    birthdaylist - discontinued ?
    63 Posts 2 Posters 21.8k Views 2 Watching
      sdetweil @rkorell
      @rkorell can i see your birthdaylist config
      and the date portion of one birthday from the list, which order the date info is in
      and this error is trying to check if tye month part starts w a 0
      and i figure out which date separator you used
      /, or :, or just not ,
      and then i split the date with the separator i discovered, they all HAVE to be the same separator and order
      R 1 Reply Last reply
        @sdetweil yes, for sure
        birth, name
        17/01/1965,Carola
        31/12/1963, Ralf
        27/01/1993, Lennart
        11/07/1987, Levin
        28/07/1985, Katharina
        4/1/1953,Norbert L.
        18/3/1939,Jürgen
        22/3/1996,Chrizzy
        27/3/1985,Hochzeitstag
        31/3/2012,Hannah
        31/3/2022,Nilo
        11/4/1974,Claas
        26/4/1965,Ralf B.
        30/4/1989,Rahel
        7/5/2020,Mathilda
        27/5/1994,Elaine
        10/6/1960,Melanie
        5/2/1965,Stefan
        26/5/2002,Leonie
        4/1/2004,Carolin
        10/6/95, 2.Hochzeitstag
        10/6/1964,Petra B
        23/6/1984,Colin
        29/7/1995,Jassi
        29/7/1955,Shirley P.
        20/7/2001,Helene
        5/8/1963,Harald
        16/9/1997,Shirley Pi.
        20/9/1965,Heiko D.
        15/8/1967,Uta
        23/8/2019,Emil
        17/11/68,Susanne
        27/9/1987,Severin
        9/11/1948,Marianne
        12/11/1967,Silvia
        27/11/1956,Martina L.
          rkorell Module Developer @rkorell
          Ahh…
          in the code listing it shows up a difference …
          “10/6/95, 2. Hochzeitstag”
          with an additional space and a dot…
          is this a problem?
          I can change the taxt and delete space if nacessary (althoug I mean I’ve read that you are truncing entries …
          But the dot could be eliminated if useful.
          Ralf
            interesting enough the error shows up first time as I reported - the list is always the same - literally unchanged until first day of installation…
            S 2 Replies Last reply
              sdetweil @rkorell
              @rkorell nvm i see it… let me look at it
                sdetweil @rkorell
                @rkorell I don’t see the error… can you show me the bdlist config
                also, that line of code would only happen is there WAS a birthday to display
                and your list doesn’t have one for tomorrow or later (in this month)
                are for next month…
                still don’t see the error…
                my code strips off the extra leading space on the name field.
                  @sdetweil indeed - should have done this at the begin, sorry:
                  // Geburtstagsliste
                  // Gelesen wird: ~/MagicMirror/modules/birthdaylist/data/bdl.csv
                  	        module: "birthdaylist",
                  	        disabled: false,
                  	        position:'top_right',
                  						dimmEntries: false,  // true: dims entries and the associated symbol when the date has expired. false: dont display entries and the associated symbol when the date has expired.
                  						initialLoadDelay: 0, // How many seconds to wait on a fresh start up.
                  						updateDelay: 5,      // How many seconds after midnight before a refresh
                  						currentMonthOnly: false,  // will show birthdays for the current month only if true
                  						maxEntries: 3,	     // maximum entries to show, default is all
                  						dateFormat: '',	     // date format for birthday (default is none), could be 'Do' for 'Sep 12th'
                  						ageFormat:'',	     // some format string for the persons age, '[ n ]'  n will be replace by age value
                  						withMonth: true ,    // then true, add the month display as part of the date field,
                  						debug:true,
                  warmest regards,
                  Ralf
                    Stefan, Jürgen and Chrizzy are shown - which is correct, as far as I understand the parameters.
                      sdetweil @rkorell
                      @rkorell correct, same as what i see. no fault tho
                      the init message appears to be an MagicMirror bug
                      i opened https://github.com/MagicMirrorOrg/MagicMirror/issues/3708
                        @sdetweil OK; thanks.
                        this is regarding the init error.
                        Yesterday night birthdaylist disappeared again.
                        And my initial finding is at least reproducable:
                        Birthdaylist disappears from physical screen (connected via HDMI) and from VNC remote session.
                        BUT: In webbrowser it disappears NOT:
                        If I do a reload in Webbrowser - instantly the birthdaylist appears on screen as well as in VNC session.
                        console log shows:
                        birthdaylist received a system notification: MODULE_DOM_UPDATED
                        I had assumed that I can find all of the console logs in the logfiles in $HOME/.pm2/logs but this is not true.
                        Any idea regarding this discrepancy?
                        Thanks again a LOT for your kind and great support!
