    New module installer
    51 Posts 7 Posters 26.8k Views 6 Watching
      sdetweil @plainbroke
      @plainbroke I just did a fresh install on a new MM… on a different machine
      when I bring up the MM page it works
      when I bring up the installer page it works… takes a few seconds
      when I open the MMM-Config/review page the configuration page comes up
      open the installer page
      http://server:port/installer
      open the developers window, ctrl-shift-i
      go to the console tab , see if there are any errors
      open the sources tab
       left nav
      selec modules,
        mmm-config
            module_installer
                   select the form-client.js
                   scroll the source to line 120, click on the line number
                   should turn blue
      like this
      hit f5 refresh the page
      it should look like this
      you should be able to scroll the mouse over the words incoming_json
      and it should pop up a big window of the json
      like this
        @plainbroke feel better… this is not that important
          @plainbroke i pushed a bunch of fixes.
          plainbrokeP 1 Reply Last reply
          • plainbrokeP
            plainbroke @sdetweil
            I removed it with rm -rf MMM-Config
            Then rebooted Pi
            Then reinstalled with:
            cd ~/MagicMirror/modules
            git clone https://github.com/sdetweil/MMM-Config
            cd MMM-Config
            npm install
            THAT DID NOT WORK.
            threw all kinds of errors in shift+ctrl+i
            So I went back to the
            cd MMM_Config module and ran
            git pull
            git checkout with_installer
            npm install
            rebooted the Pi
            Now it works.
            Why I do not know.
            But it does. I am going to try it out with MMM-MPlayer.
            Thanks for the great work…
            S 2 Replies Last reply
              @plainbroke said in New module installer:
              yes, that will put you on the root branch main or master
              you have to checkout the other branch that has the installer function in it
                @plainbroke pushed a few more updates… now open repo button in configuration screens as well as installer
                M 1 Reply Last reply
                  MDWEBB @sdetweil
                  @sdetweil Hi Sam,
                  I update the fetch interval on my CalendarExt3 module via MMM-Config as i had a power flick and events hadn’t came back quick enough for my liking. However now the whole CalendarExt3 module is not display and i am getting errors on start up saying it can’t calidate main module.js i hadn’t made any changes outside of the config module. I tried uninstalling CalendaerExt3 and reinstalling but without any luck would love some guidance. Will past the latest config module below also.
                  mdwebb@raspberrypi:~/MagicMirror $ npm start
                  > magicmirror@2.31.0-develop start
                  > npm run start:x11
                  > magicmirror@2.31.0-develop start:x11
                  [2025-01-20 20:36:52.086] [LOG]   Starting MagicMirror: v2.31.0-develop
                  [2025-01-20 20:36:52.114] [LOG]   Loading config ...
                  [2025-01-20 20:36:52.116] [LOG]   config template file not exists, no envsubst
                  [2025-01-20 20:36:52.693] [INFO]  Checking config file /home/mdwebb/MagicMirror/config/config.js ...
                  [2025-01-20 20:36:52.837] [INFO]  Your configuration file doesn't contain syntax errors :)
                  [2025-01-20 20:36:52.839] [INFO]  Checking modules structure configuration ...
                  [2025-01-20 20:36:52.983] [INFO]  Your modules structure configuration doesn't contain errors :)
                  [2025-01-20 20:36:52.985] [LOG]   Loading module helpers ...
                  [2025-01-20 20:36:52.997] [LOG]   Initializing new module helper ...
                  [2025-01-20 20:36:52.998] [LOG]   Module helper loaded: updatenotification
                  [2025-01-20 20:36:52.999] [LOG]   No helper found for module: clock.
                  [2025-01-20 20:36:53.000] [LOG]   No helper found for module: MMM-CountDown.
                  [2025-01-20 20:36:53.244] [LOG]   Initializing new module helper ...
                  [2025-01-20 20:36:53.244] [LOG]   Module helper loaded: MMM-ImagesPhotos
                  [2025-01-20 20:36:53.265] [LOG]   Initializing new module helper ...
