    Can't get mmm-calendarext3 - customEvents to display the changed events, or more than 9 days.
    21 Posts 2 Posters 7.2k Views 2 Watching
      cheminge
      I am working on my very first MagicMirror, and I am having a few issues with this 3rd party module.
      If anyone can help, I am having trouble with the customEvents section to show different color for different summary of a calendar event.
      I have 2 problems,
      1.) doesn’t change the color or symbol of the entry,
      2.) I can only see yesterday, and 8 days in the future. I wanted to be able to see the entire month if possible (from the 1st to the 31st) (or even the days that are currently showing on the one month screen).
      This is what I have in my config file:
      let config = {
      	address: "localhost",	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
      	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
      	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
      	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
      	language: "en",
      	locale: "en-US",
      	logLevel: ["ERROR", "WARN", "INFO", "LOG"], // Add "DEBUG",  for even more logging
      	timeFormat: 12,
      	units: "imperial",
      	showPeriod: "true",
      	{module: "calendar",
      			fade: false,
      //            maximumEntries: 10,
      //            maximumNumberOfDays: 3,
                  flipDateHeaderTitle: true,
      			broadcastPastEvents: true,
                  hideDuplicates: true,
                  coloredText: true,
                  coloredBackground: false,
                  coloredSymbol: true,
      			pastDaysCount: 35,
      			wrapEvents: true,
      						url: "https://calendar.google.com/calendar.... someurl,
      						symbol: "fire-extinguisher",
      						className: "Unit Days",
      						beforeDays: 60,
      						afterDays: 180,
      						color: "orange",
      						fetchInterval: 60000, //900000 is 15 minuets
      				customEvents: [{keyword: "1 - Unit", symbol: "fire-extinguisher", color: "red"}, {keyword: "2 - Unit", symbol: "fire-extinguisher", color: "green"}, {keyword: "3 - Unit", symbol: "fire-extinguisher", color: "blue"}],
      	{module: "MMM-CalendarExt3",
      			pages: {"ATFD - Work Calendar": "middle_center"},
      			position: "middle_center",
      				mode: "month",
      				firstDayOfWeek: 0,
      				locale:'en-US',
      				headerTitleOptions: {month: 'long'},
      				fontSize: "20px",
      				eventHeight: "22px",
      				maxEventLines: "6",
      				useWeather: false,
      				displayLegend: true,
      				useIconify: true,
      				calendarSet: ["ATFD 3 Unit", "Unit Days"],
      S 2 Replies Last reply
        sdetweil @cheminge
        @cheminge is this the latest MM release??
        did you install the broadcast clipping fix??
        https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
        also, please use the code block for any config/logs…
        paste text into editor
        select pasted text
        hit the </> button
          sdetweil @cheminge
          @cheminge said in Can't get mmm-calendarext3 - customEvents to display the changed events, or more than 9 days.:
          customEvents: [{keyword: “1 - Unit”, symbol: “fire-extinguisher”, color: “red”}, {keyword: “2 - Unit”, symbol: “fire-extinguisher”, color: “green”}, {keyword: “3 - Unit”, symbol: “fire-extinguisher”, color: “blue”}],
          those would only change the events in the calendar UI. not in Ext3…
          and you are not showing the default calendar (no position setting)
          C 1 Reply Last reply
            cheminge @sdetweil
            Yes, I am running the latest mmm-calendarext3, but I also ran the script as suggested. “Already up to date” comes up when I run the update for mmm-calendarext3.
            The EXT3 does show the color and symbol, but not the CustomEvents. Is this because EXT3 doesn’t support that function?
            I just did the broadcast clipping fix and I am still having the two problems.
            I have other pages that show other calendarEXT3, and they seem to be working, I just left them out as they are not having these issues, so I made a simple config file with just this calendar, and it is still the same result.
              sdetweil @cheminge
              @cheminge customevents in the default calendar is done at the UI , long after the events are broadcast
              in Ext3 there it the eventtransformer () function to allow you to
              manipulate the events before they appear
              if you look at this person’s Ext3 config here
              https://forum.magicmirror.builders/post/122721
              you will see an example of that function in the Ext3 config
                cheminge
                Thank you!!!
                I now have the color and symbol working!!!
                now, onto issue number 2. how do I get it to show more of the events?
                  sdetweil @cheminge
                  @cheminge did you put on the fix as I asked before… this is not an EXT3 fix, its a base MM fix
                  see https://forum.magicmirror.builders/post/122703
                    cheminge @sdetweil
                    Ok,
                    After some deep diving I realized I have broadcastPastEvents: true, in the wrong location in my config file.
                    I moved it down to be inside the “config” location and it now works!
