    MMM-Pir or MMM-PIR-Sensor
    27 Posts 6 Posters 12.8k Views 5 Watching
      sdetweil @svenpisa
      @svenpisa yes, just delete the folder
        @svenpisa
        see these
        https://forums.raspberrypi.com/viewtopic.php?t=328633
        https://projects.raspberrypi.org/en/projects/physical-computing/11
          Andrei.Leahu
          I have the same problem. The Module is not working, I tried so many parameter changes. Besides that I tried to read the values of the PIR with a python script and is working. To power on/off the monitor via console is working too. I don’t know what to try else
            sdetweil @Andrei.Leahu
            @Andrei-Leahu can you show the info from npm start.
            Right after
            starting application
              Andrei.Leahu @sdetweil
              @sdetweil Hello here is the Info Log: magicmirror@2.26.0 start
              [2024-10-06 14:00:06.410] [LOG] Starting MagicMirror: v2.26.0
              [2024-10-06 14:00:06.456] [LOG] Loading config …
              [2024-10-06 14:00:06.469] [LOG] config template file not exists, no envsubst
              [2024-10-06 14:00:07.561] [INFO] Checking config file /home/xenon/MagicMirror/config/config.js …
              [2024-10-06 14:00:07.688] [INFO] Your configuration file doesn’t contain syntax errors :)
              [2024-10-06 14:00:07.689] [INFO] Checking modules structure configuration …
              [2024-10-06 14:00:07.770] [INFO] Your modules structure configuration doesn’t contain errors :)
              [2024-10-06 14:00:08.526] [LOG] Loading module helpers …
              [2024-10-06 14:00:08.537] [LOG] No helper found for module: alert.
              [2024-10-06 14:00:08.625] [LOG] Initializing new module helper …
              [2024-10-06 14:00:08.626] [LOG] Module helper loaded: updatenotification
              [2024-10-06 14:00:08.641] [LOG] No helper found for module: clock.
              [2024-10-06 14:00:08.644] [LOG] No helper found for module: compliments.
              [2024-10-06 14:00:08.646] [LOG] No helper found for module: weather.
              [2024-10-06 14:00:08.726] [LOG] Initializing new module helper …
              [2024-10-06 14:00:08.728] [LOG] Module helper loaded: MMM-GoogleKeep
              [2024-10-06 14:00:08.732] [LOG] No helper found for module: MMM-CalendarExt3.
              [2024-10-06 14:00:09.350] [LOG] Initializing new module helper …
              [2024-10-06 14:00:09.351] [LOG] Module helper loaded: calendar
              [2024-10-06 14:00:10.016] [LOG] Initializing new module helper …
              [2024-10-06 14:00:10.017] [LOG] Module helper loaded: MMM-BackgroundSlideshow
              [2024-10-06 14:00:10.053] [LOG] Initializing new module helper …
              [2024-10-06 14:00:10.055] [LOG] Module helper loaded: MMM-Pir
              [2024-10-06 14:00:10.058] [LOG] All module helpers loaded.
              [2024-10-06 14:00:10.104] [LOG] Starting server on port 8080 …
              [2024-10-06 14:00:10.979] [LOG] Server started …
              [2024-10-06 14:00:10.981] [LOG] Connecting socket for: updatenotification
              [2024-10-06 14:00:10.983] [LOG] Starting module helper: updatenotification
              [2024-10-06 14:00:10.985] [LOG] Connecting socket for: MMM-GoogleKeep
              [2024-10-06 14:00:10.987] [LOG] [MMM-GoogleKeep_helper]:: Starting node_helper for module [MMM-GoogleKeep]
              [2024-10-06 14:00:10.988] [LOG] Connecting socket for: calendar
              [2024-10-06 14:00:11.013] [LOG] Starting node helper for: calendar
              [2024-10-06 14:00:11.019] [LOG] Connecting socket for: MMM-BackgroundSlideshow
              [2024-10-06 14:00:11.027] [LOG] Connecting socket for: MMM-Pir
              [2024-10-06 14:00:11.040] [LOG] Sockets connected & modules started …
              [2024-10-06 14:00:11.581] [LOG] Launching application.
              [2024-10-06 14:00:16.406] [INFO] System information:
              SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.2; virtual: false
              OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v8+
              VERSIONS: electron: 27.3.5; used node: 18.17.1; installed node: 20.8.0; npm: 10.9.0; pm2:
              OTHER: timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
              [2024-10-06 14:00:17.370] [LOG] Create new calendarfetcher for url: xxxx- Interval: 2000
              [2024-10-06 14:00:17.661] [LOG] Create new calendarfetcher for url: xxxxxx - Interval: 2000
              [2024-10-06 14:00:17.671] [LOG] [MMM-Pir] Version: 1.5.4 rev: 240824
              [2024-10-06 14:00:17.680] [LOG] [MMM-Pir] [LIB] [PIR] Mode 0 Selected (onoff library)
              [2024-10-06 14:00:17.768] [LOG] [MMM-Pir] [CALLBACK] Pir: PIR_STARTED
              [2024-10-06 14:00:17.770] [LOG] [MMM-Pir] [LIB] [PIR] Started!
              [2024-10-06 14:00:17.773] [LOG] [MMM-Pir] [LIB] [SCREEN] Mode 1: vcgencmd
              [2024-10-06 14:00:17.775] [LOG] [MMM-Pir] [LIB] [SCREEN] Start.