                  [2025-01-20 20:36:53.265] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast
                  [2025-01-20 20:36:53.429] [LOG]   Initializing new module helper ...
                  [2025-01-20 20:36:53.429] [LOG]   Module helper loaded: MMM-Config
                  [2025-01-20 20:36:53.430] [LOG]   No helper found for module: MMM-CalendarExt3.
                  [2025-01-20 20:36:53.430] [LOG]   No helper found for module: alert.
                  [2025-01-20 20:36:53.526] [LOG]   Initializing new module helper ...
                  [2025-01-20 20:36:53.527] [LOG]   Module helper loaded: calendar
                  [2025-01-20 20:36:53.650] [LOG]   Initializing new module helper ...
                  [2025-01-20 20:36:53.650] [LOG]   Module helper loaded: MMM-Remote-Control
                  [2025-01-20 20:36:53.698] [LOG]   Initializing new module helper ...
                  [2025-01-20 20:36:53.698] [LOG]   Module helper loaded: MMM-ModuleScheduler
                  [2025-01-20 20:36:53.699] [LOG]   All module helpers loaded.
                  [2025-01-20 20:36:53.711] [LOG]   Starting server on port 8080 ...
                  [2025-01-20 20:36:54.371] [LOG]   Server started ...
                  [2025-01-20 20:36:54.377] [LOG]   Connecting socket for: updatenotification
                  [2025-01-20 20:36:54.378] [LOG]   Starting module helper: updatenotification
                  [2025-01-20 20:36:54.384] [LOG]   Connecting socket for: MMM-ImagesPhotos
                  [2025-01-20 20:36:54.386] [LOG]   Starting node helper for: MMM-ImagesPhotos
                  [2025-01-20 20:36:54.389] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
                  [2025-01-20 20:36:54.390] [LOG]   Starting node_helper for MMM-OpenWeatherMapForecast
                  [2025-01-20 20:36:54.396] [LOG]   Connecting socket for: MMM-Config
                  [2025-01-20 20:36:54.727] [LOG]   will pull config data at 17:00:00 in 22985320 ms
                  [2025-01-20 20:36:54.729] [LOG]   Connecting socket for: calendar
                  [2025-01-20 20:36:54.736] [LOG]   Starting node helper for: calendar
                  [2025-01-20 20:36:54.738] [LOG]   Connecting socket for: MMM-Remote-Control
                  [2025-01-20 20:36:54.744] [LOG]   Starting node helper for: MMM-Remote-Control
                  [2025-01-20 20:36:54.848] [LOG]   Connecting socket for: MMM-ModuleScheduler
                  [2025-01-20 20:36:54.849] [LOG]   Starting node helper for: MMM-ModuleScheduler
                  [2025-01-20 20:36:54.850] [LOG]   Sockets connected & modules started ...
                  [2025-01-20 20:36:55.644] [LOG]   Launching application.
                  [2025-01-20 20:36:57.126] [INFO]  System information:
                  ### SYSTEM:   manufacturer: ; model: ; virtual: false
                  ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51+rpt-rpi-v8
                  ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
                  ### OTHER:    timeZone: Australia/Melbourne; ELECTRON_ENABLE_GPU: undefined
                  [2025-01-20 20:36:57.162] [ERROR] ERROR! Could not validate main module js file.
