    MMM-Pir or MMM-PIR-Sensor
    27 Posts 6 Posters 13.1k Views 5 Watching
      svenpisa
      Next Problems on my side…
      First of all, the assignment I used:
      PIR sensor that I have connected: HC-SR505
      Pins : 2(5V) 9(Ground) 15(GPIO22)
      Raspberry Pi 3b
      The first thing I tried was https://github.com/MarcLandis/MMM-PIR-Sensor?tab=readme-ov-file on my MM.
      Installation so far ok. But when I wanted to install wiring-pi I got stuck at the following step:
      What exactly do I have to enter under ‘wiring-pi’? This is where I fail.
      Then I thought I’d give it a try with
      https://github.com/bugsounet/MMM-Pir .
      The timer also counts down nicely and switches the monitor off after 2 minutes, but the PIR doesn’t react.
        module: 'MMM-Pir',
        position: 'top_left',
          debug: false,
          delay: 2 * 60 * 1000,
          turnOffDisplay: true,
          mode: 1,
          ecoMode: true,
          displayCounter: true,
          displayBar: true,
          displayStyle: "Text",
          displayLastPresence: true,
          lastPresenceTimeFormat: "LL H:mm",
          mode6_gpio: 20,
          mode6_clearGpioValue: true,
          pir_gpio: 21,
          pir_reverseValue: false,
          xrandrForceRotation: "normal",
          wrandrForceRotation: "normal"
      I would have to
      mode6_gpio: 20, and / or pir_gpio: 21, to 15? But the PIR doesn’t react there either.
      I read somewhere that you have to “unlock” the pins first?
      Can you tell me how I can use one of the two modules?
      S mumblebajM 2 Replies Last reply
        jefftse @sdetweil
        @sdetweil thank you and i got it working!
          sdetweil @svenpisa
          @svenpisa 1st thing to do is use one of the python pir scripts to verify that the pir works, without MagicMirror involvement
          Google search how to use the PIR
            svenpisa @sdetweil
            HELP!!!
            and how do I do that?
            I just googled and came across the following page:
            https://tutorials-raspberrypi.de/raspberry-pi-bewegungsmelder-sensor-pir/?utm_content=cmp-true
            do I just need to create the file and refer to the correct pin?
            Or what exactly do I need to install?
              sdetweil @svenpisa
              @svenpisa I would go here
              https://pimylifeup.com/raspberry-pi-motion-sensor/
              • mumblebajM
                mumblebaj Module Developer @svenpisa
                @svenpisa said in MMM-Pir or MMM-PIR-Sensor:
                That is just a usage step. You can ignore that. If you ran the npm install wiring-pi then you should be all set.
                  svenpisa
                  Hi Sam, I have now taken the instructions from you
                  https://pimylifeup.com/raspberry-pi-motion-sensor/ and have gone through them step by step.
                  I am using pin 15 (Gripo22)
                  I then edited the motion_sensor.py and entered pir_sensor = 15.
                  I simply ignored the piezo =7 entry as I only want to connect the PIR. So I really only entered pir_sensor = 15.
                  I have now entered the following in Config.js
                  			module: 'MMM-Pir',
                  				debug: false,
                  				delay: 1 * 60 * 1000,
                  				mode: 1,
                  				ecoMode: true,
                  				displayBar: true,
                  				displayStyle: "SemiCircle",
                  				mode6_gpio: 22,
                  				pir_gpio: 22,
                  But I don’t have the feeling that the PIR is really reacting to my movements. I can stand in front of it or tap it with my finger, but the screen doesn’t wake up.
                  But strangely enough, the screen does wake up from time to time, which I don’t think is due to the PIR.
                  where is my mistake or am I using the following entry incorrectly? What is the purpose of the two entries?
                  				mode6_gpio: 22,
                  				pir_gpio: 22,
                  As you can see the countdown runs down and goes back to full time but I have no idea why. I don’t think it’s because of the PIR… I can fiddle with it as much as I like… The time doesn’t change
                    sdetweil @svenpisa
                    @svenpisa that is why I wanted you to run the python script outside of MagicMirror to confirm the PIR sensor is working correctly, detecting presence
                    if it doesn’t work without MagicMirror it won’t work WITH MagicMirror either.
                      svenpisa
                      I don’t understand that. I have done it exactly according to the tutorial and via
                      sudo python motion_sensor.py
                      to test the Pir. I could not recognize a new line immediately after a movement, but a line is generated every 5 seconds.