                    Do I need to move the other items inside of the “config” location?
                    			fade: false,
                                            coloredText: true,
                    			pastDaysCount: 90,
                    			wrapEvents: true,
                    			updateOnFetch: true,
                    			colored: true,
                    						url: "https://**My Google Calendar Link**.ics",
                    						symbol: "person-military-to-person",
                    						className: "**ClassName**",
                    						beforeDays: 30,
                    						afterDays: 90,
                    						maximumEntries: 100,
                    						pastDaysCount: 40,
                    						color: "green",
                      sdetweil @cheminge
                      @cheminge yes
                      everything BEFORE config:{
                      belongs to Magicmirror, and the module will not see it
                      ONLY stuff inside config goes to the module
                      config:{
                      ..... here
                      see
                      https://docs.magicmirror.builders/modules/configuration.html#example
                        sdetweil @cheminge
                        @cheminge did you get it working?
                          cheminge @sdetweil
                          Everything seems to be working, but I am having one issue.
                          I have repeating events, that are “All Day” events.
                          Then the week of the event I change the event on the google calendar to be for a specific time of day.
                          When I do this, I see both the repeating “All Day” and the Specific time events. (so double events on the same day) It also doesn’t read the new times that I have put into the google calendar.
                          I don’t even know where to start to look for a solution for this.
                          Attached is a screen shot of the calendar, and for example, on January 28, all 3 are duplicate entries.
                            sdetweil @cheminge
                            @cheminge did you put on the fixes for calendar?
                            are you running MagicMirror version 2.30, many calendar fixes
                            if you are, i want the event that you modified
                            before and after dumped from your ics data
                            curl -sL the-cal-url >somefile.txt
                            edit , find the event
                            BEGIN:VEVENT
                            END:VEVENT
                              cheminge @sdetweil
                              Yes, I think I have 2.30 and many calendar fixes installed…
                              Here is they entry for one of the entries on the 1-28-25 (duplicate of the “Alyce” entry)
                              BEGIN:VEVENT
                              DTSTART;TZID=America/New_York:20250128T103000
                              DTEND;TZID=America/New_York:20250128T113000
                              DTSTAMP:20250129T181146Z
                              UID:m6rjo4c4r97p3jm4i84aiud6ld_R20250128@google.com
                              RECURRENCE-ID;TZID=America/New_York:19691231T190000
                              CREATED:20221212T202854Z
                              LAST-MODIFIED:20250124T145109Z
                              LOCATION:**Protected Data ** (removed for protection data)
                              SEQUENCE:3
                              STATUS:CONFIRMED
                              SUMMARY:**Alyce Entry ** (removed for protection data)
                              TRANSP:TRANSPARENT
                              END:VEVENT
                              EGIN:VEVENT
                              DTSTART;VALUE=DATE:20250128
                              DTEND;VALUE=DATE:20250129
                              RRULE:FREQ=WEEKLY;WKST=SU;INTERVAL=2;BYDAY=TU
                              SEQUENCE:2
                              STATUS:CONFIRMED
                              TRANSP:TRANSPARENT
                              END:VEVENT
                                sdetweil @cheminge
                                @cheminge can you show me the output of
                                git branch
                                  sdetweil @cheminge
                                  @cheminge are you in the ny timezone too?
                                    sdetweil @cheminge
                                    @cheminge ok, the RRULE rule is that the extracted event MUST match the event its extracted from
                                    you have a full day RRULE
                                    and then extracted one instance
                                    DTSTART;TZID=America/New_York:20250131T103000
                                    DTEND;TZID=America/New_York:20250131T113000
                                    by RULE, this will be FORCED to a fullday event
                                    as the source event is fullday
                                    similarly if
                                    the event is date/time
                                    then the extracted MUST be date/time
                                    AND its bi weekly, so the extracted event is ignored. as its not on a week boundary
                                    (the RRULE cycle bi weekly and ONLY on TUESDAY)
                                    the tie between the events is the UID field
                                    the calendar tool should have changed the UID field
                                    to make this a standalone event
                                    but left it as part of the recurrence,
                                    got to be one or the other… match the RRULE or be separate
                                      cheminge @sdetweil
                                      This is what I get:
                                      _fix_clipping
                                      • develop
                                        master
                                        cheminge @sdetweil
                                        yes, I am in the New York time zone.
                                          sdetweil @cheminge
                                          @cheminge did you see my analysis of the events you posted
                                            cheminge @sdetweil
                                            Yes I see your analysis.
                                            Are you saying that the calendar tool (google) is not separating the event out and making it a new UID?
                                            I still don’t know how to get around that.
                                            When I confirm, should I make a new event and then delete the repeating event for that day?
