    birthdaylist - discontinued ?
    63 Posts 2 Posters 20.0k Views 2 Watching
      @sdetweil said i added some debug for suspending, resuming, and getdom() if suspended
      git pull to update
      add debug:true
      to the config options
      you will see the output from mmm-logging
      who calls before we suspend ?
      Dear Sam,
      thanks a lot.
      pi@smarthome:~/MagicMirror/modules/birthdaylist $ git pull
      hint: Pulling without specifying how to reconcile divergent branches is
      hint: discouraged. You can squelch this message by running one of the following
      hint: commands sometime before your next pull:
      hint:
      hint:   git config pull.rebase false  # merge (the default strategy)
      hint:   git config pull.rebase true   # rebase
      hint:   git config pull.ff only       # fast-forward only
      hint:
      hint: You can replace "git config" with "git config --global" to set a default
      hint: preference for all repositories. You can also pass --rebase, --no-rebase,
      hint: or --ff-only on the command line to override the configured default per
      hint: invocation.
      remote: Enumerating objects: 5, done.
      remote: Counting objects: 100% (5/5), done.
      remote: Compressing objects: 100% (1/1), done.
      remote: Total 3 (delta 2), reused 3 (delta 2), pack-reused 0 (from 0)
      Unpacking objects: 100% (3/3), 419 bytes | 32.00 KiB/s, done.
      From https://github.com/sdetweil/birthdaylist
         0fcfb8c..0c16aeb  master     -> origin/master
      Updating 0fcfb8c..0c16aeb
      Fast-forward
       birthdaylist.js | 11 +++++++++--
       1 file changed, 9 insertions(+), 2 deletions(-)
      git pull has worked, debug is enabled.
      Surprisingly enough today in the morning birthdaylist is NOT disappeared.
      This exactly is the kind of error I like most: Unpredictable and not reproducable :-(
      Thanks anyway for your really great support (I’m pretty sure you do have more than enough other things to do …)
      Checking the console output the “debug” switch works - a lot more of information is showing up.
      Several module notifications are received from your module and broadcasted in log.
      One single “conspicuousness”: undefined is in init! in line 48 of birthdaylist.js :
      (Log.log(this.name + " is in init!");)
      The “suspended” status (and therefore “hidden” (??) ) is reached several times - I guess caused by MMM-Pir ? - at least it corresponds definitely with turning off the screen by MMM-Pir.
      Warmest regards,
      Ralf
        rkorell Module Developer @rkorell
        The suspending call seems indeed to come from MMM-Pir.
        But there is always a resuming…
        birthdaylist received a module notification: MMM_PIR-SCREEN_POWERSTATUS from sender: MMM-Pir
        birthdaylist.js:337 birthdaylist suspending
        birthdaylist.js:108 birthdaylist received a module notification: CURRENTWEATHER_TYPE from sender: weather
        birthdaylist.js:108 birthdaylist received a module notification: WEATHER_UPDATED from sender: weather
        birthdaylist.js:108 birthdaylist received a module notification: CALL_DISCONNECTED from sender: MMM-FRITZ-Box-Callmonitor-py3
        birthdaylist.js:108 birthdaylist received a module notification: MMM_PIR-SCREEN_POWERSTATUS from sender: MMM-Pir
        birthdaylist.js:345 birthdaylist resuming
        2birthdaylist.js:108 birthdaylist received a module notification: MMM_PIR-SCREEN_POWERSTATUS from sender: MMM-Pir
        I assume that we have to wait until birthdaylist disappears and then check the written logs afterwards if there is something different (I guess: NOT :-(. )
        Regards,
        Ralf
          sdetweil @rkorell
          @rkorell right we have to wait, thanks for the great info
          ill look at the init time message
            sdetweil @rkorell
            @rkorell notifications are broadcast. so every module gets every broadcast.
            thats why you have to check if the broadcast is for you , but logging them all can give an idea what is going on.
            if clock seconds was enabled you would see a notification for that too
              @sdetweil clock seconds are enabled, as far as I know …
              at least I haven’t found a parameter to enable/disable seconds
              and second hand is shown …
                sdetweil @rkorell
                @rkorell you are using the analog clock, not digital
                this for digital
                displaySeconds	Display seconds.
                Possible values: true or false
                Default value: true
                and I didn’t see this change
                sendNotifications	Enable notifications for elapsed time. Used to be always done send prio to v2.23
                Possible values: true, or false
                Default value: false
                  @sdetweil Yeah…
                  You’re right.
                  I’ve set this - my type of clock is set to “both” because I like sunset and day of week information.
                  This causes an error in your module…
                  birthdaylist.js:398 Uncaught (in promise) TypeError: Cannot read properties of undefined (reading 'startsWith')
                      at Class.getBD_DAY_from_Date (birthdaylist.js:398:9)
                      at Class.getDom (birthdaylist.js:462:154)
                      at main.js:132:35
                      at new Promise (<anonymous>)
                      at updateDom (main.js:112:10)
                      at Object.updateDom (main.js:669:4)
                      at Class.updateDom (module.js:341:6)
                      at Class.socketNotificationReceived (birthdaylist.js:328:9)
                      at module.js:240:9
                      at Socket.<anonymous> (socketclient.js:32:4)
                  Not sure if this corresponds with the displaySeconds parameter but seen this error first time…
                  Regards,
                  Ralf
                  R S 2 Replies Last reply Reply Quote 0
                    No, obviously NOT…
                    I’ve now added “sendNotifications: true” to config.
