scaling gone wonky
16 Posts 4 Posters 1.5k Views 4 Watching
    cyclonej
    I am new to Raspberry Pi and MM and CSS and Github. I am running MM v2.29.0 on a Raspberry Pi 5. I am using MMM-CalendarExt2 to show my current month calendar in bottom of screen and upcoming stuff in upper left. Basically took the example from MMM-CalendarExt2 and stripped out some.
    I had my MM looking great a few days ago. All of the sudden after booting up and launching, my MM looks awful. The modules are overlapping. No idea how this happened. The main calendar, which is set for bottom_bar, is taking up the while screen.
    I have the browser set to 100% size, which I think should be normal. Whether running in Firefox or Chromium , MM looks equally bad.
    I recently enabled VNC to remotely control the Pi from my regular Windows laptop. I would not expect this to affect scaling of modules.
    Troubleshooting I have done so far:
    I tested disabling VNC temporarily, which had not effect on MM.
    I reverted back to the default config.js and custom.css, then rebuilt my layout from scratch. It still looks awful.
    I tested with varying zoom in firefox. While this did change the look, it still looked bad no matter what zoom was set to. At 50% zoom, the overlap is gone, but text is too small to read. At >100% zoom, it looks soooo bad.
    I have no idea is this issue is in MM or in the OS (Raspberry Pi OS).
    Here is my config.js:
    /* Config Sample
     * see https://docs.magicmirror.builders/configuration/introduction.html
     * and https://docs.magicmirror.builders/modules/configuration.html
     * You can use environment variables using a `config.js.template` file instead of `config.js`
     * which will be converted to `config.js` while starting. For more information
     * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
    let config = {
    	address: "localhost",	// Address to listen on, can be:
    	port: 8080,
    	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
    	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
    	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
    	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
    	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
    	language: "en",
    	locale: "en-US",
    	timeFormat: 12,
    	units: "imperial",
    			module: "alert",
    			module: "updatenotification",
    			position: "top_bar"
    			module: "clock",
    			position: "top_left"
    			module: "weather",
    				weatherProvider: "openmeteo",
    				type: "current",
    				lat: 40.776676,
    				lon: -73.971321
    		    module: 'MMM-CalendarExt2',
    			rotateInterval: 60*1000,
    			deduplicateEventsOn: ["title","startDate","endDate"],
    			scenes:[
    				views: ["current","upcoming","Overview Private"],
    			views:[
    				    mode: "current",
    				    maxDays: 1,
    				    locale: "en",
    				    hideOverflow: false,
    				    filterPassedEvent: false,
    				mode: "upcoming",
    				maxDays: 5,
    				locale: "en",
    				useEventTimeRelative: false,
    				name: "Overview Private",
    				title: "Family Calendars",
    				mode: "month",
    				type: "row",
    				position: "bottom_bar",
    				slotCount: 7,
    				locale: "en",
    				calendars: [],
    						icon: "mdi:calendar-star",
    						maxItems: 100,
    						scanInterval: 1000*60*30,
    						beforeDays: 30,
    						afterDays: 90,
    						url: "REDACTED",
    						icon: "mdi:birthday-cake-outline",
    						maxItems: 100,
    						beforeDays: 30,
    						afterDays: 90,
    						url: "REDACTED",
    						icon: "mdi:google",
    						maxItems: 100,
    						beforeDays: 30,
    						afterDays: 90,
    						url: "REDACTED",
    						icon: "hugeicons:garbage-truck",
    						maxItems: 100,
    						beforeDays: 30,
    						afterDays: 90,
    						url: "REDACTED",
    						filter: (event) => {
    						  if (event.title == "PTO") {
    						    return true
    						  if (event.title == "Payday") {
    						    return true
    						  return false
    						icon: "mdi:basketball",
    						maxItems: 100,
    						beforeDays: 30,
    						afterDays: 90,
    						url: "REDACTED",
    						  if (event.title == "End Date") {
    						    return false
    						  return true
    						icon: "fa6-solid:school-circle-xmark",
    						maxItems: 100,
    						beforeDays: 30,
    						afterDays: 90,
    						url: "REDACTED",
    						icon: "maki:school",
    						maxItems: 100,
    						beforeDays: 30,
    						afterDays: 90,
    						url: "REDACTED",
    						  if (event.title == "Kwanzaa") {
    						    return false
    						  if (event.title == "Hanukkah") {
    						    return false
    						  return true
    						icon: "fa6-solid:school-circle-exclamation",
    						maxItems: 100,
    						beforeDays: 30,
    						afterDays: 90,
    						url: "REDACTED",
    my custom.css
    /* Custom CSS Sample
     * Change color and fonts here.
