    birthdaylist - discontinued ?
    63 Posts 2 Posters 20.0k Views 2 Watching
      :-) yes for sure.
      But I had assumed that the already given output (from other modules as well) will change …
        sdetweil @rkorell
        @rkorell i added some debug for suspending, resuming, and getdom() if suspended
        git pull to update
        add debug:true
        to the config options
        you will see the output from mmm-logging
        who calls before we suspend ?
          @sdetweil said i added some debug for suspending, resuming, and getdom() if suspended
          git pull to update
          add debug:true
          Dear Sam,
          thanks a lot.
          pi@smarthome:~/MagicMirror/modules/birthdaylist $ git pull
          hint: Pulling without specifying how to reconcile divergent branches is
          hint: discouraged. You can squelch this message by running one of the following
          hint: commands sometime before your next pull:
          hint:
          hint:   git config pull.rebase false  # merge (the default strategy)
          hint:   git config pull.rebase true   # rebase
          hint:   git config pull.ff only       # fast-forward only
          hint:
          hint: You can replace "git config" with "git config --global" to set a default
          hint: preference for all repositories. You can also pass --rebase, --no-rebase,
          hint: or --ff-only on the command line to override the configured default per
          hint: invocation.
          remote: Enumerating objects: 5, done.
          remote: Counting objects: 100% (5/5), done.
          remote: Compressing objects: 100% (1/1), done.
          remote: Total 3 (delta 2), reused 3 (delta 2), pack-reused 0 (from 0)
          Unpacking objects: 100% (3/3), 419 bytes | 32.00 KiB/s, done.
          From https://github.com/sdetweil/birthdaylist
             0fcfb8c..0c16aeb  master     -> origin/master
          Updating 0fcfb8c..0c16aeb
          Fast-forward
           birthdaylist.js | 11 +++++++++--
           1 file changed, 9 insertions(+), 2 deletions(-)
          git pull has worked, debug is enabled.
          Surprisingly enough today in the morning birthdaylist is NOT disappeared.
          This exactly is the kind of error I like most: Unpredictable and not reproducable :-(
          Thanks anyway for your really great support (I’m pretty sure you do have more than enough other things to do …)
          Checking the console output the “debug” switch works - a lot more of information is showing up.
          Several module notifications are received from your module and broadcasted in log.
          One single “conspicuousness”: undefined is in init! in line 48 of birthdaylist.js :
          (Log.log(this.name + " is in init!");)
          The “suspended” status (and therefore “hidden” (??) ) is reached several times - I guess caused by MMM-Pir ? - at least it corresponds definitely with turning off the screen by MMM-Pir.
          Warmest regards,
          Ralf
            rkorell Module Developer @rkorell
            The suspending call seems indeed to come from MMM-Pir.
            But there is always a resuming…
            birthdaylist received a module notification: MMM_PIR-SCREEN_POWERSTATUS from sender: MMM-Pir
            birthdaylist.js:337 birthdaylist suspending
            birthdaylist.js:108 birthdaylist received a module notification: CURRENTWEATHER_TYPE from sender: weather
            birthdaylist.js:108 birthdaylist received a module notification: WEATHER_UPDATED from sender: weather
            birthdaylist.js:108 birthdaylist received a module notification: CALL_DISCONNECTED from sender: MMM-FRITZ-Box-Callmonitor-py3
            birthdaylist.js:108 birthdaylist received a module notification: MMM_PIR-SCREEN_POWERSTATUS from sender: MMM-Pir
            birthdaylist.js:345 birthdaylist resuming
            2birthdaylist.js:108 birthdaylist received a module notification: MMM_PIR-SCREEN_POWERSTATUS from sender: MMM-Pir
            I assume that we have to wait until birthdaylist disappears and then check the written logs afterwards if there is something different (I guess: NOT :-(. )
            Regards,
            Ralf
              sdetweil @rkorell
              @rkorell right we have to wait, thanks for the great info
              ill look at the init time message
                sdetweil @rkorell
                @rkorell notifications are broadcast. so every module gets every broadcast.
                thats why you have to check if the broadcast is for you , but logging them all can give an idea what is going on.
                if clock seconds was enabled you would see a notification for that too
                  @sdetweil clock seconds are enabled, as far as I know …
                  at least I haven’t found a parameter to enable/disable seconds
                  and second hand is shown …
                    sdetweil @rkorell
                    @rkorell you are using the analog clock, not digital
                    this for digital
                    displaySeconds	Display seconds.
                    Possible values: true or false
                    Default value: true
                    and I didn’t see this change
                    sendNotifications	Enable notifications for elapsed time. Used to be always done send prio to v2.23
                    Possible values: true, or false
                    Default value: false
                      @sdetweil Yeah…
                      You’re right.
                      I’ve set this - my type of clock is set to “both” because I like sunset and day of week information.
                      This causes an error in your module…
                      birthdaylist.js:398 Uncaught (in promise) TypeError: Cannot read properties of undefined (reading 'startsWith')
                          at Class.getBD_DAY_from_Date (birthdaylist.js:398:9)
                          at Class.getDom (birthdaylist.js:462:154)
                          at main.js:132:35
                          at new Promise (<anonymous>)
                          at updateDom (main.js:112:10)
                          at Object.updateDom (main.js:669:4)
                          at Class.updateDom (module.js:341:6)
                          at Class.socketNotificationReceived (birthdaylist.js:328:9)
                          at module.js:240:9
                          at Socket.<anonymous> (socketclient.js:32:4)
                      Not sure if this corresponds with the displaySeconds parameter but seen this error first time…
                      Regards,
                      Ralf
                      R S 2 Replies Last reply Reply Quote 0
                        No, obviously NOT…
                        I’ve now added “sendNotifications: true” to config.
