    birthdaylist - discontinued ?
    63 Posts 2 Posters 21.8k Views 2 Watching
      @sdetweil OK; cool.“workaround” is OK for me :-)
      so
      debug: true,
      AND
      debugging:true,
      both in your module?
      Again: Thanks a LOT.
      Ralf
        sdetweil @rkorell
        @rkorell yes, both
        R 1 Reply Last reply
          @sdetweil OK, thanks.
          Have done.
            sdetweil @rkorell
            @rkorell you should have a couple days on redraw now, does it still disappear?
            Can you show the new debug info
              Dear Sam , @sdetweil - tahns for following up!!!
              No. With the “debugging” switch I did not see a disappearing again .
              Yes, for sure, I can see nothing “spectacular”…
              Can you derive something from this information?
              Warmest regads,
              Ralf
                sdetweil @rkorell
                @rkorell I don’t see the update just after midnight
                  @sdetweil OK; sorry, misunderstood.
                  In the log file is nothing interesting - As far as I’m able to interpret this right:
                  [2025-02-01 23:52:48.499] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                  [2025-02-01 23:52:48.920] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                  [2025-02-01 23:52:51.572] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                  [2025-02-01 23:57:44.968] [LOG]   2025-02-01T23:57:44 <log> MMM-Strava: "Getting data for module_15_MMM-Strava" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                  [2025-02-01 23:57:44.973] [LOG]   2025-02-01T23:57:44 <log> MMM-Strava: "Getting athlete activities for module_15_MMM-Strava after 2025-01-01" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                  [2025-02-01 23:57:45.407] [LOG]   2025-02-01T23:57:45 <log> MMM-Strava: "listActivities api returned 4 activities in page 1 using 200 per page." (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                  [2025-02-01 23:57:45.582] [LOG]   2025-02-01T23:57:45 <log> MMM-Strava: "Summarising athlete activities for module_15_MMM-Strava" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                  [2025-02-01 23:57:47.063] [LOG]   2025-02-01T23:57:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                  [2025-02-01 23:57:47.069] [LOG]   2025-02-01T23:57:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                  [2025-02-01 23:57:47.300] [LOG]   2025-02-01T23:57:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                  [2025-02-01 23:57:48.629] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                  [2025-02-01 23:57:49.043] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                  [2025-02-01 23:57:51.842] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                  [2025-02-02 00:02:48.764] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                  [2025-02-02 00:02:49.155] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                  [2025-02-02 00:02:52.110] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                  [2025-02-02 00:07:45.030] [LOG]   2025-02-02T00:07:45 <log> MMM-Strava: "Getting data for module_15_MMM-Strava" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                  [2025-02-02 00:07:45.036] [LOG]   2025-02-02T00:07:45 <log> MMM-Strava: "Getting athlete activities for module_15_MMM-Strava after 2025-01-01" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                  [2025-02-02 00:07:45.496] [LOG]   2025-02-02T00:07:45 <log> MMM-Strava: "listActivities api returned 4 activities in page 1 using 200 per page." (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                  [2025-02-02 00:07:45.670] [LOG]   2025-02-02T00:07:45 <log> MMM-Strava: "Summarising athlete activities for module_15_MMM-Strava" (/home/pi/MagicMirror/modules/MMM-Strava/node_helper.js:477 Class.log)
                  [2025-02-02 00:07:47.243] [LOG]   2025-02-02T00:07:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                  [2025-02-02 00:07:47.248] [LOG]   2025-02-02T00:07:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                  [2025-02-02 00:07:47.493] [LOG]   2025-02-02T00:07:47 <log> Refreshed access token because it has expired. Expired at: 00:07:46 now is: 00:07:47 (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/core/SpotifyConnector.js:24 )
                  [2025-02-02 00:07:47.509] [LOG]   2025-02-02T00:07:47 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                  [2025-02-02 00:07:48.900] [INFO]  Newsfeed-Fetcher: Broadcasting 1 items.