                  [2025-01-20 20:36:57.168] [ERROR] ReferenceError: HTMLElement is not defined
                      at Object.<anonymous> (/home/mdwebb/MagicMirror/modules/MMM-CalendarExt3/MMM-CalendarExt3.js:6:26)
                      at Module._compile (node:internal/modules/cjs/loader:1484:14)
                      at Module._extensions..js (node:internal/modules/cjs/loader:1564:10)
                      at Module.load (node:internal/modules/cjs/loader:1295:32)
                      at Module._load (node:internal/modules/cjs/loader:1111:12)
                      at c._load (node:electron/js2c/node_init:2:16955)
                      at Module.require (node:internal/modules/cjs/loader:1318:19)
                      at require (node:internal/modules/helpers:179:18)
                      at Class.loadModuleDefaultConfig (/home/mdwebb/MagicMirror/modules/MMM-Remote-Control/node_helper.js:317:30)
                      at /home/mdwebb/MagicMirror/modules/MMM-Remote-Control/node_helper.js:271:26
                      at FSReqCallback.oncomplete (node:fs:198:5)
                  [3636:0120/203657.414249:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [3636:0120/203657.423716:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [3636:0120/203657.424432:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [3636:0120/203657.424789:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [3636:0120/203657.425361:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [3636:0120/203657.425726:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [3636:0120/203657.426131:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [3636:0120/203657.426495:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [3636:0120/203657.431838:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [3636:0120/203657.439567:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [3636:0120/203657.451490:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [3636:0120/203657.455922:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [3636:0120/203657.456469:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [3636:0120/203657.456802:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [3636:0120/203657.458595:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [3636:0120/203657.463710:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [3636:0120/203657.468093:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [3636:0120/203657.471514:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [3636:0120/203657.472361:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [3636:0120/203657.472678:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [3636:0120/203657.473397:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [3636:0120/203657.479438:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [3636:0120/203657.485371:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [3636:0120/203657.485794:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [3636:0120/203657.486390:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [3636:0120/203657.486682:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [3636:0120/203657.487070:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                  [3636:0120/203657.488116:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                  [2025-01-20 20:36:58.222] [LOG]
                  [2025-01-20 20:37:00.003] [LOG]   Config based debug=module_3_MMM-ImagesPhotos
                  [2025-01-20 20:37:00.008] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/ - Interval: 3600000
                  [2025-01-20 20:37:00.017] [LOG]   MMM-ModuleScheduler is removing all scheduled jobs
                  [2025-01-20 20:37:00.018] [LOG]   MMM-ModuleScheduler received CREATE_NOTIFICATION_SCHEDULE
                  [2025-01-20 20:37:00.021] [LOG]   MMM-ModuleScheduler cannot create schedule. Missing `schedule` in `notification_schedule`: true
                  [2025-01-20 20:37:00.029] [INFO]  updatenotification: Updater Class Loaded!
                  [2025-01-20 20:37:00.030] [INFO]  updatenotification: Checking PM2 using...
                  [2025-01-20 20:37:00.031] [INFO]  updatenotification: [PM2] You are not using pm2
                  [2025-01-20 20:37:00.033] [INFO]  Checking git for module: MMM-CountDown
                  [2025-01-20 20:37:00.070] [INFO]  Checking git for module: MMM-ImagesPhotos
                  [2025-01-20 20:37:00.104] [INFO]  Checking git for module: MMM-OpenWeatherMapForecast
                  [2025-01-20 20:37:00.171] [INFO]  Checking git for module: MMM-Config
                  [2025-01-20 20:37:00.213] [INFO]  Checking git for module: MMM-CalendarExt3
                  [2025-01-20 20:37:00.240] [INFO]  Checking git for module: MMM-Remote-Control
                  [2025-01-20 20:37:00.265] [INFO]  Checking git for module: MMM-ModuleScheduler
                  [2025-01-20 20:37:00.319] [INFO]  Checking git for module: MagicMirror
                  [2025-01-20 20:37:05.720] [INFO]  Calendar-Fetcher: Broadcasting 970 events from https://calendar.google.com/calendar/ical...
                  [2025-01-20 20:37:06.063] [LOG]   Shutting down server...
                  [2025-01-20 20:37:06.066] [LOG]   Stopping module helper: updatenotification
                  [2025-01-20 20:37:06.067] [LOG]   Stopping module helper: MMM-ImagesPhotos
                  [2025-01-20 20:37:06.069] [LOG]   Stopping module helper: MMM-OpenWeatherMapForecast
                  [2025-01-20 20:37:06.070] [LOG]   Stopping module helper: MMM-Config
                  [2025-01-20 20:37:06.071] [LOG]   Stopping module helper: calendar
                  [2025-01-20 20:37:06.076] [LOG]   Stopping module helper: MMM-ModuleScheduler
                  [2025-01-20 20:37:06.078] [LOG]   Node_helpers stopped ...
