    Touchscreen Family Dashboard
    touchscreentouch
    51 Posts 26 Posters 45.6k Views 44 Watching
    • E Offline
      elwood1982uk @wswenson
      @wswenson @tjat i’d also love to see the original files. I’m very much a noob here. I’ve tried downloading and installing all the modules but it just looks like the default mm screen -how do I configure/edit to look like yours, etc, please?
      • E Offline
        elwood1982uk @roysim11
        Man I thought I was the only person on the internet who wanted a family dashboard that was interactive (ie to enter events on Google calendar -not just view them!). I’ve got the RPI and touch screen (Hannspree 23") sorted but with no real knowledge of coding or magic mirror modules was at a loss. I will be looking through your posts/git in more detail then I next get time! Thanks!
          mdiorio @elwood1982uk
          @elwood1982uk
          I was having issues with the calendar swipe feature not working. The keypress would work fine though. Looks like the new version of Electron has removed touchevents and changed to pointerdown and pointerup.
          I forked the original and made the changes: https://github.com/B3DTech/MMM-KeyPress
          I’m looking at cleaning up code in the add event module to remove some of the hard-coded customizations in the original. They are very much customized to the original creator with family names and icons hard coded. For the most part, that isn’t needed in a general framework for just adding events.
          I am also looking at merging the code into the latest version of MMM-CalendarExt3 since it’s so far behind now.
          It’s a slow work in progress. If anyone else has some time and wants to help out let me know.
            sdetweil @mdiorio
            @mdiorio electron still will provide touch events provided the underlying screen service does…
            did you change OS levels since it last appeared to work?
            they have changed the window manager twice in the last year.
            Original was X11
            last year introduced Wayland
            this Oct introduced Labwc
              mdiorio @sdetweil
              @sdetweil said in Touchscreen Family Dashboard:
              First time I’m using it is this week, so it would appear I’m using labwc.
              All I know is that the old KeyPress module wasn’t working and doing a console debug in electron was showing no touchevents being sent, only pointer events.
                sdetweil @mdiorio
                @mdiorio you can change back to x11 using the raspi-config app
                  mdiorio @sdetweil
                  @sdetweil Why would I change back when my code works with the current version. General concept MM should be don’t require a crap ton of customization just to make it work. Making users who may want to use this switch to a different windowing system doesn’t really make sense. Especially since I’m sure RPi will eventually remove X11.
                    sdetweil @mdiorio
                    @mdiorio because it is new and not working in many cases yet
                    if you want it to work now, your only choice is to move back
                    you said your code does not work, touch doesnt
                    • E Offline
                      elwood1982uk
                      Hi all. Back after Xmas break. I’m still very new to this and not entirely sure where to begin. Before Xmas I tried downloading the files provided (thanks!) but can’t get it to work. Any chance of a noob walkthrough or a link to somewhere that will tell me how to add the modules and get a working touch calendar? Thanks!
                      • L Offline
                        linkiln @elwood1982uk
                        @elwood1982uk Hi, I’ve got similar problem with touch callendar. I’ve made two changes in https://github.com/B3DTech/MMM-KeyPress module.
                        In node_helper.js:
                        step: (direction === “ArrowRight” ? 3 : -3) // 1 to move forward, -1 to move backward
                        to:
                        step: (direction === “ArrowRight” ? 1 : -1) // 1 to move forward, -1 to move backward
                        and second thing uncomment:
                        // this.sendNotification(‘CX3_GLANCE_CALENDAR’, payload);
                        After this changes changing calendar start working with touch.
                        • 3 / 6
