    MMM-CalendarExt3 not showing events on calendar, but does on list after 2.30 update
    37 Posts 5 Posters 17.0k Views 6 Watching
      sdetweil @tke499
      @tke499 i’ll give you a hack til next release
      in ~/MagicMirror/modules/default/calendar.js
      add this line
      		fadePoint: 0.25, // Start on 1/4th of the list.  line 25
      		fadeSteps:0,  // ------- this one
      and
      			startFade = events.length * this.config.fadePoint;   // line 255 after above added
      			fadeSteps = events.length - startFade;
      			if(this.config.fadeSteps)                  /* these two */
      				fadeSteps=this.config.fadeSteps
      then in your config.js calendar
                fade:true,
                fadePoint:0.02,   //  use this to get into the top 10 (my 200 list gets to number 4)
                fadeSteps:6,         // use this to decide how many steps from full to gone
      T C 2 Replies Last reply Reply Quote 0
      • T
        tke499 @sdetweil
        @sdetweil Thanks. Do we know why this is happening with this release? Assuming it had to do with the calendar update.
          sdetweil @tke499
          @tke499 I do not yet… I checked the code that sends the list to other modules and I don’t SEE anything … ps, I personally did all the calendar updates
          both versions clip the list to the config.maxEvents: value. (10 default in both)
            @tke499 looking at the code again, there WAS a bug in prior releases, where
            you COULD specify to limit the number of entries produced BY calendar
                   url: "some cal url",
                   maximumEntries:xxx   // default whatever the base config has for this property
            so, I added code to fix that bug
            SO, if one does NOT specify maximumEntries in the cal url section,
            it will clip to the default value,
            which it did NOT DO before…
            the prior bug was maxEvents said 100 (including old)
            1st cal contributed 20
            2nd cal contributed 100
            3rd cal contributed 5
            1st 100 (maxEvents) is returned… so none of cal 3 got processed…
            the code and limits were present in prior release, just not the clipping
            • T
              tke499 @sdetweil
              @sdetweil so I am assuming that I should just keep the coding you provided earlier correct?
                sdetweil @tke499
                @tke499
                if it works for you
                yes, next release is April 1
                • T
                  tke499 @sdetweil
                  @sdetweil appreciate being patient with me. Thanks again. I made this MM for my wife for Christmas and it has fought me every single step.
                    sdetweil @tke499
                    @tke499 no problem… been there , done that…
                    thats why I do the install/upgrade, and backup/restore scripts,
                    and look for other ways to make the core functions easier to use
                      Como @sdetweil
                      @sdetweil Wondering if this hack would work for MMM-CalendarExt3Agenda? Had half my calendars stop showing events today (the ones that have the most events in them, oddly 2 of the calendars that only have 1 or 2 events are still showing). I confirmed that the events still show in the default calendar module. I also tried the troubleshooting steps listed previously in the thread (pulling the latest from git and npm install) but no luck.
                      Thanks as always!
                        sdetweil @Como
                        @Como yes, all the ext3 modules get the data from the same place
                          Como @sdetweil
                          @sdetweil so I actually read through your posts again and saw the comment regarding the max entries. I ended up increasing the default 100 to 1000 and it the module is working as expected.
                            sdetweil @Como
                            @Como cool in general w ext3 family you set maxevents up as it can display events in the past. which the default calendar doesn’t do
                              @Como @Niggich @tke499 @MMRIZE
                              apply this fix
                              see
                              https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
                              NiggichN 1 Reply Last reply Reply Quote 0
                              • NiggichN
                                Niggich @sdetweil
                                @sdetweil THX a lot! This fix is working… it is fading out and it’s showing the events at CX3…