                  Config file
                    var config = {
                      address: "0.0.0.0",
                      port: 8080,
                      basePath: "/",
                      ipWhitelist: [
                        "127.0.0.1",
                        "::ffff:127.0.0.1",
                        "::1",
                        "192.000.00.000",
                        "192.000.00.00"
                      language: "en",
                      locale: "en-US",
                      logLevel: [
                        "INFO",
                        "LOG",
                        "WARN",
                        "ERROR"
                      timeFormat: 24,
                      units: "metric",
                      useHttps: false,
                          module: "updatenotification",
                          position: "top_bar",
                          order: "*",
                          disabled: false,
                          animateIn: "None",
                          animateOut: "None",
                          config: {}
                          module: "clock",
                          order: "*",
                          animateIn: "None",
                          animateOut: "None",
                          index: 0,
                          label: "instance 1",
                            displayType: "digital",
                            timeFormat: "24",
                            displaySeconds: true,
                            showPeriod: true,
                            showDate: true,
                            showTime: true,
                            dateFormat: "dddd, LL",
                            analogSize: "200px",
                            analogFace: "simple",
                            analogPlacement: "bottom",
                            analogShowDate: "top",
                            secondsColor: "#888888",
                            lat: 47.630539,
                            lon: -122.344147,
                            showPeriodUpper: false,
                            clockBold: false,
                            showWeek: false,
                            sendNotifications: false,
                            showSunTimes: false,
                            showMoonTimes: false
                          disabled: false
                          module: "MMM-CountDown",
                            date: "2025-02-21",
                            event: "Webb Holiday"
                          order: "*",
                          disabled: false,
                          animateIn: "None",
                          animateOut: "None"
                          module: "MMM-ImagesPhotos",
                          position: "top_center",
                            animationSpeed: 1000,
                            updateInterval: 30000,
                            maxHeight: "500px",
                            maxWidth: "500px",
                            path: ""
                          order: "*",
                          disabled: false,
                          animateIn: "None",
                          animateOut: "None"
                          module: "weather",
                          disabled: true,
                          order: "*",
                          index: 0,
                          animateIn: "none",
                          animateOut: "none",
                            weatherProvider: "openmeteo",
                            type: "current",
                            units: "metric",
                            tempUnits: "metric",
                            windUnits: "metric",
                            timeFormat: "24",
                            useBeaufort: true,
                            lang: "en",
                            useKmh: false,
                            showHumidity: false
                          module: "weather",
                          disabled: true,
                          label: "instance 2",
                          order: "*",
                          index: 1,
                          animateIn: "none",
                          animateOut: "none",
                            type: "forecast",
                            units: "metric",
                            updateInterval: 600000,
                            timeFormat: "24",
                            showPeriod: true,
                            showWindDirection: true,
                            useBeaufort: true,
                            lang: "en",
                            showSun: true,
                            decimalSymbol: ".",
                            maxNumberOfDays: 5,
                            maxEntries: 5,
                            fade: true,
                            fadePoint: 0.25,
                            initialLoadDelay: 0,
                            appendLocationNameToHeader: true,
                            calendarClass: "calendar",
                            tableClass: "small",
                            showFeelsLike: true,
                            roundTemp: false,
                            useKmh: false,
                            showWindDirectionAsArrow: false,
                            showHumidity: false,
                            degreeLabel: false,
                            showIndoorTemperature: false,
                            showIndoorHumidity: false,
                            ignoreToday: false,
                            onlyTemp: false,
                            showPrecipitationAmount: false,
                            colored: false,
                            absoluteDates: false
                          module: "MMM-OpenWeatherMapForecast",
                          header: "Weather",
                          classes: "default everyone",
                            apikey: "",
                            latitude: "-38.314560",