                        Mirror reloads and your module starts without this error message.
                          sdetweil @rkorell
                          @rkorell can i see your birthdaylist config
                          and the date portion of one birthday from the list, which order the date info is in
                          and this error is trying to check if tye month part starts w a 0
                          and i figure out which date separator you used
                          /, or :, or just not ,
                          and then i split the date with the separator i discovered, they all HAVE to be the same separator and order
                            @sdetweil yes, for sure
                            birth, name
                            17/01/1965,Carola
                            31/12/1963, Ralf
                            27/01/1993, Lennart
                            11/07/1987, Levin
                            28/07/1985, Katharina
                            4/1/1953,Norbert L.
                            18/3/1939,Jürgen
                            22/3/1996,Chrizzy
                            27/3/1985,Hochzeitstag
                            31/3/2012,Hannah
                            31/3/2022,Nilo
                            11/4/1974,Claas
                            26/4/1965,Ralf B.
                            30/4/1989,Rahel
                            7/5/2020,Mathilda
                            27/5/1994,Elaine
                            10/6/1960,Melanie
                            5/2/1965,Stefan
                            26/5/2002,Leonie
                            4/1/2004,Carolin
                            10/6/95, 2.Hochzeitstag
                            10/6/1964,Petra B
                            23/6/1984,Colin
                            29/7/1995,Jassi
                            29/7/1955,Shirley P.
                            20/7/2001,Helene
                            5/8/1963,Harald
                            16/9/1997,Shirley Pi.
                            20/9/1965,Heiko D.
                            15/8/1967,Uta
                            23/8/2019,Emil
                            17/11/68,Susanne
                            27/9/1987,Severin
                            9/11/1948,Marianne
                            12/11/1967,Silvia
                            27/11/1956,Martina L.
                              Ahh…
                              in the code listing it shows up a difference …
                              “10/6/95, 2. Hochzeitstag”
                              with an additional space and a dot…
                              is this a problem?
                              I can change the taxt and delete space if nacessary (althoug I mean I’ve read that you are truncing entries …
                              But the dot could be eliminated if useful.
                              Ralf
                                interesting enough the error shows up first time as I reported - the list is always the same - literally unchanged until first day of installation…
                                  sdetweil @rkorell
                                  @rkorell nvm i see it… let me look at it
                                    sdetweil @rkorell
                                    @rkorell I don’t see the error… can you show me the bdlist config
                                    also, that line of code would only happen is there WAS a birthday to display
                                    and your list doesn’t have one for tomorrow or later (in this month)
                                    are for next month…
                                    still don’t see the error…
                                    my code strips off the extra leading space on the name field.
                                      @sdetweil indeed - should have done this at the begin, sorry:
                                      // Geburtstagsliste
                                      // Gelesen wird: ~/MagicMirror/modules/birthdaylist/data/bdl.csv
                                      	        module: "birthdaylist",
                                      	        disabled: false,
                                      	        position:'top_right',
                                      						dimmEntries: false,  // true: dims entries and the associated symbol when the date has expired. false: dont display entries and the associated symbol when the date has expired.
                                      						initialLoadDelay: 0, // How many seconds to wait on a fresh start up.
                                      						updateDelay: 5,      // How many seconds after midnight before a refresh
                                      						currentMonthOnly: false,  // will show birthdays for the current month only if true
                                      						maxEntries: 3,	     // maximum entries to show, default is all
                                      						dateFormat: '',	     // date format for birthday (default is none), could be 'Do' for 'Sep 12th'
                                      						ageFormat:'',	     // some format string for the persons age, '[ n ]'  n will be replace by age value
                                      						withMonth: true ,    // then true, add the month display as part of the date field,
                                      						debug:true,
                                      warmest regards,
                                      Ralf
                                        Stefan, Jürgen and Chrizzy are shown - which is correct, as far as I understand the parameters.
                                          sdetweil @rkorell
                                          @rkorell correct, same as what i see. no fault tho
                                          the init message appears to be an MagicMirror bug
                                          i opened https://github.com/MagicMirrorOrg/MagicMirror/issues/3708
                                            @sdetweil OK; thanks.
                                            this is regarding the init error.
                                            Yesterday night birthdaylist disappeared again.
                                            And my initial finding is at least reproducable:
                                            Birthdaylist disappears from physical screen (connected via HDMI) and from VNC remote session.
                                            BUT: In webbrowser it disappears NOT:
                                            If I do a reload in Webbrowser - instantly the birthdaylist appears on screen as well as in VNC session.
                                            console log shows:
                                            birthdaylist received a system notification: MODULE_DOM_UPDATED
                                            I had assumed that I can find all of the console logs in the logfiles in $HOME/.pm2/logs but this is not true.
                                            Any idea regarding this discrepancy?
                                            Thanks again a LOT for your kind and great support!
                                            Warmest regards,
                                            Ralf
                                            (sorry for the rubbish Browser - rendering but I’m not able (or too stupid) to scale this correctly)
                                            • 2 / 4
