    Can't get mmm-calendarext3 - customEvents to display the changed events, or more than 9 days.
    21 Posts 2 Posters 4.2k Views 2 Watching
      sdetweil @cheminge
      @cheminge is this the latest MM release??
      did you install the broadcast clipping fix??
      https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
      also, please use the code block for any config/logs…
      paste text into editor
      select pasted text
      hit the </> button
        sdetweil @cheminge
        @cheminge said in Can't get mmm-calendarext3 - customEvents to display the changed events, or more than 9 days.:
        customEvents: [{keyword: “1 - Unit”, symbol: “fire-extinguisher”, color: “red”}, {keyword: “2 - Unit”, symbol: “fire-extinguisher”, color: “green”}, {keyword: “3 - Unit”, symbol: “fire-extinguisher”, color: “blue”}],
        those would only change the events in the calendar UI. not in Ext3…
        and you are not showing the default calendar (no position setting)
          cheminge @sdetweil
          Yes, I am running the latest mmm-calendarext3, but I also ran the script as suggested. “Already up to date” comes up when I run the update for mmm-calendarext3.
          The EXT3 does show the color and symbol, but not the CustomEvents. Is this because EXT3 doesn’t support that function?
          I just did the broadcast clipping fix and I am still having the two problems.
          I have other pages that show other calendarEXT3, and they seem to be working, I just left them out as they are not having these issues, so I made a simple config file with just this calendar, and it is still the same result.
            sdetweil @cheminge
            @cheminge customevents in the default calendar is done at the UI , long after the events are broadcast
            in Ext3 there it the eventtransformer () function to allow you to
            manipulate the events before they appear
            if you look at this person’s Ext3 config here
            https://forum.magicmirror.builders/post/122721
            you will see an example of that function in the Ext3 config
              cheminge
              Thank you!!!
              I now have the color and symbol working!!!
              now, onto issue number 2. how do I get it to show more of the events?
                sdetweil @cheminge
                @cheminge did you put on the fix as I asked before… this is not an EXT3 fix, its a base MM fix
                see https://forum.magicmirror.builders/post/122703
                  cheminge @sdetweil
                  Ok,
                  After some deep diving I realized I have broadcastPastEvents: true, in the wrong location in my config file.
                  I moved it down to be inside the “config” location and it now works!
                  Do I need to move the other items inside of the “config” location?
                  	{module: "calendar",
                  			fade: false,
                                          flipDateHeaderTitle: true,
                                          hideDuplicates: true,
                                          coloredText: true,
                                          coloredBackground: false,
                                          coloredSymbol: true,
                  			pastDaysCount: 90,
                  			wrapEvents: true,
                  			updateOnFetch: true,
                  			colored: true,
                  						url: "https://**My Google Calendar Link**.ics",
                  						symbol: "person-military-to-person",
                  						className: "**ClassName**",
                  						beforeDays: 30,
                  						afterDays: 90,
                  						maximumEntries: 100,
                  						pastDaysCount: 40,
                  						color: "green",
                  						fetchInterval: 60000, //900000 is 15 minuets
                    sdetweil @cheminge
                    @cheminge yes
                    everything BEFORE config:{
                    belongs to Magicmirror, and the module will not see it
                    ONLY stuff inside config goes to the module
                    config:{
                    ..... here
                    see
                    https://docs.magicmirror.builders/modules/configuration.html#example
                      sdetweil @cheminge
                      @cheminge did you get it working?
                        cheminge @sdetweil
                        Everything seems to be working, but I am having one issue.
                        I have repeating events, that are “All Day” events.
                        Then the week of the event I change the event on the google calendar to be for a specific time of day.
                        When I do this, I see both the repeating “All Day” and the Specific time events. (so double events on the same day) It also doesn’t read the new times that I have put into the google calendar.
                        I don’t even know where to start to look for a solution for this.
                        Attached is a screen shot of the calendar, and for example, on January 28, all 3 are duplicate entries.
