    Stop and Start MM on a schedule
    13 Posts 4 Posters 4.2k Views 4 Watching
    • plainbrokeP Offline
      plainbroke
      How do I get MM to Start and Stop on a schedule?
      I am running Bookworm 64bit and MM v2.29
      This is what used to work in buster 32bit and MM v2.15
      in my crontab -e
      # Turn off display Sunday - Thursday at 21h45
      15 21 * * 0-4 pm2 stop all
      # Turn off display Friday - Saturday at 23h45
      45 21 * * 5,6 pm2 stop all
      # Turn on screen Monday - Friday at 7h00
      00 07 * * 1-5 pm2 start mm
      # Turn on screen Saturday - Sunday at 8h00
      00 08 * * 6,0 pm2 start mm
      It doesnt work anymore.
      Can someone explain why it doesnt work anymore and how to fix it.
      S D 3 Replies Last reply Reply Quote 0
        sdetweil @plainbroke
        @plainbroke cron typically runs as root, but the pm2 info was saved under some user
        you can specify the username in crontab somehow
          @plainbroke see
          https://serverfault.com/questions/352835/crontab-running-as-a-specific-user
            @plainbroke does pm2 launch from cron?
              DarrenO 0 @plainbroke
              @plainbroke Are you running from a Pi?
              I used to have scheduled on/off times like this and I used to turn on/off the HDMI port of the Pi at the specified times.
              As the screen I had it attached to no longer detected an output source, it would then go into sleep mode until the assigned time the script enabled the HDMI interface again.
              I don’t recall the actual command/settings I used to do it, but it was similar to :
              // To turn off
              xrandr --output HDMI-1 --off
              //to turn on.
              xrandr --output HDMI-1 --auto
              • mumblebajM Offline
                mumblebaj Module Developer @DarrenO 0
                @DarrenO-0 I would suggest having a look at the following post I created. I use it to turn my monitor on and off at scheduled times. Not restarting the Pi though.
                https://forum.magicmirror.builders/topic/19116/having-trouble-with-screen-on-and-off-here-are-some-tips-that-could-help?_=1735999238062
                  plainbroke @mumblebaj
                  @mumblebaj
                  Not wanting to turn off the screen, simply because it is a pain to reach the power button to turn it back on, and no remote to get into setup of the TV it was a $40 used tv I bought. it works but I just leave it on and stop MM with a black screen and and the bar in black with bright green letters. It is very very dim. I am going to add the
                  user pi and the path home/pi to the cron job and see what happens.
                  Thanks for the links
                  All of you.
                  not sure yet if pm2 is working in cron?
                  hoping the change will work.
                  plainbrokeP S 2 Replies Last reply Reply Quote 0
                    plainbroke @plainbroke
                    @DarrenO-0
                    @mumblebaj
                    Is there a way to run a cron job?
                    I have done a few google searches with no results that worked.
                      @plainbroke said in Stop and Start MM on a schedule:
                      has to be run as user that stored the config,. when pm2 save is done
                      cause that info is store in the users .pm2 folder, ~/.pm2
                      so if the cron job runs as user… oops…
                      so you might be able to use this, a trick I have in another app…
                      user=????username????
                      sudo -u $user pm2 start app_name or number
                      this lets you sneak into user mode for one command
                      so my username is sam,
                      for example, stop my mm app
                      sudo -u sam pm2 stop 7
                        plainbroke @sdetweil
                        I think adding the user pi /home/pi/pm2 stop all
                        worked but I am using your update script right now.
                        So not sure which one stopped MagicMirror.
                        The dang mouse arrow is on the screen, so I will have to find that command to hide it now…
                          @plainbroke for the mouse pounter, install unclutter, have to reboot after, sometime
                          sudo apt install unclutter
                          but it SHOULD have been hidden already
                          pm2 status
                          will show you the apps
                          pm2 --help
                          will show you all it can do (a lot!)
                          yes, my upgrade script stops MM under pm2…
                            Not sure why but unclutter was not installed.
                            It is now and the mouse pointer went away with a reboot.
                            This is all a fresh install in December when I loaded bookworm and 2.29 Then reloaded all the modules using your backup/restore scripts… Sure makes things easier, for sure.
                            Maybe you can add a check for unclutter in your script ???
                            I thought it was on your script page with pm2 repair and the update scripts.
                            But did not find it there, tonight. Could have been there, I have not been nearly as on my game since my son passed the end of October. 11 days after his 42nd Birthday. I am still a little in denial 69 days later… It will be strange driving 10 hrs to see my Grand kids and my Daughter in law without him there to talk to ect…
                            Sorry for the rambling. Kind of my thing right now . Plus my dang Computer went down and took a week to get back up. I now have a working backup for it also…
                            Time for me to get to bed. We are expecting 6" to a foot of snow over the next 24 hrs… Fun Fun Fun.
                              @plainbroke my condolences… may his memory bring you joy.
                              I haven’t installed unclutter in years, until last month on another system where the cursor finally bugged me… been like that for a year.
                              I don’t know the reason for needing it, unless someone edits main.css and comments out
                              cursor:none;
                              so, theres that… safe travels…
