    birthdaylist - discontinued ?
    63 Posts 2 Posters 21.8k Views 2 Watching
      sdetweil @rkorell
      @rkorell correct, same as what i see. no fault tho
      the init message appears to be an MagicMirror bug
      i opened https://github.com/MagicMirrorOrg/MagicMirror/issues/3708
      R 1 Reply Last reply
        @sdetweil OK; thanks.
        this is regarding the init error.
        Yesterday night birthdaylist disappeared again.
        And my initial finding is at least reproducable:
        Birthdaylist disappears from physical screen (connected via HDMI) and from VNC remote session.
        BUT: In webbrowser it disappears NOT:
        If I do a reload in Webbrowser - instantly the birthdaylist appears on screen as well as in VNC session.
        console log shows:
        birthdaylist received a system notification: MODULE_DOM_UPDATED
        I had assumed that I can find all of the console logs in the logfiles in $HOME/.pm2/logs but this is not true.
        Any idea regarding this discrepancy?
        Thanks again a LOT for your kind and great support!
        Warmest regards,
        Ralf
        (sorry for the rubbish Browser - rendering but I’m not able (or too stupid) to scale this correctly)
          sdetweil @rkorell
          @rkorell ok, that message comes in response to a module updating its content. but I see a bug in my code i cant get to today
          to work around it add another config parm for the module
          debugging:true,
          you will get additional messages during setup and nightly refresh (5 seconds after midnight by default)
          maybe its not a bug, but a document error
            @sdetweil OK; cool.“workaround” is OK for me :-)
            so
            debug: true,
            AND
            debugging:true,
            both in your module?
            Again: Thanks a LOT.
            Ralf
              sdetweil @rkorell
              @rkorell yes, both
                @sdetweil OK, thanks.
                Have done.
                  sdetweil @rkorell
                  @rkorell you should have a couple days on redraw now, does it still disappear?
                  Can you show the new debug info
                    Dear Sam , @sdetweil - tahns for following up!!!
                    No. With the “debugging” switch I did not see a disappearing again .
                    Yes, for sure, I can see nothing “spectacular”…
                    Can you derive something from this information?
                    Warmest regads,
                    Ralf
                      sdetweil @rkorell
                      @rkorell I don’t see the update just after midnight
                        @sdetweil OK; sorry, misunderstood.
                        In the log file is nothing interesting - As far as I’m able to interpret this right:
                        [2025-02-01 23:52:48.499] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                        [2025-02-01 23:52:48.920] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                        [2025-02-01 23:52:51.572] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                        [2025-02-01 23:57:44.968] [LOG]   2025-02-01T23:57:44 <log> MMM-Strava: "Getting data for module_15_MMM-Strava" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                        [2025-02-01 23:57:44.973] [LOG]   2025-02-01T23:57:44 <log> MMM-Strava: "Getting athlete activities for module_15_MMM-Strava after 2025-01-01" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                        [2025-02-01 23:57:45.407] [LOG]   2025-02-01T23:57:45 <log> MMM-Strava: "listActivities api returned 4 activities in page 1 using 200 per page." (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                        [2025-02-01 23:57:45.582] [LOG]   2025-02-01T23:57:45 <log> MMM-Strava: "Summarising athlete activities for module_15_MMM-Strava" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                        [2025-02-01 23:57:47.063] [LOG]   2025-02-01T23:57:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                        [2025-02-01 23:57:47.069] [LOG]   2025-02-01T23:57:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                        [2025-02-01 23:57:47.300] [LOG]   2025-02-01T23:57:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                        [2025-02-01 23:57:48.629] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                        [2025-02-01 23:57:49.043] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                        [2025-02-01 23:57:51.842] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                        [2025-02-02 00:02:48.764] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                        [2025-02-02 00:02:49.155] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                        [2025-02-02 00:02:52.110] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                        [2025-02-02 00:07:45.030] [LOG]   2025-02-02T00:07:45 <log> MMM-Strava: "Getting data for module_15_MMM-Strava" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                        [2025-02-02 00:07:45.036] [LOG]   2025-02-02T00:07:45 <log> MMM-Strava: "Getting athlete activities for module_15_MMM-Strava after 2025-01-01" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                        [2025-02-02 00:07:45.496] [LOG]   2025-02-02T00:07:45 <log> MMM-Strava: "listActivities api returned 4 activities in page 1 using 200 per page." (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                        [2025-02-02 00:07:45.670] [LOG]   2025-02-02T00:07:45 <log> MMM-Strava: "Summarising athlete activities for module_15_MMM-Strava" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                        [2025-02-02 00:07:47.243] [LOG]   2025-02-02T00:07:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                        [2025-02-02 00:07:47.248] [LOG]   2025-02-02T00:07:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                        [2025-02-02 00:07:47.493] [LOG]   2025-02-02T00:07:47 <log> Refreshed access token because it has expired. Expired at: 00:07:46 now is: 00:07:47 (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/core/SpotifyConnector.js:24 )
                        [2025-02-02 00:07:47.509] [LOG]   2025-02-02T00:07:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                        [2025-02-02 00:07:48.900] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                        [2025-02-02 00:07:49.269] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                        Error log is “empty” for the time around midnight:
