    New module installer
    51 Posts 7 Posters 26.8k Views 6 Watching
    • plainbrokeP
      plainbroke @sdetweil
      I removed it with rm -rf MMM-Config
      Then rebooted Pi
      Then reinstalled with:
      cd ~/MagicMirror/modules
      git clone https://github.com/sdetweil/MMM-Config
      cd MMM-Config
      npm install
      THAT DID NOT WORK.
      threw all kinds of errors in shift+ctrl+i
      So I went back to the
      cd MMM_Config module and ran
      git pull
      git checkout with_installer
      npm install
      rebooted the Pi
      Now it works.
      Why I do not know.
      But it does. I am going to try it out with MMM-MPlayer.
      Thanks for the great work…
      S 2 Replies Last reply
        sdetweil @plainbroke
        @plainbroke said in New module installer:
        yes, that will put you on the root branch main or master
        you have to checkout the other branch that has the installer function in it
          @plainbroke pushed a few more updates… now open repo button in configuration screens as well as installer
          M 1 Reply Last reply
            MDWEBB @sdetweil
            @sdetweil Hi Sam,
            I update the fetch interval on my CalendarExt3 module via MMM-Config as i had a power flick and events hadn’t came back quick enough for my liking. However now the whole CalendarExt3 module is not display and i am getting errors on start up saying it can’t calidate main module.js i hadn’t made any changes outside of the config module. I tried uninstalling CalendaerExt3 and reinstalling but without any luck would love some guidance. Will past the latest config module below also.
            mdwebb@raspberrypi:~/MagicMirror $ npm start
            > magicmirror@2.31.0-develop start
            > npm run start:x11
            > magicmirror@2.31.0-develop start:x11
            [2025-01-20 20:36:52.086] [LOG]   Starting MagicMirror: v2.31.0-develop
            [2025-01-20 20:36:52.114] [LOG]   Loading config ...
            [2025-01-20 20:36:52.116] [LOG]   config template file not exists, no envsubst
            [2025-01-20 20:36:52.693] [INFO]  Checking config file /home/mdwebb/MagicMirror/config/config.js ...
            [2025-01-20 20:36:52.837] [INFO]  Your configuration file doesn't contain syntax errors :)
            [2025-01-20 20:36:52.839] [INFO]  Checking modules structure configuration ...
            [2025-01-20 20:36:52.983] [INFO]  Your modules structure configuration doesn't contain errors :)
            [2025-01-20 20:36:52.985] [LOG]   Loading module helpers ...
            [2025-01-20 20:36:52.997] [LOG]   Initializing new module helper ...
            [2025-01-20 20:36:52.998] [LOG]   Module helper loaded: updatenotification
            [2025-01-20 20:36:52.999] [LOG]   No helper found for module: clock.
            [2025-01-20 20:36:53.000] [LOG]   No helper found for module: MMM-CountDown.
            [2025-01-20 20:36:53.244] [LOG]   Initializing new module helper ...
            [2025-01-20 20:36:53.244] [LOG]   Module helper loaded: MMM-ImagesPhotos
            [2025-01-20 20:36:53.265] [LOG]   Initializing new module helper ...
            [2025-01-20 20:36:53.265] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
            [2025-01-20 20:36:53.429] [LOG]   Initializing new module helper ...
            [2025-01-20 20:36:53.429] [LOG]   Module helper loaded: MMM-Config
            [2025-01-20 20:36:53.430] [LOG]   No helper found for module: MMM-CalendarExt3.
            [2025-01-20 20:36:53.430] [LOG]   No helper found for module: alert.
            [2025-01-20 20:36:53.526] [LOG]   Initializing new module helper ...
            [2025-01-20 20:36:53.527] [LOG]   Module helper loaded: calendar
            [2025-01-20 20:36:53.650] [LOG]   Initializing new module helper ...
            [2025-01-20 20:36:53.650] [LOG]   Module helper loaded: MMM-Remote-Control
            [2025-01-20 20:36:53.698] [LOG]   Initializing new module helper ...
