MMM-Pir
      [2024-10-06 14:00:11.040] [LOG] Sockets connected & modules started …
      [2024-10-06 14:00:11.581] [LOG] Launching application.
      [2024-10-06 14:00:16.406] [INFO] System information:
      SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.2; virtual: false
      OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v8+
      VERSIONS: electron: 27.3.5; used node: 18.17.1; installed node: 20.8.0; npm: 10.9.0; pm2:
      OTHER: timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
      [2024-10-06 14:00:17.370] [LOG] Create new calendarfetcher for url: xxxx- Interval: 2000
      [2024-10-06 14:00:17.661] [LOG] Create new calendarfetcher for url: xxxxxx - Interval: 2000
      [2024-10-06 14:00:17.671] [LOG] [MMM-Pir] Version: 1.5.4 rev: 240824
      [2024-10-06 14:00:17.680] [LOG] [MMM-Pir] [LIB] [PIR] Mode 0 Selected (onoff library)
      [2024-10-06 14:00:17.768] [LOG] [MMM-Pir] [CALLBACK] Pir: PIR_STARTED
      [2024-10-06 14:00:17.770] [LOG] [MMM-Pir] [LIB] [PIR] Started!
      [2024-10-06 14:00:17.773] [LOG] [MMM-Pir] [LIB] [SCREEN] Mode 1: vcgencmd
      [2024-10-06 14:00:17.775] [LOG] [MMM-Pir] [LIB] [SCREEN] Start.
      [2024-10-06 14:00:17.777] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_PRESENCE true
      [2024-10-06 14:00:17.806] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_SHOWING
      [2024-10-06 14:00:17.808] [LOG] [MMM-Pir] Started!
      [2024-10-06 14:00:17.812] [INFO] updatenotification: Updater Class Loaded!
      [2024-10-06 14:00:17.813] [INFO] updatenotification: Checking PM2 using…
      [2024-10-06 14:00:17.817] [INFO] Checking git for module: MMM-GoogleKeep
      [2024-10-06 14:00:17.873] [INFO] BACKGROUNDSLIDESHOW: Reading directory “modules/MMM-BackgroundSlideshow/exampleImages/” for images.
      [2024-10-06 14:00:17.877] [INFO] BACKGROUNDSLIDESHOW: 4 files found
      [2024-10-06 14:00:17.881] [INFO] BACKGROUNDSLIDESHOW: reading path “modules/MMM-BackgroundSlideshow/exampleImages//1.png”
      [2024-10-06 14:00:17.882] [LOG] resizeImages: false
      [2024-10-06 14:00:17.935] [INFO] Checking git for module: MMM-CalendarExt3
      [2024-10-06 14:00:17.958] [LOG] [MMM-Pir] [LIB] [SCREEN] Display: Force On Start
      [2024-10-06 14:00:17.960] [LOG] [MMM-Pir] [LIB] [SCREEN] Display ON.
      [2024-10-06 14:00:18.016] [INFO] Checking git for module: MMM-BackgroundSlideshow
      [2024-10-06 14:00:18.103] [INFO] Checking git for module: MMM-Pir
      [2024-10-06 14:00:18.312] [INFO] Checking git for module: MagicMirror
      [2024-10-06 14:00:18.632] [LOG] Stream closed.
      [2024-10-06 14:00:19.094] [INFO] Calendar-Fetcher: Broadcasting 0 events from xxxxx
      [2024-10-06 14:00:19.260] [INFO] Calendar-Fetcher: Broadcasting 0 events from xxxxx
      [2024-10-06 14:00:19.266] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_POWERSTATUS true
      [2024-10-06 14:00:19.268] [LOG] [MMM-Pir] [LIB] [SCREEN] [POWER] Display from false —> true
      [2024-10-06 14:00:19.273] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:20’, bar: 0 }
      [2024-10-06 14:00:20.280] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:19’, bar: 1000 }
      [2024-10-06 14:00:20.429] [LOG] {
      note_text: {
      header: ’
      text: [
      ‘â Pampers’
      [2024-10-06 14:00:20.599] [LOG] [MMM-GoogleKeep] finished running…
      [2024-10-06 14:00:20.851] [INFO] updatenotification: You are not using pm2
      [2024-10-06 14:00:21.382] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:18’, bar: 2000 }
      [2024-10-06 14:00:21.553] [INFO] xxxx
      [2024-10-06 14:00:21.768] [INFO] Calendar-Fetcher: Broadcasting 0 events from xxx
      [2024-10-06 14:00:22.405] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:17’, bar: 3000 }
      [2024-10-06 14:00:23.465] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:16’, bar: 4000 }
      [2024-10-06 14:00:23.820] [INFO] Calendar-Fetcher: Broadcasting 0 events from xxxx
      [2024-10-06 14:00:24.475] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:15’, bar: 5000 }
      [2024-10-06 14:00:25.477] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:14’, bar: 6000 }
        sdetweil @Andrei.Leahu
        @Andrei-Leahu thanks. Bullseye, 64bit,
        @bugsounet will have to look at this
        bugsounetB 1 Reply Last reply
        • bugsounetB
          bugsounet Banned @sdetweil
          @sdetweil I know but MMM-Pir v2 is under-coding
          In all case:
          • [MMM-Pir] [LIB] [PIR] Mode 0 Selected (onoff library) : onoff library will be removed
          • [MMM-Pir] [LIB] [SCREEN] Mode 1: vcgencmd : vcgencmd will be removed
          A 1 Reply Last reply
          • A
            Andrei.Leahu @bugsounet
            @bugsounet I understand, so to make it work I should use now another mode right? Thank you
            • A
              Andrei.Leahu @Andrei.Leahu
              so I tried xset dpms force off and on and they are working so I will use mode: 2 for the screen. Now I have this behavior for pir_mode:1 : the counter is not counting down as if the sensor is always on maybe?
              pir_mode:2 not working. Thank you
                jefftse
                Did anyone get MMM-PIR-Sensor work with bookworm?
                  sdetweil @jefftse
                  @jefftse MMM-Zpir has had lots of changes recently due to bookworm
                  J 1 Reply Last reply
                    jefftse @sdetweil
                    @sdetweil does it still work? I can’t get it to work to save my life?
                    S 2 Replies Last reply
                      sdetweil @jefftse
                      @jefftse yes, the parms changed, different mode
                        sdetweil @jefftse
                        @jefftse please don’t double post. all users with reputation below 2 have their posts reviewed before they go live. this stops all the junk posts, advertising, etc
                        but sometimes the reviewers sleep. lol
                          jefftse @sdetweil
                          @sdetweil gotcha. can you point me the right post to fix this please?
                            sdetweil @jefftse
                            @jefftse i dont have THE answer
                            see the module doc, there are lots of modes
                            https://github.com/bugsounet/MMM-Pir
                              jefftse @sdetweil
                              @sdetweil thank you and i got it working!
