    birthdaylist - discontinued ?
    63 Posts 2 Posters 18.6k Views 2 Watching
      sdetweil @rkorell
      @rkorell I don’t see the error… can you show me the bdlist config
      also, that line of code would only happen is there WAS a birthday to display
      and your list doesn’t have one for tomorrow or later (in this month)
      are for next month…
      still don’t see the error…
      my code strips off the extra leading space on the name field.
        @sdetweil indeed - should have done this at the begin, sorry:
        // Geburtstagsliste
        // Gelesen wird: ~/MagicMirror/modules/birthdaylist/data/bdl.csv
        	        module: "birthdaylist",
        	        disabled: false,
        	        position:'top_right',
        						dimmEntries: false,  // true: dims entries and the associated symbol when the date has expired. false: dont display entries and the associated symbol when the date has expired.
        						initialLoadDelay: 0, // How many seconds to wait on a fresh start up.
        						updateDelay: 5,      // How many seconds after midnight before a refresh
        						currentMonthOnly: false,  // will show birthdays for the current month only if true
        						maxEntries: 3,	     // maximum entries to show, default is all
        						dateFormat: '',	     // date format for birthday (default is none), could be 'Do' for 'Sep 12th'
        						ageFormat:'',	     // some format string for the persons age, '[ n ]'  n will be replace by age value
        						withMonth: true ,    // then true, add the month display as part of the date field,
        						debug:true,
        warmest regards,
        Ralf
          rkorell Module Developer @rkorell
          Stefan, Jürgen and Chrizzy are shown - which is correct, as far as I understand the parameters.
            sdetweil @rkorell
            @rkorell correct, same as what i see. no fault tho
            the init message appears to be an MagicMirror bug
            i opened https://github.com/MagicMirrorOrg/MagicMirror/issues/3708
              @sdetweil OK; thanks.
              this is regarding the init error.
              Yesterday night birthdaylist disappeared again.
              And my initial finding is at least reproducable:
              Birthdaylist disappears from physical screen (connected via HDMI) and from VNC remote session.
              BUT: In webbrowser it disappears NOT:
              If I do a reload in Webbrowser - instantly the birthdaylist appears on screen as well as in VNC session.
              console log shows:
              birthdaylist received a system notification: MODULE_DOM_UPDATED
              I had assumed that I can find all of the console logs in the logfiles in $HOME/.pm2/logs but this is not true.
              Any idea regarding this discrepancy?
              Thanks again a LOT for your kind and great support!
              Warmest regards,
              Ralf
              (sorry for the rubbish Browser - rendering but I’m not able (or too stupid) to scale this correctly)
                sdetweil @rkorell
                @rkorell ok, that message comes in response to a module updating its content. but I see a bug in my code i cant get to today
                to work around it add another config parm for the module
                debugging:true,
                you will get additional messages during setup and nightly refresh (5 seconds after midnight by default)
                maybe its not a bug, but a document error
                  @sdetweil OK; cool.“workaround” is OK for me :-)
                  so
                  debug: true,
                  AND
                  debugging:true,
                  both in your module?
                  Again: Thanks a LOT.
                  Ralf
                    sdetweil @rkorell
                    @rkorell yes, both
                      @sdetweil OK, thanks.
                      Have done.
                        sdetweil @rkorell
                        @rkorell you should have a couple days on redraw now, does it still disappear?
                        Can you show the new debug info
                          Dear Sam , @sdetweil - tahns for following up!!!
                          No. With the “debugging” switch I did not see a disappearing again .
                          Yes, for sure, I can see nothing “spectacular”…
                          Can you derive something from this information?
                          Warmest regads,
                          Ralf
                            sdetweil @rkorell
                            @rkorell I don’t see the update just after midnight
                              @sdetweil OK; sorry, misunderstood.