                        Warmest regards,
                        Ralf
                        (sorry for the rubbish Browser - rendering but I’m not able (or too stupid) to scale this correctly)
                          sdetweil @rkorell
                          @rkorell ok, that message comes in response to a module updating its content. but I see a bug in my code i cant get to today
                          to work around it add another config parm for the module
                          debugging:true,
                          you will get additional messages during setup and nightly refresh (5 seconds after midnight by default)
                          maybe its not a bug, but a document error
                            @sdetweil OK; cool.“workaround” is OK for me :-)
                            so
                            debug: true,
                            AND
                            debugging:true,
                            both in your module?
                            Again: Thanks a LOT.
                            Ralf
                              sdetweil @rkorell
                              @rkorell yes, both
                                @sdetweil OK, thanks.
                                Have done.
                                  sdetweil @rkorell
                                  @rkorell you should have a couple days on redraw now, does it still disappear?
                                  Can you show the new debug info
                                    Dear Sam , @sdetweil - tahns for following up!!!
                                    No. With the “debugging” switch I did not see a disappearing again .
                                    Yes, for sure, I can see nothing “spectacular”…
                                    Can you derive something from this information?
                                    Warmest regads,
                                    Ralf
                                      sdetweil @rkorell
                                      @rkorell I don’t see the update just after midnight
                                        @sdetweil OK; sorry, misunderstood.
                                        In the log file is nothing interesting - As far as I’m able to interpret this right:
                                        [2025-02-01 23:52:48.499] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                                        [2025-02-01 23:52:48.920] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                                        [2025-02-01 23:52:51.572] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                                        [2025-02-01 23:57:44.968] [LOG]   2025-02-01T23:57:44 <log> MMM-Strava: "Getting data for module_15_MMM-Strava" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                                        [2025-02-01 23:57:44.973] [LOG]   2025-02-01T23:57:44 <log> MMM-Strava: "Getting athlete activities for module_15_MMM-Strava after 2025-01-01" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                                        [2025-02-01 23:57:45.407] [LOG]   2025-02-01T23:57:45 <log> MMM-Strava: "listActivities api returned 4 activities in page 1 using 200 per page." (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                                        [2025-02-01 23:57:45.582] [LOG]   2025-02-01T23:57:45 <log> MMM-Strava: "Summarising athlete activities for module_15_MMM-Strava" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                                        [2025-02-01 23:57:47.063] [LOG]   2025-02-01T23:57:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                        [2025-02-01 23:57:47.069] [LOG]   2025-02-01T23:57:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                        [2025-02-01 23:57:47.300] [LOG]   2025-02-01T23:57:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                        [2025-02-01 23:57:48.629] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                                        [2025-02-01 23:57:49.043] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                                        [2025-02-01 23:57:51.842] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                                        [2025-02-02 00:02:48.764] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                                        [2025-02-02 00:02:49.155] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                                        [2025-02-02 00:02:52.110] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                                        [2025-02-02 00:07:45.030] [LOG]   2025-02-02T00:07:45 <log> MMM-Strava: "Getting data for module_15_MMM-Strava" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                                        [2025-02-02 00:07:45.036] [LOG]   2025-02-02T00:07:45 <log> MMM-Strava: "Getting athlete activities for module_15_MMM-Strava after 2025-01-01" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                                        [2025-02-02 00:07:45.496] [LOG]   2025-02-02T00:07:45 <log> MMM-Strava: "listActivities api returned 4 activities in page 1 using 200 per page." (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                                        [2025-02-02 00:07:45.670] [LOG]   2025-02-02T00:07:45 <log> MMM-Strava: "Summarising athlete activities for module_15_MMM-Strava" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                                        [2025-02-02 00:07:47.243] [LOG]   2025-02-02T00:07:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                        [2025-02-02 00:07:47.248] [LOG]   2025-02-02T00:07:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                        [2025-02-02 00:07:47.493] [LOG]   2025-02-02T00:07:47 <log> Refreshed access token because it has expired. Expired at: 00:07:46 now is: 00:07:47 (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/core/SpotifyConnector.js:24 )
                                        [2025-02-02 00:07:47.509] [LOG]   2025-02-02T00:07:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                        [2025-02-02 00:07:48.900] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                                        [2025-02-02 00:07:49.269] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                                        Error log is “empty” for the time around midnight:
                                        [2025-02-01 23:07:48.215] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-01 23:22:44.976] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-01 23:37:44.996] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-01 23:52:45.072] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 00:07:45.159] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 00:22:45.228] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 00:37:45.305] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 00:52:45.385] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 01:07:45.623] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 01:22:45.537] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 01:37:45.657] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 01:52:45.742] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 02:07:45.838] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 02:22:45.994] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 02:37:46.097] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 02:52:46.168] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 03:07:46.285] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 03:22:46.325] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 03:37:46.523] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 03:52:46.508] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 04:07:46.575] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 04:22:46.640] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 04:37:46.754] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 04:52:46.811] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        [2025-02-02 05:07:46.922] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                                        Where else can I look?
                                        Regards,
                                        Ralf
                                          sdetweil @rkorell
                                          @rkorell will have to review again . later
                                            @sdetweil Thanks.
                                            Take your time.
                                            This is definitely not urgent!
                                            Ralf
                                            • 2 / 4