                    Mirror reloads and your module starts without this error message.
                      sdetweil @rkorell
                      @rkorell can i see your birthdaylist config
                      and the date portion of one birthday from the list, which order the date info is in
                      and this error is trying to check if tye month part starts w a 0
                      and i figure out which date separator you used
                      /, or :, or just not ,
                      and then i split the date with the separator i discovered, they all HAVE to be the same separator and order
                        @sdetweil yes, for sure
                        birth, name
                        17/01/1965,Carola
                        31/12/1963, Ralf
                        27/01/1993, Lennart
                        11/07/1987, Levin
                        28/07/1985, Katharina
                        4/1/1953,Norbert L.
                        18/3/1939,Jürgen
                        22/3/1996,Chrizzy
                        27/3/1985,Hochzeitstag
                        31/3/2012,Hannah
                        31/3/2022,Nilo
                        11/4/1974,Claas
                        26/4/1965,Ralf B.
                        30/4/1989,Rahel
                        7/5/2020,Mathilda
                        27/5/1994,Elaine
                        10/6/1960,Melanie
                        5/2/1965,Stefan
                        26/5/2002,Leonie
                        4/1/2004,Carolin
                        10/6/95, 2.Hochzeitstag
                        10/6/1964,Petra B
                        23/6/1984,Colin
                        29/7/1995,Jassi
                        29/7/1955,Shirley P.
                        20/7/2001,Helene
                        5/8/1963,Harald
                        16/9/1997,Shirley Pi.
                        20/9/1965,Heiko D.
                        15/8/1967,Uta
                        23/8/2019,Emil
                        17/11/68,Susanne
                        27/9/1987,Severin
                        9/11/1948,Marianne
                        12/11/1967,Silvia
                        27/11/1956,Martina L.
                          Ahh…
                          in the code listing it shows up a difference …
                          “10/6/95, 2. Hochzeitstag”
                          with an additional space and a dot…
                          is this a problem?
                          I can change the taxt and delete space if nacessary (althoug I mean I’ve read that you are truncing entries …
                          But the dot could be eliminated if useful.
                          Ralf
                            interesting enough the error shows up first time as I reported - the list is always the same - literally unchanged until first day of installation…
                              sdetweil @rkorell
                              @rkorell nvm i see it… let me look at it
                                sdetweil @rkorell
                                @rkorell I don’t see the error… can you show me the bdlist config
                                also, that line of code would only happen is there WAS a birthday to display
                                and your list doesn’t have one for tomorrow or later (in this month)
                                are for next month…
                                still don’t see the error…
                                my code strips off the extra leading space on the name field.
                                  @sdetweil indeed - should have done this at the begin, sorry:
                                  // Geburtstagsliste
                                  // Gelesen wird: ~/MagicMirror/modules/birthdaylist/data/bdl.csv
                                  	        module: "birthdaylist",
                                  	        disabled: false,
                                  	        position:'top_right',
                                  						dimmEntries: false,  // true: dims entries and the associated symbol when the date has expired. false: dont display entries and the associated symbol when the date has expired.
                                  						initialLoadDelay: 0, // How many seconds to wait on a fresh start up.
                                  						updateDelay: 5,      // How many seconds after midnight before a refresh
                                  						currentMonthOnly: false,  // will show birthdays for the current month only if true
                                  						maxEntries: 3,	     // maximum entries to show, default is all
                                  						dateFormat: '',	     // date format for birthday (default is none), could be 'Do' for 'Sep 12th'
                                  						ageFormat:'',	     // some format string for the persons age, '[ n ]'  n will be replace by age value
                                  						withMonth: true ,    // then true, add the month display as part of the date field,
                                  						debug:true,
                                  warmest regards,
                                  Ralf
                                    Stefan, Jürgen and Chrizzy are shown - which is correct, as far as I understand the parameters.
                                      sdetweil @rkorell
                                      @rkorell correct, same as what i see. no fault tho
                                      the init message appears to be an MagicMirror bug
                                      i opened https://github.com/MagicMirrorOrg/MagicMirror/issues/3708
                                        @sdetweil OK; thanks.
                                        this is regarding the init error.
                                        Yesterday night birthdaylist disappeared again.
                                        And my initial finding is at least reproducable:
                                        Birthdaylist disappears from physical screen (connected via HDMI) and from VNC remote session.
                                        BUT: In webbrowser it disappears NOT:
                                        If I do a reload in Webbrowser - instantly the birthdaylist appears on screen as well as in VNC session.
                                        console log shows:
                                        birthdaylist received a system notification: MODULE_DOM_UPDATED
                                        I had assumed that I can find all of the console logs in the logfiles in $HOME/.pm2/logs but this is not true.
                                        Any idea regarding this discrepancy?
                                        Thanks again a LOT for your kind and great support!
                                        Warmest regards,
                                        Ralf
                                        (sorry for the rubbish Browser - rendering but I’m not able (or too stupid) to scale this correctly)
                                          sdetweil @rkorell
                                          @rkorell ok, that message comes in response to a module updating its content. but I see a bug in my code i cant get to today
                                          to work around it add another config parm for the module
                                          debugging:true,
                                          you will get additional messages during setup and nightly refresh (5 seconds after midnight by default)
                                          maybe its not a bug, but a document error
                                            @sdetweil OK; cool.“workaround” is OK for me :-)
                                            so
                                            debug: true,
                                            AND
                                            debugging:true,
                                            both in your module?
                                            Again: Thanks a LOT.
                                            Ralf
                                            • 2 / 4
