    Version 2.30.0 weather module, stuck loading, worked fine before upgrade
    52 Posts 6 Posters 35.1k Views 7 Watching
      Richard238
      Ran the update, weather module failed , read this thread and can now have either weather or forecast. Can we no longer have both, like before?
        sdetweil @Richard238
        @Richard238 two instances, type: as appropriate. NO endpoint setting. The v3 openweather api only supports /onecall (already set as default)
        https://forum.magicmirror.builders/post/123079
        The config.js.sample shows two instances
          Richard238
          @sdetweil said in Version 2.30.0 weather module, stuck loading, worked fine before upgrade:
          ionToHeader: false
          default config sample works, but that’s using openmeteo, not openweathermap, is that correct?
          			module: "weather",
          				weatherProvider: "openmeteo",
          				type: "current",
          				lat: 40.776676,
          				lon: -73.971321
          			module: "weather",
          			header: "Weather Forecast",
          				type: "forecast",
          				lat: 40.776676,
          				lon: -73.971321
          openweathermap.js I have as
          		apiVersion: "3.0",
          		apiBase: "https://api.openweathermap.org/data/",
          		// weatherEndpoint is "/onecall" since API 3.0
          		// "/onecall", "/forecast" or "/weather" only for pro customers
          		weatherEndpoint: "/onecall",
            @Richard238 leave off those parms. Defaults to 3.0 etc
            Just put in your 3.0 apikey and lat/lon
            And of course set the provider
            R 1 Reply Last reply
              Richard238 @sdetweil
              Which ones, sorry?
                @Richard238 all the openweather ones you showed
                  This gives the ‘undefined, invalid date’ error on the MM
                  			module: 'weather',
                  			header: 'Current xxxxxxxxxxxxxxx  weather: ',
                  			position: 'top_right',
                  				lat: 11111111,
                  				lon:   2222222,
                  				apiKey: "33333333333"
                    @Richard238 and you used real lat/lon
                    R 2 Replies Last reply
                      Yes, real Lat:Lon used
                        Do the L:L and API key live in the openweathermap.js file, or the config.js file? Or both?
                          @Richard238 all config goes in config.js
                          Never need to edit any other file
                            openweathermap.js is unchanged
                            WeatherProvider.register("openweathermap", {
                            	providerName: "OpenWeatherMap",
                            	// Set the default config properties that is specific to this provider
                            	defaults: {
                            		apiVersion: "3.0",
                            		locationID: false,
                            		// the /onecall endpoint needs lat / lon values, it doesn't support the locationId
                            		lat: 0,
                            		lon: 0,
                            		apiKey: ""
                            config.js shows
                            		module: 'weather',
                            		header: 'Current zzzzzzzzzzzzzzzz  weather: ',
                            			//weatherProvider: "openweathermap",
                            			type: "current",
                            			lat: nnnnnnnnnnn,
                            			lon: -nnnnnnnnnnnnn,
                            			apiKey: "aaaaaaaaaaaaaaaaaaaaaaaaaaa"
                            			//type: 'current',
                            			//location: 'xxxxxxxxxxxxxx',
                            			//locationID: 'zzzzzzzz',  //ID from https://www.openweathermap.org
                            			//apiKey: 'aaaaaaaaaaaaaaaaaaaaaaaaaaa'
                              @Richard238
                              providerName: “OpenWeatherMap”
                              That is not the correct property name
                              From the doc
                              https://docs.magicmirror.builders/modules/weather.html#usage
                                With no caps? Still doesn’t work.
                                  @Richard238 again show the whole config, xxx out the api key
                                  Start w
                                  position
                                  and config
                                  provider
                                  type ( default is current)
                                  apikey
                                  lat
                                  lon
                                  the 3.0 apikey requires a credit card backing, right?
                                    			module: 'weather',
                                    			header: 'Current zzzzzzzzzzzzz  weather: ',
                                    				lat: 111111111111111,
                                    				lon: 1111111111111111111111,
                                    				apiKey: "aaaaaaaaaaaaaaaaaaaaaaaaaaaaaa",
                                    				type: 'current',
                                    				units: 'config.units'
                                    				//location: 'zzzzzzzzzzzzzzz',
                                    I must have had that API key for aeons, don’t ever remember it having a c/card behind it.
                                    Maybe it’s out-of-date.
                                      @Richard238 yes they told us the old free api was being terminated. only the new api exists, so we changed the defaults
                                      but other users have reported the 2.5 apikey still works
                                      see the 1st post on this topic
                                        Rberry91 @sdetweil
                                        @sdetweil hi Sam,
                                        I have added a credit card and added the extra codes from the article and it doesn’t load.20250308_055711.jpg
                                          sdetweil @Rberry91
                                          @Rberry91 if you have the 3.0 apikey you dont add any extra parms
                                          just type, apikey, lat and lon
                                            Rberry91 @sdetweil
                                            It still says invalid date
                                            Sorry so many questions