                              In the log file is nothing interesting - As far as I’m able to interpret this right:
                              [2025-02-01 23:52:48.499] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                              [2025-02-01 23:52:48.920] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                              [2025-02-01 23:52:51.572] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                              [2025-02-01 23:57:44.968] [LOG]   2025-02-01T23:57:44 <log> MMM-Strava: "Getting data for module_15_MMM-Strava" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                              [2025-02-01 23:57:44.973] [LOG]   2025-02-01T23:57:44 <log> MMM-Strava: "Getting athlete activities for module_15_MMM-Strava after 2025-01-01" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                              [2025-02-01 23:57:45.407] [LOG]   2025-02-01T23:57:45 <log> MMM-Strava: "listActivities api returned 4 activities in page 1 using 200 per page." (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                              [2025-02-01 23:57:45.582] [LOG]   2025-02-01T23:57:45 <log> MMM-Strava: "Summarising athlete activities for module_15_MMM-Strava" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                              [2025-02-01 23:57:47.063] [LOG]   2025-02-01T23:57:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                              [2025-02-01 23:57:47.069] [LOG]   2025-02-01T23:57:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                              [2025-02-01 23:57:47.300] [LOG]   2025-02-01T23:57:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                              [2025-02-01 23:57:48.629] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                              [2025-02-01 23:57:49.043] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                              [2025-02-01 23:57:51.842] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                              [2025-02-02 00:02:48.764] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                              [2025-02-02 00:02:49.155] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                              [2025-02-02 00:02:52.110] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                              [2025-02-02 00:07:45.030] [LOG]   2025-02-02T00:07:45 <log> MMM-Strava: "Getting data for module_15_MMM-Strava" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                              [2025-02-02 00:07:45.036] [LOG]   2025-02-02T00:07:45 <log> MMM-Strava: "Getting athlete activities for module_15_MMM-Strava after 2025-01-01" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                              [2025-02-02 00:07:45.496] [LOG]   2025-02-02T00:07:45 <log> MMM-Strava: "listActivities api returned 4 activities in page 1 using 200 per page." (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                              [2025-02-02 00:07:45.670] [LOG]   2025-02-02T00:07:45 <log> MMM-Strava: "Summarising athlete activities for module_15_MMM-Strava" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                              [2025-02-02 00:07:47.243] [LOG]   2025-02-02T00:07:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                              [2025-02-02 00:07:47.248] [LOG]   2025-02-02T00:07:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                              [2025-02-02 00:07:47.493] [LOG]   2025-02-02T00:07:47 <log> Refreshed access token because it has expired. Expired at: 00:07:46 now is: 00:07:47 (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/core/SpotifyConnector.js:24 )
                              [2025-02-02 00:07:47.509] [LOG]   2025-02-02T00:07:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                              [2025-02-02 00:07:48.900] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                              [2025-02-02 00:07:49.269] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                              Error log is “empty” for the time around midnight:
                              [2025-02-01 23:07:48.215] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-01 23:22:44.976] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-01 23:37:44.996] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-01 23:52:45.072] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 00:07:45.159] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 00:22:45.228] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 00:37:45.305] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 00:52:45.385] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 01:07:45.623] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 01:22:45.537] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 01:37:45.657] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 01:52:45.742] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 02:07:45.838] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 02:22:45.994] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 02:37:46.097] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 02:52:46.168] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 03:07:46.285] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 03:22:46.325] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 03:37:46.523] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 03:52:46.508] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 04:07:46.575] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 04:22:46.640] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 04:37:46.754] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 04:52:46.811] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              [2025-02-02 05:07:46.922] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                              Where else can I look?
                              Regards,
                              Ralf
                                sdetweil @rkorell
                                @rkorell will have to review again . later
                                  @sdetweil Thanks.
                                  Take your time.
                                  This is definitely not urgent!
                                  Ralf
                                    sdetweil @rkorell
                                    @rkorell I just pushed some fixes for the update cycle
                                    give it a try…
                                    git pull
                                    to update
                                      @sdetweil , Cool!
                                      Thanks a lot.
                                      pi@smarthome:~/MagicMirror/modules/birthdaylist $ git pull
                                      hint: Pulling without specifying how to reconcile divergent branches is
                                      hint: discouraged. You can squelch this message by running one of the following
                                      hint: commands sometime before your next pull:
                                      hint:
                                      hint:   git config pull.rebase false  # merge (the default strategy)
                                      hint:   git config pull.rebase true   # rebase
                                      hint:   git config pull.ff only       # fast-forward only
                                      hint:
                                      hint: You can replace "git config" with "git config --global" to set a default
                                      hint: preference for all repositories. You can also pass --rebase, --no-rebase,
                                      hint: or --ff-only on the command line to override the configured default per
                                      hint: invocation.
                                      remote: Enumerating objects: 5, done.
                                      remote: Counting objects: 100% (5/5), done.
                                      remote: Compressing objects: 100% (1/1), done.
                                      remote: Total 3 (delta 2), reused 3 (delta 2), pack-reused 0 (from 0)
                                      Unpacking objects: 100% (3/3), 584 bytes | 97.00 KiB/s, done.
                                      From https://github.com/sdetweil/birthdaylist
                                         0c16aeb..e4013e9  master     -> origin/master
                                      Updating 0c16aeb..e4013e9
                                      Fast-forward
                                       birthdaylist.js | 31 +++++++++++++++++++------------
                                       1 file changed, 19 insertions(+), 12 deletions(-)
                                      Can I now remove the debug-attributes?
                                      Warmest regards,
                                      Ralf
                                        sdetweil @rkorell
                                        @rkorell yes, or you can leave them on for a little while
                                          @sdetweil OK; will do.
                                          Thanks.
                                          Ralf
                                            sdetweil @rkorell
                                            @rkorell see any remaining issues?
                                            if not, you can turn off both debug settings for next time you start MagicMirror
                                            • 2 / 4