                            longitude: "146.419373",
                            iconset: "4c",
                            concise: false,
                            forecastLayout: "table",
                            maxDailiesToShow: 5,
                            showWind: false,
                            units: "metric",
                            language: "en",
                            showExtraCurrentConditions: false,
                            showHourlyForecast: false,
                            forecastHeaderText: ""
                          order: "*",
                          disabled: false,
                          animateIn: "None",
                          animateOut: "None"
                          module: "MMM-Config",
                            restart: "none"
                          order: "*",
                          disabled: false,
                          animateIn: "none",
                          animateOut: "none"
                          module: "MMM-CalendarExt3",
                          position: "bottom_bar",
                          title: "",
                            instanceId: "basicCalendar",
                            locale: "en-US",
                            maxEventLines: 6,
                            firstDayOfWeek: "0",
                            weekIndex: 0,
                            weeksInView: 4,
                            eventHeight: "15px",
                            useMarquee: true,
                            refreshInterval: 600,
                            eventTransformer: (ev)=> {
                    if (ev.title.search('DINNER') > -1) ev.symbol = ['fluent-color:food-28']
                    if (ev.title.search('Arnold') > -1) ev.symbol = ['fluent-emoji-flat:dog']
                    if (ev.title.search('Gus') > -1) ev.symbol = ['fluent-emoji-flat:dog']
                    if (ev.title.search('Dogs') > -1) ev.symbol = ['fluent-emoji-flat:dog']
                    if (ev.title.search('dogs') > -1) ev.symbol = ['fluent-emoji-flat:dog']
                    if (ev.title.search('Marcus') > -1) ev.symbol = ['noto:pretzel']
                    if (ev.title.search('Pretzel') > -1) ev.symbol = ['noto:pretzel']
                    if (ev.title.search('Recycle Bin') > -1) ev.symbol = ['game-icons:soda-bottle']
                    if (ev.title.search('Green Waste bins') > -1) ev.symbol = ['streamline-emojis:leaf-fluttering-in-wind']
                    if (ev.title.search('Cleaning Day') > -1) ev.symbol = ['openmoji:broom']
                    if (ev.title.search('Swimming') > -1) ev.symbol = ['fxemoji:swimming']
                    if (ev.title.search('Phils') > -1) ev.symbol = ['twemoji:baby-angel-light-skin-tone']
                    if (ev.title.search('Phyllis') > -1) ev.symbol = ['twemoji:baby-angel-light-skin-tone']
                    if (ev.title.search('Birthday') > -1) ev.symbol = ['emojione:birthday-cake']
                    if (ev.title.search('birthday') > -1) ev.symbol = ['emojione:birthday-cake']
                    if (ev.title.search('Hugo') > -1) ev.symbol = ['cryptocurrency-color:hight']
                    if (ev.title.search('Maggie') > -1) ev.symbol = ['cryptocurrency-color:xmy']
                    if (ev.title.search('Lucas') > -1) ev.symbol = ['openmoji:man-judge-light-skin-tone']
                    if (ev.title.search('Hudge') > -1) ev.symbol = ['twemoji:gemini']
                    if (ev.title.search('Danielle') > -1) ev.symbol = ['twemoji:gemini']
                    if (ev.title.search('Factory') > -1) ev.symbol = ['emojione-v1:cow']
                    if (ev.title.search('factory') > -1) ev.symbol = ['emojione-v1:cow']
                    return ev
                            eventFilter: (ev) =>  {
                   return true
                            manipulateDateCell: (cellDom, events) =>  {
                            weatherPayload: (payload) =>  {
                   return payload
                            eventPayload: (payload) =>  {
                   return payload
                          order: "*",
                          disabled: false,
                          animateIn: "None",
                          animateOut: "None"
                          module: "newsfeed",
                          disabled: true,
                          order: "*",
                          animateIn: "None",
                          animateOut: "None",
                          index: 0,
                            feeds: [
                                title: "New York Times",
                                url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml",
                                encoding: "UTF-8"
                            showSourceTitle: true,
                            showPublishDate: true,
                            broadcastNewsFeeds: true,
                            broadcastNewsUpdates: true,
                            wrapTitle: true,
                            wrapDescription: true,
                            truncDescription: true,
                            lengthDescription: 400,
                            reloadInterval: 300000,
                            updateInterval: 10000,
                            animationSpeed: 2500,
                            maxNewsItems: 0,
                            ignoreOlderThan: 86400000,
                            scrollLength: 500,
                            showAsList: false,
                            showDescription: false,
                            showTitleAsUrl: false,
                            hideLoading: false,
                            ignoreOldItems: false,
                            logFeedWarnings: false,
                            dangerouslyDisableAutoEscaping: false,
                            startTags: [],
                            endTags: [],