                        [2025-02-01 23:07:48.215] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-01 23:22:44.976] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-01 23:37:44.996] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-01 23:52:45.072] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 00:07:45.159] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 00:22:45.228] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 00:37:45.305] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 00:52:45.385] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 01:07:45.623] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 01:22:45.537] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 01:37:45.657] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 01:52:45.742] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 02:07:45.838] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 02:22:45.994] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 02:37:46.097] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 02:52:46.168] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 03:07:46.285] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 03:22:46.325] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 03:37:46.523] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 03:52:46.508] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 04:07:46.575] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 04:22:46.640] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 04:37:46.754] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 04:52:46.811] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        [2025-02-02 05:07:46.922] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                        Where else can I look?
                        Regards,
                        Ralf
                          sdetweil @rkorell
                          @rkorell will have to review again . later
                            @sdetweil Thanks.
                            Take your time.
                            This is definitely not urgent!
                            Ralf
                              sdetweil @rkorell
                              @rkorell I just pushed some fixes for the update cycle
                              give it a try…
                              git pull
                              to update
                                @sdetweil , Cool!
                                Thanks a lot.
                                pi@smarthome:~/MagicMirror/modules/birthdaylist $ git pull
                                hint: Pulling without specifying how to reconcile divergent branches is
                                hint: discouraged. You can squelch this message by running one of the following
                                hint: commands sometime before your next pull:
                                hint:
                                hint:   git config pull.rebase false  # merge (the default strategy)
                                hint:   git config pull.rebase true   # rebase
                                hint:   git config pull.ff only       # fast-forward only
                                hint:
                                hint: You can replace "git config" with "git config --global" to set a default
                                hint: preference for all repositories. You can also pass --rebase, --no-rebase,
                                hint: or --ff-only on the command line to override the configured default per
                                hint: invocation.
                                remote: Enumerating objects: 5, done.
                                remote: Counting objects: 100% (5/5), done.
                                remote: Compressing objects: 100% (1/1), done.
                                remote: Total 3 (delta 2), reused 3 (delta 2), pack-reused 0 (from 0)
                                Unpacking objects: 100% (3/3), 584 bytes | 97.00 KiB/s, done.
                                From https://github.com/sdetweil/birthdaylist
                                   0c16aeb..e4013e9  master     -> origin/master
                                Updating 0c16aeb..e4013e9
                                Fast-forward
                                 birthdaylist.js | 31 +++++++++++++++++++------------
                                 1 file changed, 19 insertions(+), 12 deletions(-)
                                Can I now remove the debug-attributes?
                                Warmest regards,
                                Ralf
                                  sdetweil @rkorell
                                  @rkorell yes, or you can leave them on for a little while
                                    @sdetweil OK; will do.
                                    Thanks.
                                    Ralf
                                      sdetweil @rkorell
                                      @rkorell see any remaining issues?
                                      if not, you can turn off both debug settings for next time you start MagicMirror
                                        @sdetweil :-)
                                        Just yesterday I made some other minor changes and with this I‘ve deactivated the debug parameters for your module.
                                        Will keep this in my eyes and report back, if problem re-appears or not.
                                        Thanks so far !
                                        Ralf
                                          sdetweil @rkorell
                                          @rkorell awesome, thanks for the feedback
                                            Dear Sam, @sdetweil ,
                                            Just for your information - no action necessary:
                                            Unfortunately problem re-appears if I take the debug and debugging option out.
                                            But: No worries - with these options enabled, birthdaylist doesn’t disappear, so for me it “works” …
                                            Thanks for your great work!
                                            Ralf
                                            • 3 / 4
