    MMM-PublicTransportHafas direction parameter not working anymore
    5 Posts 3 Posters 1.7k Views 3 Watching
      blinkybob
      Re: MMM-PublicTransportHafas
      I configured the module to only show the departures to a certain direction. But it is showing all departures.
      Here is my part out of the config.js file:
              module: "MMM-PublicTransportHafas",
              position: "bottom_left",
                      // Departures options
                      stationID: "8005976",             // Replace with your stationID!
                      stationName: "Unterasbach",       // Replace with your station name!
                      direction: "682669", //"8004486",             // Show only departures heading to this station. (A station ID.)
                      excludedTransportationTypes: ["bus"],  // Which transportation types should not be shown on the mirror? (comma-separated list of types) possible values: >
                      timeToStation: 10,                // How long do you need to walk to the next Station?
                      timeInFuture: 70,
                      // Look and Feel
                      displayLastUpdate: true,          // Display the last time of module update.
                      maxUnreachableDepartures: 0,      // How many unreachable departures should be shown?
                      maxReachableDepartures: 7,        // How many reachable departures should be shown?
                      showColoredLineSymbols: true,     // Want colored line symbols?
                      customLineStyles: "",             // Prefix for the name of the custom css file. ex: Leipzig-lines.css (case sensitive)
                      showOnlyLineNumbers: false,       // Display only the line number instead of the complete name, i. e. "11" instead of "STR 11"
                      showTableHeadersAsSymbols: true,  // Table Headers as symbols or text?
                      useColorForRealtimeInfo: true     // Want colored real time information (timeToStation, early)?
      Any hints from your side?
      Thx
      evroomE 2 Replies Last reply Reply Quote 0
      • evroomE Offline
        evroom @blinkybob
        @blinkybob
        I personally do not use this, but are you sure about
        direction: “682669”
        Seems a bit off.
        MagicMirror version: 2.37.0
        • evroomE Offline
          evroom @blinkybob
          @blinkybob
          I tested this and indeed it does not seem to work (anymore).
          For directionI used the station Id for the station adjacent to my station.
          I will raise an issue for this.
            blinkybob @evroom
            @evroom
            yes “682669” and also “8004486” are working. Both IDs are for Nuremberg HBF. I tested both to exclude errors with the station ID.
            Okay, thx that you raised an issue… thought it was a problem with my installation.
              markus_k @blinkybob
              @blinkybob
              I’ve been running into some challenges with the direction settings too. Please try ignoreRelatedStations: true parameter. That helped me in the first module. Unfortunately, it didn’t help in the second one for the opposite direction.