                  [2025-02-02 00:07:49.269] [INFO]  Newsfeed-Fetcher: Broadcasting 7 items.
                  Error log is “empty” for the time around midnight:
                  [2025-02-01 23:07:48.215] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-01 23:22:44.976] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-01 23:37:44.996] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-01 23:52:45.072] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 00:07:45.159] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 00:22:45.228] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 00:37:45.305] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 00:52:45.385] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 01:07:45.623] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 01:22:45.537] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 01:37:45.657] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 01:52:45.742] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 02:07:45.838] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 02:22:45.994] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 02:37:46.097] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 02:52:46.168] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 03:07:46.285] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 03:22:46.325] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 03:37:46.523] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 03:52:46.508] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 04:07:46.575] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 04:22:46.640] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 04:37:46.754] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 04:52:46.811] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  [2025-02-02 05:07:46.922] [WARN]  MMM-Fuel: Filtered stationIds list is empty
                  Where else can I look?
                  Regards,
                  Ralf
                    sdetweil @rkorell
                    @rkorell will have to review again . later
                      @sdetweil Thanks.
                      Take your time.
                      This is definitely not urgent!
                      Ralf
                        sdetweil @rkorell
                        @rkorell I just pushed some fixes for the update cycle
                        give it a try…
                        git pull
                        to update
                          @sdetweil , Cool!
                          Thanks a lot.
                          pi@smarthome:~/MagicMirror/modules/birthdaylist $ git pull
                          hint: Pulling without specifying how to reconcile divergent branches is
                          hint: discouraged. You can squelch this message by running one of the following
                          hint: commands sometime before your next pull:
                          hint:
                          hint:   git config pull.rebase false  # merge (the default strategy)
                          hint:   git config pull.rebase true   # rebase
                          hint:   git config pull.ff only       # fast-forward only
                          hint:
                          hint: You can replace "git config" with "git config --global" to set a default
                          hint: preference for all repositories. You can also pass --rebase, --no-rebase,
                          hint: or --ff-only on the command line to override the configured default per
                          hint: invocation.
                          remote: Enumerating objects: 5, done.
                          remote: Counting objects: 100% (5/5), done.
                          remote: Compressing objects: 100% (1/1), done.
                          remote: Total 3 (delta 2), reused 3 (delta 2), pack-reused 0 (from 0)
                          Unpacking objects: 100% (3/3), 584 bytes | 97.00 KiB/s, done.
                          From https://github.com/sdetweil/birthdaylist
                             0c16aeb..e4013e9  master     -> origin/master
                          Updating 0c16aeb..e4013e9
                          Fast-forward
                           birthdaylist.js | 31 +++++++++++++++++++------------
                           1 file changed, 19 insertions(+), 12 deletions(-)
                          Can I now remove the debug-attributes?
                          Warmest regards,
                          Ralf
                            sdetweil @rkorell
                            @rkorell yes, or you can leave them on for a little while
                              @sdetweil OK; will do.
                              Thanks.
                              Ralf
                                sdetweil @rkorell
                                @rkorell see any remaining issues?
                                if not, you can turn off both debug settings for next time you start MagicMirror
                                  @sdetweil :-)
                                  Just yesterday I made some other minor changes and with this I‘ve deactivated the debug parameters for your module.
                                  Will keep this in my eyes and report back, if problem re-appears or not.
                                  Thanks so far !
                                  Ralf
                                    sdetweil @rkorell
                                    @rkorell awesome, thanks for the feedback
                                      Dear Sam, @sdetweil ,
                                      Just for your information - no action necessary:
                                      Unfortunately problem re-appears if I take the debug and debugging option out.
                                      But: No worries - with these options enabled, birthdaylist doesn’t disappear, so for me it “works” …
                                      Thanks for your great work!
                                      Ralf
                                        sdetweil @rkorell
                                        @rkorell weird… will look again…
                                          @sdetweil see above: take your time !!!
                                            rkorell Module Developer @rkorell
                                            — or even ignore this :-)
                                            S 2 Replies Last reply
                                            • 3 / 4
