MMM-PublicTransportHafas: Service Temporarily Unavailable
I did the update
cd ~/MagicMirror/modules/MMM-PublicTransportHafas
git pull
npm cibut it still does not work.
Any idea??
pi@magicmirror-buero:~/MagicMirror/modules/MMM-PublicTransportHafas $ npm ci
npm warn deprecated vbb-translate-ids@3.1.0: Deprecated. Use vbb-translate-ids@latest.
npm warn deprecated hafas-client@2.10.4: Deprecated. Use hafas-client@latest. -
@Volkae Looks like you don’t use my fork. I recommend deleting the module and install this: https://github.com/KristjanESPERANTO/MMM-PublicTransportHafas
@KristjanESPERANTO said in MMM-PublicTransportHafas: Service Temporarily Unavailable:
I think to be more clear, deleting the module folder
@KristjanESPERANTO
Thank you for your support. I hope to find some time this weekend to implement your suggestion. -
@KristjanESPERANTO , it works. Thanks a lot. :-)
Hi, thanks for your update.
I installed your git version and I had to install undici additionally. Is that correct?The MM works but ended starting up again and agin:
0|mm | <— Last few GCs —>
0|mm | [17870:0x2a530000] 119266 ms: Mark-Compact (reduce) 126.9 (128.6) -> 126.4 (128.1) MB, pooled: 0 MB, 791.61 / 0.00 ms (+ 0.9 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 816 ms) (average mu = 0.190, current[17870:0x2a530000] 120521 ms: Mark-Compact 126.9 (128.1) -> 126.5 (128.6) MB, pooled: 0 MB, 1201.60 / 0.00 ms (average mu = 0.113, current mu = 0.043) allocation failure; scavenge might not succeed
0|mm | <— JS stacktrace —>
0|mm | FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
0|mm | ----- Native stack trace -----
0|mm | /home/mirror/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRTIm using a raspberry pi zero with 512 MB RAM which worked fine in the past.
Also some system information:
0|mm | [2025-02-03 08:57:53.254] [INFO] System information:
0|mm | ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model A Plus Rev 1.0; virtual: false
0|mm | ### OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v7+
0|mm | ### VERSIONS: electron: 32.2.7; used node: 22.13.1; installed node: 22.13.1; npm: 10.9.2; pm2: 5.4.3
0|mm | ### OTHER: timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefinedAnyone have the same problem?
while running and short time before crashing:
user:~ $ free -m
total used free shared buff/cache available
Mem: 426 217 99 19 109 132
Swap: 871 250 621 -
@rotorax OK try this
export NODE_OPTIONS=--max-old-space-size=4096before the npm start
if using pm2 then this goes in the script it launches,
using my setup
MagicMirror/installers/mm.sh4096 may need to be adjusted
@sdetweil thanks for the idea. I already had this code seen. But never implemented in my pm2 startup file.
I tried up to 512 (limit of the raspberry I have).Thats the log I got:
0|mm | [22565:0x47124000] 127560 ms: Mark-Compact (reduce) 127.2 (128.1) -> 126.7 (128.3) MB, pooled: 0 MB, 731.03 / 0.01 ms (+ 36.3 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 896 ms) (average mu = 0.169, curren[22565:0x47124000] 128545 ms: Mark-Compact (reduce) 127.2 (128.3) -> 126.4 (127.8) MB, pooled: 0 MB, 832.78 / 0.00 ms (+ 1.0 ms in 0 steps since start of marking, biggest step 0.0 ms, walltime since start of marking 860 ms) (average mu = 0.162, current
0|mm | /home/mirror/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRTI rolled back to the old config before the change of the MMM-PublicTransprtHafas and it run hours (unfortunately I don’t get any live data anymore with the old version)…
More ideas? ;) Grateful for every hint :)
@rotorax i am certain you have to have at LEAST 4096, not smaller, maybe 8192