            [2025-01-20 20:36:53.698] [LOG]   Module helper loaded: MMM-ModuleScheduler
            [2025-01-20 20:36:53.699] [LOG]   All module helpers loaded.
            [2025-01-20 20:36:53.711] [LOG]   Starting server on port 8080 ...
            [2025-01-20 20:36:54.371] [LOG]   Server started ...
            [2025-01-20 20:36:54.377] [LOG]   Connecting socket for: updatenotification
            [2025-01-20 20:36:54.378] [LOG]   Starting module helper: updatenotification
            [2025-01-20 20:36:54.384] [LOG]   Connecting socket for: MMM-ImagesPhotos
            [2025-01-20 20:36:54.386] [LOG]   Starting node helper for: MMM-ImagesPhotos
            [2025-01-20 20:36:54.389] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
            [2025-01-20 20:36:54.390] [LOG]   Starting node_helper for MMM-OpenWeatherMapForecast
            [2025-01-20 20:36:54.396] [LOG]   Connecting socket for: MMM-Config
            [2025-01-20 20:36:54.727] [LOG]   will pull config data at 17:00:00 in 22985320 ms
            [2025-01-20 20:36:54.729] [LOG]   Connecting socket for: calendar
            [2025-01-20 20:36:54.736] [LOG]   Starting node helper for: calendar
            [2025-01-20 20:36:54.738] [LOG]   Connecting socket for: MMM-Remote-Control
            [2025-01-20 20:36:54.744] [LOG]   Starting node helper for: MMM-Remote-Control
            [2025-01-20 20:36:54.848] [LOG]   Connecting socket for: MMM-ModuleScheduler
            [2025-01-20 20:36:54.849] [LOG]   Starting node helper for: MMM-ModuleScheduler
            [2025-01-20 20:36:54.850] [LOG]   Sockets connected & modules started ...
            [2025-01-20 20:36:55.644] [LOG]   Launching application.
            [2025-01-20 20:36:57.126] [INFO]  System information:
            ### SYSTEM:   manufacturer: ; model: ; virtual: false
            ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51+rpt-rpi-v8
            ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
            ### OTHER:    timeZone: Australia/Melbourne; ELECTRON_ENABLE_GPU: undefined
            [2025-01-20 20:36:57.162] [ERROR] ERROR! Could not validate main module js file.
            [2025-01-20 20:36:57.168] [ERROR] ReferenceError: HTMLElement is not defined
                at Object.<anonymous> (/home/mdwebb/MagicMirror/modules/MMM-CalendarExt3/MMM-CalendarExt3.js:6:26)
                at Module._compile (node:internal/modules/cjs/loader:1484:14)
                at Module._extensions..js (node:internal/modules/cjs/loader:1564:10)
                at Module.load (node:internal/modules/cjs/loader:1295:32)
                at Module._load (node:internal/modules/cjs/loader:1111:12)
                at c._load (node:electron/js2c/node_init:2:16955)
                at Module.require (node:internal/modules/cjs/loader:1318:19)
                at require (node:internal/modules/helpers:179:18)
                at Class.loadModuleDefaultConfig (/home/mdwebb/MagicMirror/modules/MMM-Remote-Control/node_helper.js:317:30)
                at /home/mdwebb/MagicMirror/modules/MMM-Remote-Control/node_helper.js:271:26
                at FSReqCallback.oncomplete (node:fs:198:5)
            [3636:0120/203657.414249:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
            [3636:0120/203657.423716:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
            [3636:0120/203657.424432:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
            [3636:0120/203657.424789:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
            [3636:0120/203657.425361:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
            [3636:0120/203657.425726:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
            [3636:0120/203657.426131:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
            [3636:0120/203657.426495:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
            [3636:0120/203657.431838:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
            [3636:0120/203657.439567:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
            [3636:0120/203657.451490:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
            [3636:0120/203657.455922:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
            [3636:0120/203657.456469:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
            [3636:0120/203657.456802:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
            [3636:0120/203657.458595:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
            [3636:0120/203657.463710:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
            [3636:0120/203657.468093:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
            [3636:0120/203657.471514:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
            [3636:0120/203657.472361:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
            [3636:0120/203657.472678:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
            [3636:0120/203657.473397:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
            [3636:0120/203657.479438:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
            [3636:0120/203657.485371:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
            [3636:0120/203657.485794:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
            [3636:0120/203657.486390:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
            [3636:0120/203657.486682:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
            [3636:0120/203657.487070:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
            [3636:0120/203657.488116:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
            [2025-01-20 20:36:58.222] [LOG]
            [2025-01-20 20:37:00.003] [LOG]   Config based debug=module_3_MMM-ImagesPhotos
            [2025-01-20 20:37:00.008] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/ - Interval: 3600000
            [2025-01-20 20:37:00.017] [LOG]   MMM-ModuleScheduler is removing all scheduled jobs
            [2025-01-20 20:37:00.018] [LOG]   MMM-ModuleScheduler received CREATE_NOTIFICATION_SCHEDULE
            [2025-01-20 20:37:00.021] [LOG]   MMM-ModuleScheduler cannot create schedule. Missing `schedule` in `notification_schedule`: true
            [2025-01-20 20:37:00.029] [INFO]  updatenotification: Updater Class Loaded!
