    Version 2.30.0 weather module, stuck loading, worked fine before upgrade
    52 Posts 6 Posters 20.4k Views 7 Watching
      Earlier this year(2024), OpenWeather informed us users that they were discontinuing their old 2.5 api version (after 3 years of work)…
      this requires a new apikey, which requires a credit card backing.
      but some number of api requests per day are not charged, (as of 1/1/2025, 1000 api calls per day are ‘free’)
      see https://openweathermap.org/guide
      anyhow, we changed the module defaults to support the new ‘required’ api
      other users have mentioned that thye have changed the apiVersion back to 2.5
      and set the weatherEndPoint back to /weather and /forecast (as appropriate)
      apiVersion:.2.5,
      weatherEndpoint:"/weather"
      or
      weatherEndpoint:"/forecast"
      from the MM doc
      NOTE: as we understand it, at some point in the future, the 2.5 api will stop working at all… (jan1 , 2024, June 15 , 2024, Oct 14, 2024… who knows)
      A R 2 Replies Last reply Reply Quote 0
      • S sdetweil pinned this topic on
        angeliKITTYx @sdetweil
        @sdetweil I signed up for the new subscription and regenerated my API key (just to be safe). I remember it taking some time to show up the first time,so hopefully it will be back to normal in the morning! Thanks for the information.
          angeliKITTYx @angeliKITTYx
          @sdetweil After 24 hours, I’m still stuck at “loading…” could you confirm if I have the config set up properly? I signed up for the Onecall 3.0 API subscription, and it says it’s active.
          			module: "weather",
          				apiVersion: "3.0",
          				type: "forecast",
          				weatherEndpoint: "/forecast",
          				lat: "xxx",
          				lon: "-xxx",
           				apiKey: "cxxx",
          				roundTemp: true,
          				showPrecipitationAmount: true,
          				tableClass: "medium",
          				colored: true,
          			module: "weather",
          				apiVersion: "3.0",
          				type: "current",
          				weatherEndpoint: "/weather",
          				lat: "xxx",
          				lon: "-xxx",
           				apiKey: "cxxx",
          				showWindDirectionAsArrow: true,
          				showSun: false,
          				roundTemp: true,
            sdetweil @angeliKITTYx
            @angeliKITTYx said in Version 2.30.0 weather module, stuck loading, worked fine before upgrade:
              		apiVersion: "3.0",
              		type: "forecast",
            for apiVersion 3.0, you can ONLY use /onecall as the endpoint
            those endpoints /forecast, /… are only good with the old 2.5 apiVersion
              @sdetweil not going to lie, but I don’t see anywhere saying we have to use /onecall as the endpoint, but that worked for me for both of my current and forecast modules. The location is stating my time zone city (which is 8 hours north) , but the information seems to be correct when comparing it to a weather website. Thank you for the help.
                @angeliKITTYx openweather only provides /onecall in v3.0
                that is why the default is 3.0 and /onecall
                you don’t have to specify them since this release
                location? where do you see that?
                A 1 Reply Last reply Reply Quote 1
                  @sdetweil screenshot
                  you can see on the right module it says “America/New_York” which is my timezone city, but my lat/lon is set to my home many states south. They used to both say that, but I added the “appendLocationNameToHeader” parameter to the left one to see what it would look like.
                  Before the API update, it would properly display my home city. I’m pretty sure it’s displaying the correct weather information, but we surprisingly have similar weather to NY right now so it’s hard to confidently confirm.
                    @angeliKITTYx yes, new openweather api does not return the location info anymore. so you have to add
                    appendLocationToHeader: false
                    and add your own header
                    i will add that info to the top entry as well
                      @sdetweil yeah that’s what I ended up doing. Thank you again for all your help the last few days! Glad to have everything back to normal.
                        Richard238
                        Ran the update, weather module failed , read this thread and can now have either weather or forecast. Can we no longer have both, like before?
                          sdetweil @Richard238
                          @Richard238 two instances, type: as appropriate. NO endpoint setting. The v3 openweather api only supports /onecall (already set as default)
                          https://forum.magicmirror.builders/post/123079
                          The config.js.sample shows two instances
                            Richard238
                            @sdetweil said in Version 2.30.0 weather module, stuck loading, worked fine before upgrade:
                            ionToHeader: false
                            default config sample works, but that’s using openmeteo, not openweathermap, is that correct?
                            			module: "weather",
                            				weatherProvider: "openmeteo",
                            				type: "current",
                            				lat: 40.776676,
                            				lon: -73.971321
                            			module: "weather",
                            			header: "Weather Forecast",
                            				type: "forecast",
                            				lat: 40.776676,
                            				lon: -73.971321
                            openweathermap.js I have as
                            		apiVersion: "3.0",
                            		apiBase: "https://api.openweathermap.org/data/",
                            		// weatherEndpoint is "/onecall" since API 3.0
                            		// "/onecall", "/forecast" or "/weather" only for pro customers
                            		weatherEndpoint: "/onecall",
                              @Richard238 leave off those parms. Defaults to 3.0 etc
                              Just put in your 3.0 apikey and lat/lon
                              And of course set the provider
                                Richard238 @sdetweil
                                Which ones, sorry?
                                  @Richard238 all the openweather ones you showed
                                    This gives the ‘undefined, invalid date’ error on the MM
                                    			module: 'weather',
                                    			header: 'Current xxxxxxxxxxxxxxx  weather: ',
                                    			position: 'top_right',
                                    				lat: 11111111,
                                    				lon:   2222222,
                                    				apiKey: "33333333333"
                                      @Richard238 and you used real lat/lon
                                        Yes, real Lat:Lon used
                                          Do the L:L and API key live in the openweathermap.js file, or the config.js file? Or both?
                                            @Richard238 all config goes in config.js
                                            Never need to edit any other file