              [2024-10-06 14:00:17.777] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_PRESENCE true
              [2024-10-06 14:00:17.806] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_SHOWING
              [2024-10-06 14:00:17.808] [LOG] [MMM-Pir] Started!
              [2024-10-06 14:00:17.812] [INFO] updatenotification: Updater Class Loaded!
              [2024-10-06 14:00:17.813] [INFO] updatenotification: Checking PM2 using…
              [2024-10-06 14:00:17.817] [INFO] Checking git for module: MMM-GoogleKeep
              [2024-10-06 14:00:17.873] [INFO] BACKGROUNDSLIDESHOW: Reading directory “modules/MMM-BackgroundSlideshow/exampleImages/” for images.
              [2024-10-06 14:00:17.877] [INFO] BACKGROUNDSLIDESHOW: 4 files found
              [2024-10-06 14:00:17.881] [INFO] BACKGROUNDSLIDESHOW: reading path “modules/MMM-BackgroundSlideshow/exampleImages//1.png”
              [2024-10-06 14:00:17.882] [LOG] resizeImages: false
              [2024-10-06 14:00:17.935] [INFO] Checking git for module: MMM-CalendarExt3
              [2024-10-06 14:00:17.958] [LOG] [MMM-Pir] [LIB] [SCREEN] Display: Force On Start
              [2024-10-06 14:00:17.960] [LOG] [MMM-Pir] [LIB] [SCREEN] Display ON.
              [2024-10-06 14:00:18.016] [INFO] Checking git for module: MMM-BackgroundSlideshow
              [2024-10-06 14:00:18.103] [INFO] Checking git for module: MMM-Pir
              [2024-10-06 14:00:18.312] [INFO] Checking git for module: MagicMirror
              [2024-10-06 14:00:18.632] [LOG] Stream closed.
              [2024-10-06 14:00:19.094] [INFO] Calendar-Fetcher: Broadcasting 0 events from xxxxx
              [2024-10-06 14:00:19.260] [INFO] Calendar-Fetcher: Broadcasting 0 events from xxxxx
              [2024-10-06 14:00:19.266] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_POWERSTATUS true
              [2024-10-06 14:00:19.268] [LOG] [MMM-Pir] [LIB] [SCREEN] [POWER] Display from false —> true
              [2024-10-06 14:00:19.273] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:20’, bar: 0 }
              [2024-10-06 14:00:20.280] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:19’, bar: 1000 }
              [2024-10-06 14:00:20.429] [LOG] {
              note_text: {
              header: ’
              text: [
              ‘â Pampers’
              [2024-10-06 14:00:20.599] [LOG] [MMM-GoogleKeep] finished running…
              [2024-10-06 14:00:20.851] [INFO] updatenotification: You are not using pm2
              [2024-10-06 14:00:21.382] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:18’, bar: 2000 }
              [2024-10-06 14:00:21.553] [INFO] xxxx
              [2024-10-06 14:00:21.768] [INFO] Calendar-Fetcher: Broadcasting 0 events from xxx
              [2024-10-06 14:00:22.405] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:17’, bar: 3000 }
              [2024-10-06 14:00:23.465] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:16’, bar: 4000 }
              [2024-10-06 14:00:23.820] [INFO] Calendar-Fetcher: Broadcasting 0 events from xxxx
              [2024-10-06 14:00:24.475] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:15’, bar: 5000 }
              [2024-10-06 14:00:25.477] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:14’, bar: 6000 }
                @Andrei-Leahu thanks. Bullseye, 64bit,
                @bugsounet will have to look at this
                bugsounetB 1 Reply Last reply Reply Quote 0
                • bugsounetB Offline
                  bugsounet Banned @sdetweil
                  @sdetweil I know but MMM-Pir v2 is under-coding
                  In all case:
                  • [MMM-Pir] [LIB] [PIR] Mode 0 Selected (onoff library) : onoff library will be removed
                  • [MMM-Pir] [LIB] [SCREEN] Mode 1: vcgencmd : vcgencmd will be removed
                    Andrei.Leahu @bugsounet
                    @bugsounet I understand, so to make it work I should use now another mode right? Thank you
                      Andrei.Leahu @Andrei.Leahu
                      so I tried xset dpms force off and on and they are working so I will use mode: 2 for the screen. Now I have this behavior for pir_mode:1 : the counter is not counting down as if the sensor is always on maybe?
                      pir_mode:2 not working. Thank you
                        jefftse
                        Did anyone get MMM-PIR-Sensor work with bookworm?
                          sdetweil @jefftse
                          @jefftse MMM-Zpir has had lots of changes recently due to bookworm
                            jefftse @sdetweil
                            @sdetweil does it still work? I can’t get it to work to save my life?
                              sdetweil @jefftse
                              @jefftse yes, the parms changed, different mode
                                sdetweil @jefftse
                                @jefftse please don’t double post. all users with reputation below 2 have their posts reviewed before they go live. this stops all the junk posts, advertising, etc
                                but sometimes the reviewers sleep. lol
                                  jefftse @sdetweil
                                  @sdetweil gotcha. can you point me the right post to fix this please?
                                    sdetweil @jefftse
                                    @jefftse i dont have THE answer
                                    see the module doc, there are lots of modes
                                    https://github.com/bugsounet/MMM-Pir
                                      jefftse @sdetweil
                                      @sdetweil thank you and i got it working!