            [2025-01-20 20:37:00.030] [INFO]  updatenotification: Checking PM2 using...
            [2025-01-20 20:37:00.031] [INFO]  updatenotification: [PM2] You are not using pm2
            [2025-01-20 20:37:00.033] [INFO]  Checking git for module: MMM-CountDown
            [2025-01-20 20:37:00.070] [INFO]  Checking git for module: MMM-ImagesPhotos
            [2025-01-20 20:37:00.104] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
            [2025-01-20 20:37:00.171] [INFO]  Checking git for module: MMM-Config
            [2025-01-20 20:37:00.213] [INFO]  Checking git for module: MMM-CalendarExt3
            [2025-01-20 20:37:00.240] [INFO]  Checking git for module: MMM-Remote-Control
            [2025-01-20 20:37:00.265] [INFO]  Checking git for module: MMM-ModuleScheduler
            [2025-01-20 20:37:00.319] [INFO]  Checking git for module: MagicMirror
            [2025-01-20 20:37:05.720] [INFO]  Calendar-Fetcher: Broadcasting 970 events from https://calendar.google.com/calendar/ical...
            [2025-01-20 20:37:06.063] [LOG]   Shutting down server...
            [2025-01-20 20:37:06.066] [LOG]   Stopping module helper: updatenotification
            [2025-01-20 20:37:06.067] [LOG]   Stopping module helper: MMM-ImagesPhotos
            [2025-01-20 20:37:06.069] [LOG]   Stopping module helper: MMM-OpenWeatherMapForecast
            [2025-01-20 20:37:06.070] [LOG]   Stopping module helper: MMM-Config
            [2025-01-20 20:37:06.071] [LOG]   Stopping module helper: calendar
            [2025-01-20 20:37:06.076] [LOG]   Stopping module helper: MMM-ModuleScheduler
            [2025-01-20 20:37:06.078] [LOG]   Node_helpers stopped ...
