    MMM-CalendarExt3 not showing events on calendar, but does on list after 2.30 update
    37 Posts 5 Posters 16.6k Views 6 Watching
      sdetweil @tke499
      @tke499 what is the settings in the default calendar,
      xxx out your url
      set :maximumEvents:100,
      • T Offline
        tke499 @sdetweil
        @sdetweil I set it to 100. The events now show up, but low the list on the side goes to the bottom of the screen. Not the desired effect.
          sdetweil @tke499
          @tke499 use limitdays
          there are 50 knobs to adjust
            sdetweil @tke499
            @tke499 you can try maximumEvents:12 or 15
            there is also a way with css. i will test and document in a little while
            this should hide more than 10 events in the default calendar
            in custom.css
            .calendar table tr:nth-child(n+10) {
              display: none;
            S NiggichN 2 Replies Last reply Reply Quote 0
              @tke499 I have confirmed the css approach works…
              in ~/MagicMirror/css/.custom.css
              .calendar table tr:nth-child(n+10) {  /* 10 is the number of rows you want showing */
                        display: none;
              I have maximumEvents:200
              and only 10 lines show with the css posted
              without it, it goes to the bottom of the screen
              • NiggichN Offline
                Niggich @sdetweil
                @sdetweil thx this is working for me, but now the events doesn’t fade out… any solution?
                • T Offline
                  tke499 @sdetweil
                  @sdetweil this works, just no fade. Thanks
                    sdetweil @tke499
                    @tke499 yeh, fade is calculated based on the size of the list (200 in my case)
                    and the fade starts at 100, oops… cut off at 10…
                    fadepoint can get you a different start spot, BUT, its also changes the amount of fade (start at .02 (4 =line 4) BUT there are 196 steps in the fade, so I don’t see much…
                    looking thru the code, I don’t see any difference in the event broadcast
                      sdetweil @tke499
                      @tke499 i’ll give you a hack til next release
                      in ~/MagicMirror/modules/default/calendar.js
                      add this line
                      		fadePoint: 0.25, // Start on 1/4th of the list.  line 25
                      		fadeSteps:0,  // ------- this one
                      and
                      			startFade = events.length * this.config.fadePoint;   // line 255 after above added
                      			fadeSteps = events.length - startFade;
                      			if(this.config.fadeSteps)                  /* these two */
                      				fadeSteps=this.config.fadeSteps
                      then in your config.js calendar
                                fade:true,
                                fadePoint:0.02,   //  use this to get into the top 10 (my 200 list gets to number 4)
                                fadeSteps:6,         // use this to decide how many steps from full to gone
                      T C 2 Replies Last reply Reply Quote 0
                      • T Offline
                        tke499 @sdetweil
                        @sdetweil Thanks. Do we know why this is happening with this release? Assuming it had to do with the calendar update.
                          sdetweil @tke499
                          @tke499 I do not yet… I checked the code that sends the list to other modules and I don’t SEE anything … ps, I personally did all the calendar updates
                          both versions clip the list to the config.maxEvents: value. (10 default in both)
                            @tke499 looking at the code again, there WAS a bug in prior releases, where
                            you COULD specify to limit the number of entries produced BY calendar
                                   url: "some cal url",
                                   maximumEntries:xxx   // default whatever the base config has for this property
                            so, I added code to fix that bug
                            SO, if one does NOT specify maximumEntries in the cal url section,
                            it will clip to the default value,
                            which it did NOT DO before…
                            the prior bug was maxEvents said 100 (including old)
                            1st cal contributed 20
                            2nd cal contributed 100
                            3rd cal contributed 5
                            1st 100 (maxEvents) is returned… so none of cal 3 got processed…
                            the code and limits were present in prior release, just not the clipping
                            • T Offline
                              tke499 @sdetweil
                              @sdetweil so I am assuming that I should just keep the coding you provided earlier correct?
                                sdetweil @tke499
                                @tke499
                                if it works for you
                                yes, next release is April 1
                                • T Offline
                                  tke499 @sdetweil
                                  @sdetweil appreciate being patient with me. Thanks again. I made this MM for my wife for Christmas and it has fought me every single step.
                                    sdetweil @tke499
                                    @tke499 no problem… been there , done that…
                                    thats why I do the install/upgrade, and backup/restore scripts,
                                    and look for other ways to make the core functions easier to use
                                      Como @sdetweil
                                      @sdetweil Wondering if this hack would work for MMM-CalendarExt3Agenda? Had half my calendars stop showing events today (the ones that have the most events in them, oddly 2 of the calendars that only have 1 or 2 events are still showing). I confirmed that the events still show in the default calendar module. I also tried the troubleshooting steps listed previously in the thread (pulling the latest from git and npm install) but no luck.
                                      Thanks as always!
                                        sdetweil @Como
                                        @Como yes, all the ext3 modules get the data from the same place
                                          Como @sdetweil
                                          @sdetweil so I actually read through your posts again and saw the comment regarding the max entries. I ended up increasing the default 100 to 1000 and it the module is working as expected.
                                            sdetweil @Como
                                            @Como cool in general w ext3 family you set maxevents up as it can display events in the past. which the default calendar doesn’t do