                            prohibitedWords: []
                          module: "alert",
                          order: "*",
                          animateIn: "None",
                          animateOut: "None",
                          index: 0,
                            effect: "slide",
                            alert_effect: "jelly",
                            display_time: 3500,
                            position: "center",
                            welcome_message: false
                          disabled: false
                          order: "*",
                          animateIn: "None",
                          animateOut: "None",
                          index: 0,
                            maximumEntries: 10,
                            maximumNumberOfDays: 365,
                            limitDays: 0,
                            pastDaysCount: 0,
                            displaySymbol: true,
                            defaultSymbol: "calendar-alt",
                            defaultSymbolClassName: "fas fa-fw fa-",
                            maxTitleLength: 25,
                            maxLocationTitleLength: 25,
                            maxTitleLines: 3,
                            maxEventTitleLines: 3,
                            fetchInterval: 3600000,
                            animationSpeed: 2000,
                            fade: true,
                            fadePoint: 0.25,
                            urgency: 7,
                            timeFormat: "relative",
                            dateFormat: "MMM Do",
                            dateEndFormat: "LT",
                            fullDayEventDateFormat: "MMM Do",
                            getRelative: 6,
                            hideDuplicates: true,
                                symbol: "calendar-alt",
                                url: "https://calendar.google.com/calendar/ical/
                            customEvents: [
                                keyword: ".*",
                                transform: {
                                  search: "De verjaardag van "
                                keyword: ".*",
                                transform: {
                                  search: "'s birthday"
                            locationTitleReplace: {
                              "street ": ""
                            broadcastEvents: true,
                            broadcastPastEvents: true,
                            updateOnFetch: true,
                            showLocation: false,
                            displayRepeatingCountTitle: false,
                            wrapEvents: false,
                            wrapLocationEvents: false,
                            showEnd: false,
                            showEndsOnlyWithDuration: false,
                            hidePrivate: false,
                            hideOngoing: false,
                            hideTime: false,
                            showTimeToday: false,
                            colored: false,
                            forceUseCurrentTime: false,
                            sliceMultiDayEvents: false,
                            nextDaysRelative: false,
                            selfSignedCert: false,
                            coloredText: false,
                            coloredBorder: false,
                            coloredSymbol: false,
                            coloredBackground: false,
                            limitDaysNeverSkip: false,
                            flipDateHeaderTitle: false,
                            excludedEvents: []
                          disabled: false
                          module: "MMM-Remote-Control",
                            apiKey: ""
                          order: "*",
                          disabled: false,
                          animateIn: "None",
                          animateOut: "None"
                          module: "MMM-ModuleScheduler",
                            notification_schedule: true
                          order: "*",
                          disabled: false,
                          animateIn: "None",
                          animateOut: "None"
                  S M 4 Replies Last reply
                    sdetweil @MDWEBB
                    @MDWEBB hm, could not validate file…
                    edit: ---- you said you reinstalled, so this is not a file corruption problem
                    lets go to the MMM-CalendarExt3 folder
                    and do
                    git status
                    it should not list any files
                    please show the reults
                      sdetweil @MDWEBB
                      @MDWEBB also you changed refreshInterval to 600
                      milliseconds down from 30 minutes!! (the module cannot redraw that fast)
                      i think you need to change the waitFetch value up to 10000
                      milliseconds.
                      i don’t think refreshInterval should ever be less that 300000
                      (5 minutes)
                        @MDWEBB I could not recreate the error by setting one of my Ext3 instances to refreshInterval :600
                          @MDWEBB
                          BUT… just for the sake of testing something… MMM-Config saved the prior config.js
                          so if you
                          cd~/MagicMirror/config
                          #rename this one out of the way
                          mv config.js save-config.js
                          ls config -laFt config.*
                          #and copy the top one back to config.js
                          #mark the filename, right click mouse
                          cp -rightclick-paste config.js
                          and then restart MagicMirror
                          do you still get the error??