            Config file
              var config = {
                address: "0.0.0.0",
                port: 8080,
                basePath: "/",
                ipWhitelist: [
                  "127.0.0.1",
                  "::ffff:127.0.0.1",
                  "::1",
                  "192.000.00.000",
                  "192.000.00.00"
                language: "en",
                locale: "en-US",
                logLevel: [
                  "INFO",
                  "LOG",
                  "WARN",
                  "ERROR"
                timeFormat: 24,
                units: "metric",
                useHttps: false,
                    module: "updatenotification",
                    position: "top_bar",
                    order: "*",
                    disabled: false,
                    animateIn: "None",
                    animateOut: "None",
                    config: {}
                    module: "clock",
                    order: "*",
                    animateIn: "None",
                    animateOut: "None",
                    index: 0,
                    label: "instance 1",
                      displayType: "digital",
                      timeFormat: "24",
                      displaySeconds: true,
                      showPeriod: true,
                      showDate: true,
                      showTime: true,
                      dateFormat: "dddd, LL",
                      analogSize: "200px",
                      analogFace: "simple",
                      analogPlacement: "bottom",
                      analogShowDate: "top",
                      secondsColor: "#888888",
                      lat: 47.630539,
                      lon: -122.344147,
                      showPeriodUpper: false,
                      clockBold: false,
                      showWeek: false,
                      sendNotifications: false,
                      showSunTimes: false,
                      showMoonTimes: false
                    disabled: false
                    module: "MMM-CountDown",
                      date: "2025-02-21",
                      event: "Webb Holiday"
                    order: "*",
                    disabled: false,
                    animateIn: "None",
                    animateOut: "None"
                    module: "MMM-ImagesPhotos",
                    position: "top_center",
                      animationSpeed: 1000,
                      updateInterval: 30000,
                      maxHeight: "500px",
                      maxWidth: "500px",
                      path: ""
                    order: "*",
                    disabled: false,
                    animateIn: "None",
                    animateOut: "None"
                    module: "weather",
                    disabled: true,
                    order: "*",
                    index: 0,
                    animateIn: "none",
                    animateOut: "none",
                      weatherProvider: "openmeteo",
                      type: "current",
                      units: "metric",
                      tempUnits: "metric",
                      windUnits: "metric",
                      timeFormat: "24",
                      useBeaufort: true,
                      lang: "en",
                      useKmh: false,
                      showHumidity: false
                    module: "weather",
                    disabled: true,
                    label: "instance 2",
                    order: "*",
                    index: 1,
                    animateIn: "none",
                    animateOut: "none",
                      type: "forecast",
                      units: "metric",
                      updateInterval: 600000,
                      timeFormat: "24",
                      showPeriod: true,
                      showWindDirection: true,
                      useBeaufort: true,
                      lang: "en",
                      showSun: true,
                      decimalSymbol: ".",
                      maxNumberOfDays: 5,
                      maxEntries: 5,
                      fade: true,
                      fadePoint: 0.25,
                      initialLoadDelay: 0,
                      appendLocationNameToHeader: true,
                      calendarClass: "calendar",
                      tableClass: "small",
                      showFeelsLike: true,
                      roundTemp: false,
                      useKmh: false,
                      showWindDirectionAsArrow: false,
                      showHumidity: false,
                      degreeLabel: false,
                      showIndoorTemperature: false,
                      showIndoorHumidity: false,
                      ignoreToday: false,
                      onlyTemp: false,
                      showPrecipitationAmount: false,
                      colored: false,
                      absoluteDates: false
                    module: "MMM-OpenWeatherMapForecast",
                    header: "Weather",
                    classes: "default everyone",
                      apikey: "",
                      latitude: "-38.314560",
                      longitude: "146.419373",
                      iconset: "4c",
                      concise: false,
                      forecastLayout: "table",
                      maxDailiesToShow: 5,
                      showWind: false,
                      units: "metric",
                      language: "en",
                      showExtraCurrentConditions: false,
                      showHourlyForecast: false,
                      forecastHeaderText: ""
                    order: "*",
                    disabled: false,