                      Since the tutorial says that the sensor waits 5 seconds until it queries again, I would have thought that it would work since the 1 is specified.
                      But now an entry is created directly every 5 seconds
                      I am open to all modules and settings to get the PIR up and running. If only I knew how to do it…
                        sdetweil @svenpisa
                        @svenpisa I don’t know exactly the problem…
                        the 5 second thing is in the code, not the PIR
                        it sounds like the pin number you are using is wrong, or the code is expecting no heat to be 0 and heat to be 1 ( pull up)
                        there are three different pin numbering orders and they are all different. sequential on the pi, and two others I can never remember.
                        until you get the python script showing motion/no motion, it cannot work under MagicMirror
                          svenpisa
                          Just for fun, I have now entered a different GPIO pin in sensor.py and started sudo python motion_sensor.py. Nothing happens here. So I have already selected the correct pin. But as you say, it’s probably the script.
                          How can I uninstall the motion sensor again? Simply delete the folder or is there a clean way?
                          I guess I’ll have to look for another solution, won’t I?
                            sdetweil @svenpisa
                            @svenpisa yes, just delete the folder
                              @svenpisa
                              see these
                              https://forums.raspberrypi.com/viewtopic.php?t=328633
                              https://projects.raspberrypi.org/en/projects/physical-computing/11
                              • A
                                Andrei.Leahu
                                I have the same problem. The Module is not working, I tried so many parameter changes. Besides that I tried to read the values of the PIR with a python script and is working. To power on/off the monitor via console is working too. I don’t know what to try else
                                  sdetweil @Andrei.Leahu
                                  @Andrei-Leahu can you show the info from npm start.
                                  Right after
                                  starting application
                                  A 1 Reply Last reply
                                  • A
                                    Andrei.Leahu @sdetweil
                                    @sdetweil Hello here is the Info Log: magicmirror@2.26.0 start
                                    [2024-10-06 14:00:06.410] [LOG] Starting MagicMirror: v2.26.0
                                    [2024-10-06 14:00:06.456] [LOG] Loading config …
                                    [2024-10-06 14:00:06.469] [LOG] config template file not exists, no envsubst
                                    [2024-10-06 14:00:07.561] [INFO] Checking config file /home/xenon/MagicMirror/config/config.js …
                                    [2024-10-06 14:00:07.688] [INFO] Your configuration file doesn’t contain syntax errors :)
                                    [2024-10-06 14:00:07.689] [INFO] Checking modules structure configuration …
                                    [2024-10-06 14:00:07.770] [INFO] Your modules structure configuration doesn’t contain errors :)
                                    [2024-10-06 14:00:08.526] [LOG] Loading module helpers …
                                    [2024-10-06 14:00:08.537] [LOG] No helper found for module: alert.
                                    [2024-10-06 14:00:08.625] [LOG] Initializing new module helper …
                                    [2024-10-06 14:00:08.626] [LOG] Module helper loaded: updatenotification
                                    [2024-10-06 14:00:08.641] [LOG] No helper found for module: clock.
                                    [2024-10-06 14:00:08.644] [LOG] No helper found for module: compliments.
                                    [2024-10-06 14:00:08.646] [LOG] No helper found for module: weather.
                                    [2024-10-06 14:00:08.726] [LOG] Initializing new module helper …
                                    [2024-10-06 14:00:08.728] [LOG] Module helper loaded: MMM-GoogleKeep
                                    [2024-10-06 14:00:08.732] [LOG] No helper found for module: MMM-CalendarExt3.
