    Version 2.30.0 weather module, stuck loading, worked fine before upgrade
    52 Posts 6 Posters 35.1k Views 7 Watching
    • A
      angeliKITTYx @sdetweil
      @sdetweil not going to lie, but I don’t see anywhere saying we have to use /onecall as the endpoint, but that worked for me for both of my current and forecast modules. The location is stating my time zone city (which is 8 hours north) , but the information seems to be correct when comparing it to a weather website. Thank you for the help.
        sdetweil @angeliKITTYx
        @angeliKITTYx openweather only provides /onecall in v3.0
        that is why the default is 3.0 and /onecall
        you don’t have to specify them since this release
        location? where do you see that?
        A 1 Reply Last reply
        • A
          @sdetweil screenshot
          you can see on the right module it says “America/New_York” which is my timezone city, but my lat/lon is set to my home many states south. They used to both say that, but I added the “appendLocationNameToHeader” parameter to the left one to see what it would look like.
          Before the API update, it would properly display my home city. I’m pretty sure it’s displaying the correct weather information, but we surprisingly have similar weather to NY right now so it’s hard to confidently confirm.
            @angeliKITTYx yes, new openweather api does not return the location info anymore. so you have to add
            appendLocationToHeader: false
            and add your own header
            i will add that info to the top entry as well
            • A
              @sdetweil yeah that’s what I ended up doing. Thank you again for all your help the last few days! Glad to have everything back to normal.
                Richard238
                Ran the update, weather module failed , read this thread and can now have either weather or forecast. Can we no longer have both, like before?
                  sdetweil @Richard238
                  @Richard238 two instances, type: as appropriate. NO endpoint setting. The v3 openweather api only supports /onecall (already set as default)
                  https://forum.magicmirror.builders/post/123079
                  The config.js.sample shows two instances
                    Richard238
                    @sdetweil said in Version 2.30.0 weather module, stuck loading, worked fine before upgrade:
                    ionToHeader: false
                    default config sample works, but that’s using openmeteo, not openweathermap, is that correct?
                    			module: "weather",
                    				weatherProvider: "openmeteo",
                    				type: "current",
                    				lat: 40.776676,
                    				lon: -73.971321
                    			module: "weather",
                    			header: "Weather Forecast",
                    				type: "forecast",
                    				lat: 40.776676,
                    				lon: -73.971321
                    openweathermap.js I have as
                    		apiVersion: "3.0",
                    		apiBase: "https://api.openweathermap.org/data/",
                    		// weatherEndpoint is "/onecall" since API 3.0
                    		// "/onecall", "/forecast" or "/weather" only for pro customers
                    		weatherEndpoint: "/onecall",
                      @Richard238 leave off those parms. Defaults to 3.0 etc
                      Just put in your 3.0 apikey and lat/lon
                      And of course set the provider
                      R 1 Reply Last reply
                        Richard238 @sdetweil
                        Which ones, sorry?
                          @Richard238 all the openweather ones you showed
                            This gives the ‘undefined, invalid date’ error on the MM
                            			module: 'weather',
                            			header: 'Current xxxxxxxxxxxxxxx  weather: ',
                            			position: 'top_right',
                            				lat: 11111111,
                            				lon:   2222222,
                            				apiKey: "33333333333"
                              @Richard238 and you used real lat/lon
                              R 2 Replies Last reply
                                Yes, real Lat:Lon used
                                  Do the L:L and API key live in the openweathermap.js file, or the config.js file? Or both?
                                    @Richard238 all config goes in config.js
                                    Never need to edit any other file
                                      openweathermap.js is unchanged
                                      WeatherProvider.register("openweathermap", {
                                      	providerName: "OpenWeatherMap",
                                      	// Set the default config properties that is specific to this provider
                                      	defaults: {
                                      		apiVersion: "3.0",
                                      		locationID: false,
                                      		// the /onecall endpoint needs lat / lon values, it doesn't support the locationId
                                      		lat: 0,
                                      		lon: 0,
                                      		apiKey: ""
                                      config.js shows
                                      		module: 'weather',
                                      		header: 'Current zzzzzzzzzzzzzzzz  weather: ',
                                      			//weatherProvider: "openweathermap",
                                      			type: "current",
                                      			lat: nnnnnnnnnnn,
                                      			lon: -nnnnnnnnnnnnn,
                                      			apiKey: "aaaaaaaaaaaaaaaaaaaaaaaaaaa"
                                      			//type: 'current',
                                      			//location: 'xxxxxxxxxxxxxx',
                                      			//locationID: 'zzzzzzzz',  //ID from https://www.openweathermap.org
                                      			//apiKey: 'aaaaaaaaaaaaaaaaaaaaaaaaaaa'
                                        @Richard238
                                        providerName: “OpenWeatherMap”
                                        That is not the correct property name
                                        From the doc
                                        https://docs.magicmirror.builders/modules/weather.html#usage
                                          With no caps? Still doesn’t work.
                                            @Richard238 again show the whole config, xxx out the api key
                                            Start w
                                            position
                                            and config
                                            provider
                                            type ( default is current)
                                            apikey
                                            lat
                                            lon
                                            the 3.0 apikey requires a credit card backing, right?