                    animateIn: "None",
                    animateOut: "None"
                    module: "MMM-Config",
                      restart: "none"
                    order: "*",
                    disabled: false,
                    animateIn: "none",
                    animateOut: "none"
                    module: "MMM-CalendarExt3",
                    position: "bottom_bar",
                    title: "",
                      instanceId: "basicCalendar",
                      locale: "en-US",
                      maxEventLines: 6,
                      firstDayOfWeek: "0",
                      weekIndex: 0,
                      weeksInView: 4,
                      eventHeight: "15px",
                      useMarquee: true,
                      refreshInterval: 600,
                      eventTransformer: (ev)=> {
              if (ev.title.search('DINNER') > -1) ev.symbol = ['fluent-color:food-28']
              if (ev.title.search('Arnold') > -1) ev.symbol = ['fluent-emoji-flat:dog']
              if (ev.title.search('Gus') > -1) ev.symbol = ['fluent-emoji-flat:dog']
              if (ev.title.search('Dogs') > -1) ev.symbol = ['fluent-emoji-flat:dog']
              if (ev.title.search('dogs') > -1) ev.symbol = ['fluent-emoji-flat:dog']
              if (ev.title.search('Marcus') > -1) ev.symbol = ['noto:pretzel']
              if (ev.title.search('Pretzel') > -1) ev.symbol = ['noto:pretzel']
              if (ev.title.search('Recycle Bin') > -1) ev.symbol = ['game-icons:soda-bottle']
              if (ev.title.search('Green Waste bins') > -1) ev.symbol = ['streamline-emojis:leaf-fluttering-in-wind']
              if (ev.title.search('Cleaning Day') > -1) ev.symbol = ['openmoji:broom']
              if (ev.title.search('Swimming') > -1) ev.symbol = ['fxemoji:swimming']
              if (ev.title.search('Phils') > -1) ev.symbol = ['twemoji:baby-angel-light-skin-tone']
              if (ev.title.search('Phyllis') > -1) ev.symbol = ['twemoji:baby-angel-light-skin-tone']
              if (ev.title.search('Birthday') > -1) ev.symbol = ['emojione:birthday-cake']
              if (ev.title.search('birthday') > -1) ev.symbol = ['emojione:birthday-cake']
              if (ev.title.search('Hugo') > -1) ev.symbol = ['cryptocurrency-color:hight']
              if (ev.title.search('Maggie') > -1) ev.symbol = ['cryptocurrency-color:xmy']
              if (ev.title.search('Lucas') > -1) ev.symbol = ['openmoji:man-judge-light-skin-tone']
              if (ev.title.search('Hudge') > -1) ev.symbol = ['twemoji:gemini']
              if (ev.title.search('Danielle') > -1) ev.symbol = ['twemoji:gemini']
              if (ev.title.search('Factory') > -1) ev.symbol = ['emojione-v1:cow']
              if (ev.title.search('factory') > -1) ev.symbol = ['emojione-v1:cow']
              return ev
                      eventFilter: (ev) =>  {
             return true
                      manipulateDateCell: (cellDom, events) =>  {
                      weatherPayload: (payload) =>  {
             return payload
                      eventPayload: (payload) =>  {
             return payload
                    order: "*",
                    disabled: false,
                    animateIn: "None",
                    animateOut: "None"
                    module: "newsfeed",
                    disabled: true,
                    order: "*",
                    animateIn: "None",
                    animateOut: "None",
                    index: 0,
                      feeds: [
                          title: "New York Times",
                          url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml",
                          encoding: "UTF-8"
                      showSourceTitle: true,
                      showPublishDate: true,
                      broadcastNewsFeeds: true,
                      broadcastNewsUpdates: true,
                      wrapTitle: true,
                      wrapDescription: true,
                      truncDescription: true,
                      lengthDescription: 400,
                      reloadInterval: 300000,
                      updateInterval: 10000,
                      animationSpeed: 2500,
                      maxNewsItems: 0,
                      ignoreOlderThan: 86400000,
                      scrollLength: 500,
                      showAsList: false,
                      showDescription: false,
                      showTitleAsUrl: false,
                      hideLoading: false,
                      ignoreOldItems: false,
                      logFeedWarnings: false,
                      dangerouslyDisableAutoEscaping: false,
                      startTags: [],
                      endTags: [],
                      prohibitedWords: []
                    module: "alert",
                    order: "*",
                    animateIn: "None",
                    animateOut: "None",
                    index: 0,
                      effect: "slide",
                      alert_effect: "jelly",
                      display_time: 3500,
                      position: "center",
                      welcome_message: false
                    disabled: false
                    order: "*",
                    animateIn: "None",
                    animateOut: "None",
                    index: 0,
                      maximumEntries: 10,
                      maximumNumberOfDays: 365,
                      limitDays: 0,
                      pastDaysCount: 0,
                      displaySymbol: true,
                      defaultSymbol: "calendar-alt",
                      defaultSymbolClassName: "fas fa-fw fa-",
                      maxTitleLength: 25,