                                    [2024-10-06 14:00:09.350] [LOG] Initializing new module helper …
                                    [2024-10-06 14:00:09.351] [LOG] Module helper loaded: calendar
                                    [2024-10-06 14:00:10.016] [LOG] Initializing new module helper …
                                    [2024-10-06 14:00:10.017] [LOG] Module helper loaded: MMM-BackgroundSlideshow
                                    [2024-10-06 14:00:10.053] [LOG] Initializing new module helper …
                                    [2024-10-06 14:00:10.055] [LOG] Module helper loaded: MMM-Pir
                                    [2024-10-06 14:00:10.058] [LOG] All module helpers loaded.
                                    [2024-10-06 14:00:10.104] [LOG] Starting server on port 8080 …
                                    [2024-10-06 14:00:10.979] [LOG] Server started …
                                    [2024-10-06 14:00:10.981] [LOG] Connecting socket for: updatenotification
                                    [2024-10-06 14:00:10.983] [LOG] Starting module helper: updatenotification
                                    [2024-10-06 14:00:10.985] [LOG] Connecting socket for: MMM-GoogleKeep
                                    [2024-10-06 14:00:10.987] [LOG] [MMM-GoogleKeep_helper]:: Starting node_helper for module [MMM-GoogleKeep]
                                    [2024-10-06 14:00:10.988] [LOG] Connecting socket for: calendar
                                    [2024-10-06 14:00:11.013] [LOG] Starting node helper for: calendar
                                    [2024-10-06 14:00:11.019] [LOG] Connecting socket for: MMM-BackgroundSlideshow
                                    [2024-10-06 14:00:11.027] [LOG] Connecting socket for: MMM-Pir
                                    [2024-10-06 14:00:11.040] [LOG] Sockets connected & modules started …
                                    [2024-10-06 14:00:11.581] [LOG] Launching application.
                                    [2024-10-06 14:00:16.406] [INFO] System information:
                                    SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.2; virtual: false
                                    OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v8+
                                    VERSIONS: electron: 27.3.5; used node: 18.17.1; installed node: 20.8.0; npm: 10.9.0; pm2:
                                    OTHER: timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                                    [2024-10-06 14:00:17.370] [LOG] Create new calendarfetcher for url: xxxx- Interval: 2000
                                    [2024-10-06 14:00:17.661] [LOG] Create new calendarfetcher for url: xxxxxx - Interval: 2000
                                    [2024-10-06 14:00:17.671] [LOG] [MMM-Pir] Version: 1.5.4 rev: 240824
                                    [2024-10-06 14:00:17.680] [LOG] [MMM-Pir] [LIB] [PIR] Mode 0 Selected (onoff library)
                                    [2024-10-06 14:00:17.768] [LOG] [MMM-Pir] [CALLBACK] Pir: PIR_STARTED
                                    [2024-10-06 14:00:17.770] [LOG] [MMM-Pir] [LIB] [PIR] Started!
                                    [2024-10-06 14:00:17.773] [LOG] [MMM-Pir] [LIB] [SCREEN] Mode 1: vcgencmd
                                    [2024-10-06 14:00:17.775] [LOG] [MMM-Pir] [LIB] [SCREEN] Start.
                                    [2024-10-06 14:00:17.777] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_PRESENCE true
                                    [2024-10-06 14:00:17.806] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_SHOWING
                                    [2024-10-06 14:00:17.808] [LOG] [MMM-Pir] Started!
                                    [2024-10-06 14:00:17.812] [INFO] updatenotification: Updater Class Loaded!
                                    [2024-10-06 14:00:17.813] [INFO] updatenotification: Checking PM2 using…
                                    [2024-10-06 14:00:17.817] [INFO] Checking git for module: MMM-GoogleKeep
                                    [2024-10-06 14:00:17.873] [INFO] BACKGROUNDSLIDESHOW: Reading directory “modules/MMM-BackgroundSlideshow/exampleImages/” for images.