                            I added the default modules to have links to their config doc too… (in configuration)
                            I made significant changes to the weather form layout, using select lists and custom field sets per weather provider.
                            updated the schemas MMM-Config ships to add the view readme button
                              MMRIZE @MDWEBB
                              @MDWEBB said in New module installer:
                              This error message seems to be caused by some JS validator trying to check the browser-oriented syntax on the nodeJS environment.
                              @MDWEBB
                              You’d better start from a clean configuration and then add one by one to find what was wrong.
                                sdetweil @MDWEBB
                                I bet this is the remote-control error…
                                shouldn’t stop anything
                                but, if you want to try my fork, which captures that error
                                https://github.com/sdetweil/MMM-Remote-Control
                                just remove the existing folder and git clone mine in its place
                                no functional code change or parms… just trapping this error
                                  MDWEBB @sdetweil
                                  @sdetweil Apologise for slow reply i was able to remove the node modules file and run the update for the module and now my calendar is working again.
                                    sdetweil @MDWEBB
                                    @MDWEBB no apologies required
                                    updated what module?
                                      MDWEBB @sdetweil
                                      @sdetweil update MMM-Remotecontrol.
                                      I am getting update notifications for both the MMM-Config module and MMM-Remote-Control.
                                      MMM-Config says its 3 commits behind the with_installer branch. Not sure whats happening with that
                                      MMM-Remote-Control s 8 commits behind on the master branch i get the following error when trying to use the update script though
                                      mdwebb@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-Remote-Control # adapt directory if you are using a different one
                                      git pull
                                      npm install # install (new) dependencies
                                      Updating 76c0859..5c39b06
                                      error: Your local changes to the following files would be overwritten by merge:
                                      	modules.json
                                      	package-lock.json
                                      	package.json
                                      Please commit your changes or stash them before you merge.
                                      Aborting
                                      up to date, audited 340 packages in 3s
                                      103 packages are looking for funding
                                        run `npm fund` for details
                                      found 0 vulnerabilities
                                        sdetweil @MDWEBB
                                        @MDWEBB yes there are updates to mmm-config
                                        are you using my remotecontrol repo?
                                        i would disable the updatenotification module
                                          MDWEBB @sdetweil
                                          @sdetweil i am using your remote control module yes very handy, however having issues utilising the MMM-Module-Scheduler to to turn my monitor on and off via Remote-Control. i can see in the developer window its trying to send the notification however my monitor isn’t turning off. Am i missing something?
                                                  module: 'MMM-ModuleScheduler',
                                                      notification_schedule: [
                                                          // TURN THE MONITOR/SCREEN ON AT 07:30 EVERY DAY
                                                          {notification: 'REMOTE_ACTION', schedule: '30 7 * * *', payload: {action: "MONITORON"}},
                                                          // TURN THE MONITOR/SCREEN OFF AT 22:30 EVERY DAY
                                                          {notification: 'REMOTE_ACTION', schedule: '01 14 * * *', payload: {action: "MONITOROFF"}},
                                                          // RESTART THE MAGICMIRROR PROCESS AT 2am EVERY SUNDAY
                                                          {notification: 'REMOTE_ACTION', schedule: '0 2 * * SUN', payload: {action: "RESTART"}}
                                            sdetweil @MDWEBB
                                            @MDWEBB issue on remotecontrol
                                            is not MY remote control, I just fixed the error trap that was misleading
                                            no other code change
                                            https://github.com/Jopyth/MMM-Remote-Control/issues/303
                                            which one of the 10 or 12 ways does it try to turn monitor off??
                                            which OS is different
                                            which window compositor is different x11/wayland/labwc is different
                                            I know MMM-PIR has been working hard on making it woirk thru all the choices
                                            did it work before and doesn’t now??
                                            I don’t know the module internals…
                                            • 2 / 3