                      maxLocationTitleLength: 25,
                      maxTitleLines: 3,
                      maxEventTitleLines: 3,
                      fetchInterval: 3600000,
                      animationSpeed: 2000,
                      fade: true,
                      fadePoint: 0.25,
                      urgency: 7,
                      timeFormat: "relative",
                      dateFormat: "MMM Do",
                      dateEndFormat: "LT",
                      fullDayEventDateFormat: "MMM Do",
                      getRelative: 6,
                      hideDuplicates: true,
                          symbol: "calendar-alt",
                          url: "https://calendar.google.com/calendar/ical/
                      customEvents: [
                          keyword: ".*",
                          transform: {
                            search: "De verjaardag van "
                          keyword: ".*",
                          transform: {
                            search: "'s birthday"
                      locationTitleReplace: {
                        "street ": ""
                      broadcastEvents: true,
                      broadcastPastEvents: true,
                      updateOnFetch: true,
                      showLocation: false,
                      displayRepeatingCountTitle: false,
                      wrapEvents: false,
                      wrapLocationEvents: false,
                      showEnd: false,
                      showEndsOnlyWithDuration: false,
                      hidePrivate: false,
                      hideOngoing: false,
                      hideTime: false,
                      showTimeToday: false,
                      colored: false,
                      forceUseCurrentTime: false,
                      sliceMultiDayEvents: false,
                      nextDaysRelative: false,
                      selfSignedCert: false,
                      coloredText: false,
                      coloredBorder: false,
                      coloredSymbol: false,
                      coloredBackground: false,
                      limitDaysNeverSkip: false,
                      flipDateHeaderTitle: false,
                      excludedEvents: []
                    disabled: false
                    module: "MMM-Remote-Control",
                      apiKey: ""
                    order: "*",
                    disabled: false,
                    animateIn: "None",
                    animateOut: "None"
                    module: "MMM-ModuleScheduler",
                      notification_schedule: true
                    order: "*",
                    disabled: false,
                    animateIn: "None",
                    animateOut: "None"
            S M 4 Replies Last reply
              sdetweil @MDWEBB
              @MDWEBB hm, could not validate file…
              edit: ---- you said you reinstalled, so this is not a file corruption problem
              lets go to the MMM-CalendarExt3 folder
              and do
              git status
              it should not list any files
              please show the reults
                sdetweil @MDWEBB
                @MDWEBB also you changed refreshInterval to 600
                milliseconds down from 30 minutes!! (the module cannot redraw that fast)
                i think you need to change the waitFetch value up to 10000
                milliseconds.
                i don’t think refreshInterval should ever be less that 300000
                (5 minutes)
                  @MDWEBB I could not recreate the error by setting one of my Ext3 instances to refreshInterval :600
                    @MDWEBB
                    BUT… just for the sake of testing something… MMM-Config saved the prior config.js
                    so if you
                    cd~/MagicMirror/config
                    #rename this one out of the way
                    mv config.js save-config.js
                    ls config -laFt config.*
                    #and copy the top one back to config.js
                    #mark the filename, right click mouse
                    cp -rightclick-paste config.js
                    and then restart MagicMirror
                    do you still get the error??
                      I added the default modules to have links to their config doc too… (in configuration)
                      I made significant changes to the weather form layout, using select lists and custom field sets per weather provider.
                      updated the schemas MMM-Config ships to add the view readme button
                        MMRIZE @MDWEBB
                        @MDWEBB said in New module installer:
                        This error message seems to be caused by some JS validator trying to check the browser-oriented syntax on the nodeJS environment.
                        @MDWEBB
                        You’d better start from a clean configuration and then add one by one to find what was wrong.
                          sdetweil @MDWEBB
                          I bet this is the remote-control error…
                          shouldn’t stop anything
                          but, if you want to try my fork, which captures that error
                          https://github.com/sdetweil/MMM-Remote-Control
                          just remove the existing folder and git clone mine in its place
                          no functional code change or parms… just trapping this error
                            MDWEBB @sdetweil
                            @sdetweil Apologise for slow reply i was able to remove the node modules file and run the update for the module and now my calendar is working again.
