    Version 2.30.0 weather module, stuck loading, worked fine before upgrade
    52 Posts 6 Posters 35.1k Views 7 Watching
    • A
      angeliKITTYx @sdetweil
      @sdetweil screenshot
      you can see on the right module it says “America/New_York” which is my timezone city, but my lat/lon is set to my home many states south. They used to both say that, but I added the “appendLocationNameToHeader” parameter to the left one to see what it would look like.
      Before the API update, it would properly display my home city. I’m pretty sure it’s displaying the correct weather information, but we surprisingly have similar weather to NY right now so it’s hard to confidently confirm.
        sdetweil @angeliKITTYx
        @angeliKITTYx yes, new openweather api does not return the location info anymore. so you have to add
        appendLocationToHeader: false
        and add your own header
        i will add that info to the top entry as well
        A 1 Reply Last reply
        • A
          @sdetweil yeah that’s what I ended up doing. Thank you again for all your help the last few days! Glad to have everything back to normal.
            Richard238
            Ran the update, weather module failed , read this thread and can now have either weather or forecast. Can we no longer have both, like before?
              sdetweil @Richard238
              @Richard238 two instances, type: as appropriate. NO endpoint setting. The v3 openweather api only supports /onecall (already set as default)
              https://forum.magicmirror.builders/post/123079
              The config.js.sample shows two instances
                Richard238
                @sdetweil said in Version 2.30.0 weather module, stuck loading, worked fine before upgrade:
                ionToHeader: false
                default config sample works, but that’s using openmeteo, not openweathermap, is that correct?
                			module: "weather",
                				weatherProvider: "openmeteo",
                				type: "current",
                				lat: 40.776676,
                				lon: -73.971321
                			module: "weather",
                			header: "Weather Forecast",
                				type: "forecast",
                				lat: 40.776676,
                				lon: -73.971321
                openweathermap.js I have as
                		apiVersion: "3.0",
                		apiBase: "https://api.openweathermap.org/data/",
                		// weatherEndpoint is "/onecall" since API 3.0
                		// "/onecall", "/forecast" or "/weather" only for pro customers
                		weatherEndpoint: "/onecall",
                  @Richard238 leave off those parms. Defaults to 3.0 etc
                  Just put in your 3.0 apikey and lat/lon
                  And of course set the provider
                  R 1 Reply Last reply
                    Richard238 @sdetweil
                    Which ones, sorry?
                      @Richard238 all the openweather ones you showed
                        This gives the ‘undefined, invalid date’ error on the MM
                        			module: 'weather',
                        			header: 'Current xxxxxxxxxxxxxxx  weather: ',
                        			position: 'top_right',
                        				lat: 11111111,
                        				lon:   2222222,
                        				apiKey: "33333333333"
                          @Richard238 and you used real lat/lon
                          R 2 Replies Last reply
                            Yes, real Lat:Lon used
                              Do the L:L and API key live in the openweathermap.js file, or the config.js file? Or both?
                                @Richard238 all config goes in config.js
                                Never need to edit any other file
                                  openweathermap.js is unchanged
                                  WeatherProvider.register("openweathermap", {
                                  	providerName: "OpenWeatherMap",
                                  	// Set the default config properties that is specific to this provider
                                  	defaults: {
                                  		apiVersion: "3.0",
                                  		locationID: false,
                                  		// the /onecall endpoint needs lat / lon values, it doesn't support the locationId
                                  		lat: 0,
                                  		lon: 0,
                                  		apiKey: ""
                                  config.js shows
                                  		module: 'weather',
                                  		header: 'Current zzzzzzzzzzzzzzzz  weather: ',
                                  			//weatherProvider: "openweathermap",
                                  			type: "current",
                                  			lat: nnnnnnnnnnn,
                                  			lon: -nnnnnnnnnnnnn,
                                  			apiKey: "aaaaaaaaaaaaaaaaaaaaaaaaaaa"
                                  			//type: 'current',
                                  			//location: 'xxxxxxxxxxxxxx',
                                  			//locationID: 'zzzzzzzz',  //ID from https://www.openweathermap.org
                                  			//apiKey: 'aaaaaaaaaaaaaaaaaaaaaaaaaaa'
                                    @Richard238
                                    providerName: “OpenWeatherMap”
                                    That is not the correct property name
                                    From the doc
                                    https://docs.magicmirror.builders/modules/weather.html#usage
                                      With no caps? Still doesn’t work.
                                        @Richard238 again show the whole config, xxx out the api key
                                        Start w
                                        position
                                        and config
                                        provider
                                        type ( default is current)
                                        apikey
                                        lat
                                        lon
                                        the 3.0 apikey requires a credit card backing, right?
                                          			module: 'weather',
                                          			header: 'Current zzzzzzzzzzzzz  weather: ',
                                          				lat: 111111111111111,
                                          				lon: 1111111111111111111111,
                                          				apiKey: "aaaaaaaaaaaaaaaaaaaaaaaaaaaaaa",
                                          				type: 'current',
                                          				units: 'config.units'
                                          				//location: 'zzzzzzzzzzzzzzz',
                                          I must have had that API key for aeons, don’t ever remember it having a c/card behind it.
                                          Maybe it’s out-of-date.
                                            @Richard238 yes they told us the old free api was being terminated. only the new api exists, so we changed the defaults
                                            but other users have reported the 2.5 apikey still works
                                            see the 1st post on this topic