                                    [2024-10-06 14:00:17.877] [INFO] BACKGROUNDSLIDESHOW: 4 files found
                                    [2024-10-06 14:00:17.881] [INFO] BACKGROUNDSLIDESHOW: reading path “modules/MMM-BackgroundSlideshow/exampleImages//1.png”
                                    [2024-10-06 14:00:17.882] [LOG] resizeImages: false
                                    [2024-10-06 14:00:17.935] [INFO] Checking git for module: MMM-CalendarExt3
                                    [2024-10-06 14:00:17.958] [LOG] [MMM-Pir] [LIB] [SCREEN] Display: Force On Start
                                    [2024-10-06 14:00:17.960] [LOG] [MMM-Pir] [LIB] [SCREEN] Display ON.
                                    [2024-10-06 14:00:18.016] [INFO] Checking git for module: MMM-BackgroundSlideshow
                                    [2024-10-06 14:00:18.103] [INFO] Checking git for module: MMM-Pir
                                    [2024-10-06 14:00:18.312] [INFO] Checking git for module: MagicMirror
                                    [2024-10-06 14:00:18.632] [LOG] Stream closed.
                                    [2024-10-06 14:00:19.094] [INFO] Calendar-Fetcher: Broadcasting 0 events from xxxxx
                                    [2024-10-06 14:00:19.260] [INFO] Calendar-Fetcher: Broadcasting 0 events from xxxxx
                                    [2024-10-06 14:00:19.266] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_POWERSTATUS true
                                    [2024-10-06 14:00:19.268] [LOG] [MMM-Pir] [LIB] [SCREEN] [POWER] Display from false —> true
                                    [2024-10-06 14:00:19.273] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:20’, bar: 0 }
                                    [2024-10-06 14:00:20.280] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:19’, bar: 1000 }
                                    [2024-10-06 14:00:20.429] [LOG] {
                                    note_text: {
                                    header: ’
                                    text: [
                                    ‘â Pampers’
                                    [2024-10-06 14:00:20.599] [LOG] [MMM-GoogleKeep] finished running…
                                    [2024-10-06 14:00:20.851] [INFO] updatenotification: You are not using pm2
                                    [2024-10-06 14:00:21.382] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:18’, bar: 2000 }
                                    [2024-10-06 14:00:21.553] [INFO] xxxx
                                    [2024-10-06 14:00:21.768] [INFO] Calendar-Fetcher: Broadcasting 0 events from xxx
                                    [2024-10-06 14:00:22.405] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:17’, bar: 3000 }
                                    [2024-10-06 14:00:23.465] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:16’, bar: 4000 }
                                    [2024-10-06 14:00:23.820] [INFO] Calendar-Fetcher: Broadcasting 0 events from xxxx
                                    [2024-10-06 14:00:24.475] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:15’, bar: 5000 }
                                    [2024-10-06 14:00:25.477] [LOG] [MMM-Pir] [CALLBACK] Screen: SCREEN_OUTPUT { timer: ‘00:14’, bar: 6000 }
                                      @Andrei-Leahu thanks. Bullseye, 64bit,
                                      @bugsounet will have to look at this
                                      bugsounetB 1 Reply Last reply
                                      • bugsounetB
                                        bugsounet Banned @sdetweil
                                        @sdetweil I know but MMM-Pir v2 is under-coding
                                        In all case:
                                        • [MMM-Pir] [LIB] [PIR] Mode 0 Selected (onoff library) : onoff library will be removed
                                        • [MMM-Pir] [LIB] [SCREEN] Mode 1: vcgencmd : vcgencmd will be removed
                                        • A
                                          Andrei.Leahu @bugsounet
                                          @bugsounet I understand, so to make it work I should use now another mode right? Thank you
                                          • A
                                            Andrei.Leahu @Andrei.Leahu
                                            so I tried xset dpms force off and on and they are working so I will use mode: 2 for the screen. Now I have this behavior for pir_mode:1 : the counter is not counting down as if the sensor is always on maybe?
                                            pir_mode:2 not working. Thank you
                                              jefftse
                                              Did anyone get MMM-PIR-Sensor work with bookworm?