                              sdetweil @MDWEBB
                              @MDWEBB no apologies required
                              updated what module?
                                MDWEBB @sdetweil
                                @sdetweil update MMM-Remotecontrol.
                                I am getting update notifications for both the MMM-Config module and MMM-Remote-Control.
                                MMM-Config says its 3 commits behind the with_installer branch. Not sure whats happening with that
                                MMM-Remote-Control s 8 commits behind on the master branch i get the following error when trying to use the update script though
                                mdwebb@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-Remote-Control # adapt directory if you are using a different one
                                git pull
                                npm install # install (new) dependencies
                                Updating 76c0859..5c39b06
                                error: Your local changes to the following files would be overwritten by merge:
                                	modules.json
                                	package-lock.json
                                	package.json
                                Please commit your changes or stash them before you merge.
                                Aborting
                                up to date, audited 340 packages in 3s
                                103 packages are looking for funding
                                  run `npm fund` for details
                                found 0 vulnerabilities
                                  sdetweil @MDWEBB
                                  @MDWEBB yes there are updates to mmm-config
                                  are you using my remotecontrol repo?
                                  i would disable the updatenotification module
                                    MDWEBB @sdetweil
                                    @sdetweil i am using your remote control module yes very handy, however having issues utilising the MMM-Module-Scheduler to to turn my monitor on and off via Remote-Control. i can see in the developer window its trying to send the notification however my monitor isn’t turning off. Am i missing something?
                                            module: 'MMM-ModuleScheduler',
                                                notification_schedule: [
                                                    // TURN THE MONITOR/SCREEN ON AT 07:30 EVERY DAY
                                                    {notification: 'REMOTE_ACTION', schedule: '30 7 * * *', payload: {action: "MONITORON"}},
                                                    // TURN THE MONITOR/SCREEN OFF AT 22:30 EVERY DAY
                                                    {notification: 'REMOTE_ACTION', schedule: '01 14 * * *', payload: {action: "MONITOROFF"}},
                                                    // RESTART THE MAGICMIRROR PROCESS AT 2am EVERY SUNDAY
                                                    {notification: 'REMOTE_ACTION', schedule: '0 2 * * SUN', payload: {action: "RESTART"}}
                                      sdetweil @MDWEBB
                                      @MDWEBB issue on remotecontrol
                                      is not MY remote control, I just fixed the error trap that was misleading
                                      no other code change
                                      https://github.com/Jopyth/MMM-Remote-Control/issues/303
                                      which one of the 10 or 12 ways does it try to turn monitor off??
                                      which OS is different
                                      which window compositor is different x11/wayland/labwc is different
                                      I know MMM-PIR has been working hard on making it woirk thru all the choices
                                      did it work before and doesn’t now??
                                      I don’t know the module internals…
                                        @MDWEBB I just resynced my fork with his latest remote-control
                                        he had most of my changes and seemed to catch that error… maybe
                                          I just updated the code again, this time to provide opening the readme for the repo in both install and config
                                          its on a different branch again
                                          git pull
                                          git checkout better_repo_url
                                          npm install     # <--- required.. added another library and copies a template file
                                          everything else is the same, except there is a button to open the module readme
                                          an example from the installer page, exactly the same on the config page
                                          still have some trouble with our own docs site, gitlab
                                          the readme window will open at the button position
                                            @sdetweil said in New module installer:
                                            just posted another update for better handling of the repo readme (in most cases)
                                            and handles readme’s for repo ADDs to the 3rd party list list, deletes worked ok before
                                            and for the readme during config, use the file in the installed module folder, instead of trying to get the github repo version
                                            same process
                                            git pull
                                            git checkout better_repo_url  # if already there not needed
                                            the copy fixes a bug in the readme list file
                                            and if this is first time using, make sure to add
                                            MMM-Config to your config.js
                                                  module:"MMM-Config"
                                                   position:"...", // only for qrcode if you use that
                                                    config:{
                                            • 2 / 3
