    Version 2.30.0 weather module, stuck loading, worked fine before upgrade
    52 Posts 6 Posters 35.1k Views 7 Watching
    • A
      angeliKITTYx @angeliKITTYx
      @sdetweil After 24 hours, I’m still stuck at “loading…” could you confirm if I have the config set up properly? I signed up for the Onecall 3.0 API subscription, and it says it’s active.
      			module: "weather",
      				apiVersion: "3.0",
      				type: "forecast",
      				weatherEndpoint: "/forecast",
      				lat: "xxx",
      				lon: "-xxx",
       				apiKey: "cxxx",
      				roundTemp: true,
      				showPrecipitationAmount: true,
      				tableClass: "medium",
      				colored: true,
      			module: "weather",
      				apiVersion: "3.0",
      				type: "current",
      				weatherEndpoint: "/weather",
      				lat: "xxx",
      				lon: "-xxx",
       				apiKey: "cxxx",
      				showWindDirectionAsArrow: true,
      				showSun: false,
      				roundTemp: true,
        sdetweil @angeliKITTYx
        @angeliKITTYx said in Version 2.30.0 weather module, stuck loading, worked fine before upgrade:
          		apiVersion: "3.0",
          		type: "forecast",
        for apiVersion 3.0, you can ONLY use /onecall as the endpoint
        those endpoints /forecast, /… are only good with the old 2.5 apiVersion
        A 1 Reply Last reply
        • A
          angeliKITTYx @sdetweil
          @sdetweil not going to lie, but I don’t see anywhere saying we have to use /onecall as the endpoint, but that worked for me for both of my current and forecast modules. The location is stating my time zone city (which is 8 hours north) , but the information seems to be correct when comparing it to a weather website. Thank you for the help.
            @angeliKITTYx openweather only provides /onecall in v3.0
            that is why the default is 3.0 and /onecall
            you don’t have to specify them since this release
            location? where do you see that?
            • A
              @sdetweil screenshot
              you can see on the right module it says “America/New_York” which is my timezone city, but my lat/lon is set to my home many states south. They used to both say that, but I added the “appendLocationNameToHeader” parameter to the left one to see what it would look like.
              Before the API update, it would properly display my home city. I’m pretty sure it’s displaying the correct weather information, but we surprisingly have similar weather to NY right now so it’s hard to confidently confirm.
                @angeliKITTYx yes, new openweather api does not return the location info anymore. so you have to add
                appendLocationToHeader: false
                and add your own header
                i will add that info to the top entry as well
                • A
                  @sdetweil yeah that’s what I ended up doing. Thank you again for all your help the last few days! Glad to have everything back to normal.
                    Richard238
                    Ran the update, weather module failed , read this thread and can now have either weather or forecast. Can we no longer have both, like before?
                      sdetweil @Richard238
                      @Richard238 two instances, type: as appropriate. NO endpoint setting. The v3 openweather api only supports /onecall (already set as default)
                      https://forum.magicmirror.builders/post/123079
                      The config.js.sample shows two instances
                        Richard238
                        @sdetweil said in Version 2.30.0 weather module, stuck loading, worked fine before upgrade:
                        ionToHeader: false
                        default config sample works, but that’s using openmeteo, not openweathermap, is that correct?
                        			module: "weather",
                        				weatherProvider: "openmeteo",
                        				type: "current",
                        				lat: 40.776676,
                        				lon: -73.971321
                        			module: "weather",
                        			header: "Weather Forecast",
                        				type: "forecast",
                        				lat: 40.776676,
                        				lon: -73.971321
                        openweathermap.js I have as
                        		apiVersion: "3.0",
                        		apiBase: "https://api.openweathermap.org/data/",
                        		// weatherEndpoint is "/onecall" since API 3.0
                        		// "/onecall", "/forecast" or "/weather" only for pro customers
                        		weatherEndpoint: "/onecall",
                          @Richard238 leave off those parms. Defaults to 3.0 etc
                          Just put in your 3.0 apikey and lat/lon
                          And of course set the provider
                          R 1 Reply Last reply
                            Richard238 @sdetweil
                            Which ones, sorry?
                              @Richard238 all the openweather ones you showed
                                This gives the ‘undefined, invalid date’ error on the MM
                                			module: 'weather',
                                			header: 'Current xxxxxxxxxxxxxxx  weather: ',
                                			position: 'top_right',
                                				lat: 11111111,
                                				lon:   2222222,
                                				apiKey: "33333333333"
                                  @Richard238 and you used real lat/lon
                                  R 2 Replies Last reply
                                    Yes, real Lat:Lon used
                                      Do the L:L and API key live in the openweathermap.js file, or the config.js file? Or both?
                                        @Richard238 all config goes in config.js
                                        Never need to edit any other file
                                          openweathermap.js is unchanged
                                          WeatherProvider.register("openweathermap", {
                                          	providerName: "OpenWeatherMap",
                                          	// Set the default config properties that is specific to this provider
                                          	defaults: {
                                          		apiVersion: "3.0",
                                          		locationID: false,
                                          		// the /onecall endpoint needs lat / lon values, it doesn't support the locationId
                                          		lat: 0,
                                          		lon: 0,
                                          		apiKey: ""
                                          config.js shows
                                          		module: 'weather',
                                          		header: 'Current zzzzzzzzzzzzzzzz  weather: ',
                                          			//weatherProvider: "openweathermap",
                                          			type: "current",
                                          			lat: nnnnnnnnnnn,
                                          			lon: -nnnnnnnnnnnnn,
                                          			apiKey: "aaaaaaaaaaaaaaaaaaaaaaaaaaa"
                                          			//type: 'current',
                                          			//location: 'xxxxxxxxxxxxxx',
                                          			//locationID: 'zzzzzzzz',  //ID from https://www.openweathermap.org
                                          			//apiKey: 'aaaaaaaaaaaaaaaaaaaaaaaaaaa'
                                            @Richard238
                                            providerName: “OpenWeatherMap”
                                            That is not the correct property name
                                            From the doc
                                            https://docs.magicmirror.builders/modules/weather.html#usage
