    birthdaylist - discontinued ?
    63 Posts 2 Posters 21.8k Views 2 Watching
      @sdetweil clock seconds are enabled, as far as I know …
      at least I haven’t found a parameter to enable/disable seconds
      and second hand is shown …
        sdetweil @rkorell
        @rkorell you are using the analog clock, not digital
        this for digital
        displaySeconds	Display seconds.
        Possible values: true or false
        Default value: true
        and I didn’t see this change
        sendNotifications	Enable notifications for elapsed time. Used to be always done send prio to v2.23
        Possible values: true, or false
        Default value: false
        R 1 Reply Last reply
          @sdetweil Yeah…
          You’re right.
          I’ve set this - my type of clock is set to “both” because I like sunset and day of week information.
          This causes an error in your module…
          birthdaylist.js:398 Uncaught (in promise) TypeError: Cannot read properties of undefined (reading 'startsWith')
              at Class.getBD_DAY_from_Date (birthdaylist.js:398:9)
              at Class.getDom (birthdaylist.js:462:154)
              at main.js:132:35
              at new Promise (<anonymous>)
              at updateDom (main.js:112:10)
              at Object.updateDom (main.js:669:4)
              at Class.updateDom (module.js:341:6)
              at Class.socketNotificationReceived (birthdaylist.js:328:9)
              at module.js:240:9
              at Socket.<anonymous> (socketclient.js:32:4)
          Not sure if this corresponds with the displaySeconds parameter but seen this error first time…
          Regards,
          Ralf
          R S 2 Replies Last reply
            rkorell Module Developer @rkorell
            No, obviously NOT…
            I’ve now added “sendNotifications: true” to config.
            Mirror reloads and your module starts without this error message.
              sdetweil @rkorell
              @rkorell can i see your birthdaylist config
              and the date portion of one birthday from the list, which order the date info is in
              and this error is trying to check if tye month part starts w a 0
              and i figure out which date separator you used
              /, or :, or just not ,
              and then i split the date with the separator i discovered, they all HAVE to be the same separator and order
                @sdetweil yes, for sure
                birth, name
                17/01/1965,Carola
                31/12/1963, Ralf
                27/01/1993, Lennart
                11/07/1987, Levin
                28/07/1985, Katharina
                4/1/1953,Norbert L.
                18/3/1939,Jürgen
                22/3/1996,Chrizzy
                27/3/1985,Hochzeitstag
                31/3/2012,Hannah
                31/3/2022,Nilo
                11/4/1974,Claas
                26/4/1965,Ralf B.
                30/4/1989,Rahel
                7/5/2020,Mathilda
                27/5/1994,Elaine
                10/6/1960,Melanie
                5/2/1965,Stefan
                26/5/2002,Leonie
                4/1/2004,Carolin
                10/6/95, 2.Hochzeitstag
                10/6/1964,Petra B
                23/6/1984,Colin
                29/7/1995,Jassi
                29/7/1955,Shirley P.
                20/7/2001,Helene
                5/8/1963,Harald
                16/9/1997,Shirley Pi.
                20/9/1965,Heiko D.
                15/8/1967,Uta
                23/8/2019,Emil
                17/11/68,Susanne
                27/9/1987,Severin
                9/11/1948,Marianne
                12/11/1967,Silvia
                27/11/1956,Martina L.
                  Ahh…
                  in the code listing it shows up a difference …
                  “10/6/95, 2. Hochzeitstag”
                  with an additional space and a dot…
                  is this a problem?
                  I can change the taxt and delete space if nacessary (althoug I mean I’ve read that you are truncing entries …
                  But the dot could be eliminated if useful.
                  Ralf
                    interesting enough the error shows up first time as I reported - the list is always the same - literally unchanged until first day of installation…
                      sdetweil @rkorell
                      @rkorell nvm i see it… let me look at it
                        sdetweil @rkorell
                        @rkorell I don’t see the error… can you show me the bdlist config
                        also, that line of code would only happen is there WAS a birthday to display
                        and your list doesn’t have one for tomorrow or later (in this month)
                        are for next month…
                        still don’t see the error…
                        my code strips off the extra leading space on the name field.
                          @sdetweil indeed - should have done this at the begin, sorry:
                          // Geburtstagsliste
                          // Gelesen wird: ~/MagicMirror/modules/birthdaylist/data/bdl.csv
                          	        module: "birthdaylist",
                          	        disabled: false,
                          	        position:'top_right',
                          						dimmEntries: false,  // true: dims entries and the associated symbol when the date has expired. false: dont display entries and the associated symbol when the date has expired.
                          						initialLoadDelay: 0, // How many seconds to wait on a fresh start up.
                          						updateDelay: 5,      // How many seconds after midnight before a refresh
                          						currentMonthOnly: false,  // will show birthdays for the current month only if true
                          						maxEntries: 3,	     // maximum entries to show, default is all
                          						dateFormat: '',	     // date format for birthday (default is none), could be 'Do' for 'Sep 12th'
                          						ageFormat:'',	     // some format string for the persons age, '[ n ]'  n will be replace by age value
                          						withMonth: true ,    // then true, add the month display as part of the date field,
                          						debug:true,
                          warmest regards,
                          Ralf
                            Stefan, Jürgen and Chrizzy are shown - which is correct, as far as I understand the parameters.
                              sdetweil @rkorell
                              @rkorell correct, same as what i see. no fault tho
                              the init message appears to be an MagicMirror bug
                              i opened https://github.com/MagicMirrorOrg/MagicMirror/issues/3708
                                @sdetweil OK; thanks.
                                this is regarding the init error.
                                Yesterday night birthdaylist disappeared again.
                                And my initial finding is at least reproducable:
                                Birthdaylist disappears from physical screen (connected via HDMI) and from VNC remote session.
                                BUT: In webbrowser it disappears NOT:
                                If I do a reload in Webbrowser - instantly the birthdaylist appears on screen as well as in VNC session.
                                console log shows:
                                birthdaylist received a system notification: MODULE_DOM_UPDATED
                                I had assumed that I can find all of the console logs in the logfiles in $HOME/.pm2/logs but this is not true.
                                Any idea regarding this discrepancy?
                                Thanks again a LOT for your kind and great support!
                                Warmest regards,
                                Ralf
                                (sorry for the rubbish Browser - rendering but I’m not able (or too stupid) to scale this correctly)
                                  sdetweil @rkorell
                                  @rkorell ok, that message comes in response to a module updating its content. but I see a bug in my code i cant get to today
                                  to work around it add another config parm for the module
                                  debugging:true,
                                  you will get additional messages during setup and nightly refresh (5 seconds after midnight by default)
                                  maybe its not a bug, but a document error
                                    @sdetweil OK; cool.“workaround” is OK for me :-)
                                    so
                                    debug: true,
                                    AND
                                    debugging:true,
                                    both in your module?
                                    Again: Thanks a LOT.
                                    Ralf
                                      sdetweil @rkorell
                                      @rkorell yes, both
                                        @sdetweil OK, thanks.
                                        Have done.
                                          sdetweil @rkorell
                                          @rkorell you should have a couple days on redraw now, does it still disappear?
                                          Can you show the new debug info
                                            Dear Sam , @sdetweil - tahns for following up!!!
                                            No. With the “debugging” switch I did not see a disappearing again .
                                            Yes, for sure, I can see nothing “spectacular”…
                                            Can you derive something from this information?
                                            Warmest regads,
                                            Ralf
                                            • 2 / 4