     * Beware that properties cannot be unitless, so for example write '--gap-body: 0px;' instead of just '--gap-body: 0;'
    /* Uncomment and adjust accordingly if you want to import another font from the google-fonts-api: */
    /* @import url('https://fonts.googleapis.com/css2?family=Poppins:wght@100;300;400;700&display=swap'); */
    :root {
      --color-text: #999;
      --color-text-dimmed: #666;
      --color-text-bright: #fff;
      --color-background: black;
      --font-primary: "Roboto Condensed";
      --font-secondary: "Roboto";
      --font-size: 20px;
      --font-size-small: 0.75rem;
      --gap-body-top: 60px;
      --gap-body-right: 60px;
      --gap-body-bottom: 60px;
      --gap-body-left: 60px;
      --gap-modules: 30px;
    .wi-day-sunny {
      color: #ffff00;
    .CX2 .event[data-calendar-name="Birthdays"] {
      /*color: #ce4138;*/
      border-left: #ce4138 solid;
    .CX2 .event[data-calendar-name="Paradigm"] {
      /*color: #c632ff;*/
      border-left: #2cb825 solid;
    S M 2 Replies Last reply Dec 25, 2024, 3:09 AM Reply Quote 0
      sdetweil @cyclonej
      @cyclonej horizontal/landscape mode, MagicMirror is designed for 1920x1080
      so in portrait mode it should be 1080x1920
      C 1 Reply Last reply Dec 25, 2024, 7:04 PM Reply Quote 0
        sdetweil @cyclonej
        @cyclonej i dont know. ext2 has been replaced by the ext3 family a couple years ago
        they use the default calendar module to get data, which then broadcasts it to other modules just comment out the default cal position to have it not show on the screen.
        C 1 Reply Last reply Dec 25, 2024, 3:16 AM Reply Quote 0
          cyclonej @sdetweil
          @sdetweil said in scaling gone wonky:
          I used MMM-CalendarExt2 because I liked the look in the sample better than the one in Ext3. This meant less work for me to do to get the look I was after.
          I do not have the default calendar module included in my config.js (I assume you mean the MM-supplied calendar module).
          S M 2 Replies Last reply Dec 25, 2024, 4:05 AM Reply Quote 0
            sdetweil @cyclonej
            @cyclonej correct, the calendar module supplied with MagicMirror.
            i understand, just realize the author has stopped making updates, although he may be able to guide you.
            C 1 Reply Last reply Dec 25, 2024, 4:55 AM Reply Quote 0
              cyclonej @sdetweil
              I went ahead and installed Ext3. This looks just as bad as Ext2. The calendar is occupying the whole screen. I think something has gone arwy in MM. Normal websites look fine. Its just in the MM page that the calendar is too big and i guess the date/time and weather information seem larger/wider than they should be.
              In case I forgot to mention earlier, I have my display in portrait orientation
              new config.js
              /* Config Sample
              let config = {
              	port: 8080,
              	language: "en",
              	locale: "en-US",
              	timeFormat: 12,
              	units: "imperial",
              			module: "alert",
              			position: "top_bar"
              			module: "clock",
              			module: "weather",
              				type: "current",
              				lat: REDACTED
              				lon: REDACTED
              			header: "REDACTED",
              						symbol: "calendar-xmark",
              						coloredBackground: true,
              						bgColor: "white",
              						url: "REDACTED",
              						symbol: "cake-candles",
              						bgColor: "white",
              						url: "REDACTED",
              						symbol: "google",
              						bgColor: "white",
              						url: "REDACTED",
              						symbol: "truck",
              						bgColor: "green",
              						url: "REDACTED",
              						symbol: "basketball",
              						bgColor: "orange",
              						url: "REDACTED",
              						symbol: "school-circle-xmark",
              						bgColor: "red",
              						url: "REDACTED",
              						symbol: "school",
              						bgColor: "blue",
              						url: "REDACTED",
              						symbol: "school-circle-exclamation",
              						bgColor: "white",
              						url: "REDACTED",
              			module: "MMM-CalendarExt3",
              			title: "",
              				mode: "month",
              				instanceId: "basicCalendar",
              				locale: 'en-US',
              				maxEventLines: 7,
              				firstDayOfWeek: 1,
              				calendarSet: [],
                mumblebaj Module Developer @cyclonej
                @cyclonej Seems like a default screen resolution issue for me as some of the other modules are overlapping as well and they look unusually big. Suggest you try a different resolution setting and see if that resolves?
                  MMRIZE @cyclonej
                  @cyclonej
                  Show me the whole screen capture. And what resolution the screen has?
                  C 1 Reply Last reply Dec 25, 2024, 6:08 PM Reply Quote 0
                    cyclonej @MMRIZE
                    @MMRIZE
                    Currently 1024x768, maximum allowed.
                    S 1 Reply Last reply Dec 25, 2024, 6:45 PM Reply Quote 0
                      sdetweil @cyclonej
                        cyclonej @sdetweil
                        I am marking this as solved. I think when I first booted up the Raspberry Pi, the resolution was 1920x1080. I am not sure what is preventing from going to that resolution now. That is where I will focus my troubleshooting.
                        Thanks all for the assistance.
                        C 1 Reply Last reply Dec 25, 2024, 10:04 PM Reply Quote 0
                        • C cyclonej has marked this topic as solved on Dec 25, 2024, 7:04 PM
